Re: oil on the clutch housing
First thing is to make sure it is oil. Fuel leaks look a lot like oil and there are a few places on top of the engine where leaks can occur. The oil / fuel can run back the engine in the V, down the back of the block and around the joint between the bellhousing and the engine block.
If it is inside the bellhousing most likely a rear main seal. Tranny and flywheel must come out to repair.
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed manual, two wheel drive, 3.55 gears, LUK clutch conversion, 450 lb homemade REAR BUMPER, homemade open element AIR FILTER, aluminum bed cap. With me in the cab (285#) and full of fuel weighs 6,580 lbs (steer 3420 drive 3160)
