Old 07-19-2007, 09:25 PM   #1 (permalink)
Oil Pan Seal Question
I have searched the site for an answer but could not find anything so please forgive my ignorance. My 1994.5 Ford F350 Powerstroke has an oil pan leak and I realize I cannot get the pan out. Will removing the trans and transfer and raising the motor get it out or do I need to pull the engine? If the engine has to come out does it need to come all the way out? If I have to pull a motor with 107,000 miles on the thing what else should I look for or replace while its out? Rear seal, any O rings or seals, any help? Thanks people. Joe FJ40
joefj40 is offline
Old 07-19-2007, 09:32 PM   #2 (permalink)
My Photos: (9)
Re: Oil Pan Seal Question
I believe the engine has to be pulled, then flipped upside down for the sealant to set overnight.
2002 F-350 crew cab, DRW PSD 4x4 automatic. 158,000 miles, Ford AIS, otherwise completely stock.
'94 2WD F-250 PSD 5 speed. 302,000 miles, DIY open intake, 5" single stack, Banks pyro and boost gauge, Grover air horns, DynaMat. Still on the original CPS!
Foxx is offline
Old 07-19-2007, 11:29 PM   #3 (permalink)
johndeere9610's Avatar
Send a message via AIM to johndeere9610 Send a message via Yahoo to johndeere9610
I would rering the oilcooler at least if it hasnt been done.
1995 F-350, Auto (stock), 4x4, Crewcab, Longbed, 4" superlift, 35" BFG's All Terrains, E12000 Milemarker Winch, 5" miter stacks, 160cc Injectors, Shimmed FPR, Tymar Intake, Tyamr HPX, 7.3L Intercooler , 6.0L Tranny Cooler(Thanks Jon), ISSPRO Guages Trany/Boost/Pyro, Built tranny in garage being built.
WILDMAN NATION
RDRCM# 50
johndeere9610 is offline
Old 07-20-2007, 07:59 AM   #4 (permalink)
yes engine has to come out. it might be possible to do i by just lifting it but the old pan comes of very very hard. plus you wanta get it very clean so that the new one seals good. just pull the engine out. i use a air chisel to remove the old oil pan. remove the paint from the sealing surface's of the oil pan. clean surfaces very good with brake cleaner. then using plenty of sealant seal it up leave the block upside down for 24 hours to let the sealant cure proparly, it doesn't like oil on it until it gets to cure up. i'll second the oil cooler o-rings, much easier to do with the engine out and cheap to.
check out <font color="red">dzljim.com</font> he has a pretty good write up on pulling the engine out. make sure you have everything disconnected.
<span style="color: #FF0000">#18</span> not all trucks are created equal
THE COWBOY'S CADILLAC,<span style="color: #FF0000">my pics.</span>, 96 F-350 XLT SC DRW PSD, 4x4 conversion(D60),more oil than you, auto tranny by faubion motorsports, tuned by a backwoods hack(thanks tony), 230cc injectors, D66 turbo, head studs, 910 valvesprings, open element intake, homebuilt fuel system, 3-4"DP, intercooler with homemade spider and piping, 5" chrome stacks with turnouts, front hitch(for my weight bar), member of the <span style="color: #FF0000">WNYPA</span>
on the way: more power
bullridin_fool is offline
Old 07-24-2007, 09:47 PM   #5 (permalink)
might be smart to reseal your dipstick tube adaptor too because that would be a lot easier. like the other guys said, be sure to remove all the old silicone and make sure absolutely no oil comes in contact with the silicone before it sets up.
'94 F250xlt ext. cab. ZF5-speed 4x4. DPP downpipe. Tymar intake. Tymar coolant filter. LF9691 primary filter. LF777 bypass oil filter. Electric fans. 70 psi fpr. 10k mod. 1.0 turbo housing. Boost blanket.
sdan27 is offline
