I went out the other day and started my truck when it was pretty cold so i was going to let it warm up. When I get outside of my truck I noticed a huge oil leak underneath the front of the engine. Well needless to say it hasnt leaked a day in its life and now all of a sudden it does. I noticed that it came from what looks like oil lines right underneath the drive side exhaust manifold? Does anybody have any advice for me, or had the same problem? Thanks
'95 Ford F-350, CC,4x4, 7.3 Powerstroke,RDS Stage 1's,Tony Wildman 6 position chip,3.55LS,modded IDM(Thanks Dan),3" downpipe-5" mitre cuts,ebpv gutted, 6" tip,Napa 6637 air filter,Autometer ultra lite triple pillar gauges,Dana 60,Rancho RS 5000 schocks,E40D junk trans,,Aluminum tool box with 7 LED's, headache rack,bed protectors,Hayden Trans. Cooler,Custom Homemade SD Stainless Steel Nerf Bars,285/75/16 BFG All Terrains on Factory Alcoa's,'02 SD Intercooler with homemade IC pipes,Gooseneck hitch
I have not had to replace the o-rings in mine yet, but other here have. I sounds like a traight forward job, but whe I have looked at mine it seems like a bear of a job.
I remember seeing a bunch of pics & instructions in the IDI section. I happened to be looking at On-board air and they had a bunch of fixtures to clamp the ends back on. I hope the OBS TDIs aren't that much trouble.
