i have this same leak, leaks about 2 drops of oil at shut down sometimes. The oil pump is sealed to the front cover by an o ring. So yau are pretty much looking at the same job you just did plus pulling the oil pump off and replacing the oring.
Diesel Mechanic 28 yrs
No just cleanliness, prelube the pump and follow the torque specs.
