Old 05-15-2005, 06:09 PM   #1 (permalink)
oil, oil everywhere
200 miles from home cruising along at 75 my floorboard seems warmer than normal then starts to stink like burning oil. Get out and oil is almost pouring out the bottom -trace it back up. As you look at the engine left side ,right where the pipe comes out and into the turbo mech. where it bolts down is all wet with oil.It took 4 quarts every 60 miles just to keep up. What happened? is this a gasket thing? or do I need to sit down while I get the bad news? [img]/ubbthreads/images/graemlins/frown.gif[/img]
97 F-250 Powerstroke xlt ext cab 5 spd 4x4 , shimmed fpr, Gutted ebpv, Beans Stage 1's, real Tymar intake, 1.0 upgraded turbo,7.3 Okiecooler, New h20 and oil pump.MBRP3" dp and 4" exhaust, Ts6 pos.superduty springs, 17* hpop, TONY WILDMAN tuned, SouthBend ConFe
next....D66
number 19
The only thing I can't do is the thing I'm fixin to learn how to do.
tates97 is offline
Old 05-15-2005, 06:26 PM   #2 (permalink)
Re: oil, oil everywhere
Turbo orings maybe. EBPV maybe. High pressure galley bolt backed out.
Clean as best you can have someone start the truck while you look you may need a mirror to look at the back side of the turbo.
Good Luck
Midwestman
John
Smokin' [img]/ubbthreads/images/graemlins/smokin.gif[/img]and Strokin' [img]/ubbthreads/images/graemlins/cool.gif[/img]
95 350 CC SRW 4X4 398k. Amsoil everwhere w/dualbypass filter. Early Centurion model custom paint (white with grey striping) Grey shell, brushguard, Flexsteel leatherseating wood trim and overhead console. BTS hold on tight E4OD tranny. Custom chip by Cale Thompson at BTS. Hypermax DP. Tymar Open element intake. Tru-Cool 28,000 GVW trans cooler plus Super Duty trans cooler. Super Duty Intercooler with GTS pipes. CCV mod. 3 pod A pillar guages with Isspro Pyrometer,Boost and Tranny temp guages. Fumoto oil drain. John Deere coolant eye. Sylvania Silverstars. Joe Servo IDM. BABY SWAMPS. Magnaflow 4" exhaust. Tymar Coolant Filter. Sirius satellite radio. Kelderman Air Ride on the rear. Mods as the budget will allow.I think I am almost finished.
midwestman is offline
Old 05-15-2005, 06:32 PM   #3 (permalink)
Thats cool i'll look at that .the oil seems to be coming more from cover over the injectors than the turbo area its just coming from the area from where the pipe goes up to the turbo. but i'll take a look
next....D66
number 19
tates97 is offline
Old 05-15-2005, 06:45 PM   #4 (permalink)
There are only a couple of places it could be coming from. Could be the large plug at the back of the head, it seals the high pressure oil rail. We had an o-ring on that plug go out and it lost oil everywhere.
2003 GMC Sierra 2500HD Duramax/Allison 4x4 standard cab.... 12.11@113.39 #2 so far.....
004wdPSD is offline
Old 05-15-2005, 09:02 PM   #5 (permalink)
MarkEkberg's Avatar
My Photos: (13)
I had a similiar issue, but not as bad. It was a galley plug. Had a hard time tracing it. I had to clean everything with carb cleaner before I found it.
MarkEkberg is offline
Old 05-16-2005, 12:04 AM   #6 (permalink)
Patrick Feeley's Avatar
My Photos: (18)
Check your HP oil hoses and the connections where they attach to the pump and heads. I lost about 4 quarts in ten miles when one of the o-rings failed at the pump connection. The valley filled with oil and ran down the back passenger side of the engine. Cheers!
1994 F350 CC DRW 2WD PSD (ALF4), ZF 5 Speed, 4.10 LS, SBC Con-O SMFW/Clutch, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Stancor GPR, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro (pre-turbo) , Relocated Block Heater Plug, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 05-16-2005, 04:36 PM   #7 (permalink)
I have a similar leak, no oil in valley, not leaking at EBPV, where is the galley plug?? how can you tell if it is the turbo pedestal?
Scotty
1997 F250 extcab short bed 4X4 OFF ROAD 5speed 104K, Tymar intake, Tymar 4inch turbo back exhaust, LUK SMFW, AIC, gutted EBPV
Boone NC
Tarheelstroker is offline
Old 05-16-2005, 06:56 PM   #8 (permalink)
I found the problem its the gasket for the left exhaust cover plate(? the name escapes me)the one with the pipe going into the turbo. I got the engine all cleaned up and everything I had loosen and out of the way.
Do I have take the HPOP thing out to get that bottom bolt out closest to the front of the truck??? Is there anything i should know if that is the case?
next....D66
number 19
tates97 is offline
Old 05-16-2005, 07:21 PM   #9 (permalink)
please explain more what gasket you are talking about where should I look for it? (been chasing this leak for months!)
Scotty
Boone NC
Old 05-16-2005, 07:30 PM   #10 (permalink)
If you are looking at the fuel bowl from the front of truck to the left of it is a plate with the pipe going out of it connected to the turbo. This plate also has a wiring harness attached to it. Its not the cover with the oil fill but to its right. I say the gasket but its really caulk. I cleaned it up real good with acetone and compressed air started it up fortunately it was coming from the top. thats my deal but the hpop unit is sitting on the front-most bolt and need to know how to get it out and what expect . [img]/ubbthreads/images/graemlins/shrug.gif[/img]
next....D66
number 19
tates97 is offline
