Re: oil cooler R&R
When I pulled out a few oil coolers I took front left wheel off and used loooooong [img]/ubbthreads/images/graemlins/cool.gif[/img] 3/8 extention through fender well to remove 2 front bolts on cooler flange. It was a peice of cake and I just took utility knife to cut small slit in the well first to allow wiggle room and to see the bolts. No need to raise engine or touch engine mounts. Just remove block heater and filter and the cooler will pull out the rear side after twisting just a bit.
Jim Sult / Excavator (we dig it)
Trying to fix it? KISS IT "KEEP IT SIMPLE STUPID"
Avatar- my everyday 1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60  , Bilsteins shocks, Stock for now Auto trans, Baby Swamps, Tony Wildman  Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 173000 miles
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, Tymar intake, 112000 miles
1997 F350 XL DRW Powerstroke , DP Tuner PCM, 5 speed,Luk Clutch Tymar intake. DPP downpipe, 175,000 miles
Truck Pics
HOME of FIRST Banjo Bolt Ratchet
Fan clutch wrench
