Old 07-01-2005, 11:04 AM   #1 (permalink)
OK BEFORE I MAIL IT OFF TO MY OLD MAN A FEW ?????'S
ok heres the deal i bought 2 chips from a vendor/ sponsor here.
i have a 97 federal truck with 5 speed and mleo code.
my dad has a 97 cali truck 5 speed with ???? code.
what i asked when purchasing is will the mle1 burn be fine for my dad? i already know it's just a later burn than mine.
what i got was a hold please and then a few minutes later a response of yes it is what you need. not that i dont trust the vendor but we are talking about my dads 60k mile psd here. i would feel horrible if it blew up or fried the pcm. [img]/ubbthreads/images/graemlins/phoney.gif[/img] [img]/ubbthreads/images/graemlins/confused.gif[/img]
JKA2 JKA3 are the 2 codes for his truck.
so that being said i know some of you have run some weird combos i.e.
splits with a non split pcm
regular injectors with a split pcm
i know one of these ways work but the other doesn't if i read right somewhere. so what about my situation splits with a splits pcm with a 49s chip burn of mle1?
please post only if you are 100% certain. thanks
btw if you are the vendor i purchased this from please understand. thanks [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img]
RYAN
GAUGES, INTAKE, EXHUAST, SBC CLUTCH, CHIP, BDP INJECTORS, BILSTEINS, BUSHINGS...AND A WHOLE LOT MORE..
pics
B99 BIO DIESEL SUPPORTING AMERICAS FARMERS.
US NAVY
looking for an ext cab 4x4 short bed DURAMAX!!! keeping the obs of course.
1997PSD4ME is offline
Old 07-01-2005, 11:11 AM   #2 (permalink)
Re: OK BEFORE I MAIL IT OFF TO MY OLD MAN A FEW ?????'S
If the chip has Jody's or Tony's burns I would not worrie..if someone elses [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 07-01-2005, 11:25 AM   #3 (permalink)
The MLE code won't blow up the truck, don't worry, it may idle a little funny, but it won't hurt the truck.
99.5 F-350 C/C Dually, Stealth HPOP, Full Force Diesel stroked A code injectors, Holset turbo, AEM intake.
Vengeance is offline
Old 07-01-2005, 11:53 AM   #4 (permalink)
You can do a single shot pcm on split injectors.
I have a 96 CA engine. Before I put in my Stage I's, with my splitshot injectors I put in a single shot pcm and chip, and it ran perfect. Though having splitshot programming on single shot injectors I hear is difficult to idle correctly.
You should be good, though. I wouldn't worry. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
I do have my old PCM sitting around, though, if his takes a poop for whatever reason let me know. 96 CA model 5spd. code AUG6
- Ryan
<font color="red">7.3 POWERSTROKE DIESEL</font> F-250 Flatbed 4x4 -- full info and pics inside
<font color="black">DOB 6/10/1996</font>
<font color="red">bdp</font> <font color="#8B7162">Stage I injectors and custom programs</font>
<font color="orange">SBC</font> <font color="#8B7162">Con OFE</font>
<font color="green">2002</font> <font color="#8B7162">SD HPOP</font>
285HP
Live in SoCal? Check out SoCAPS! [img]/ubbthreads/images/graemlins/grin.gif[/img]
ryanPSD is offline
Old 07-01-2005, 01:38 PM   #5 (permalink)
ok now that i'm thinking about it. when you plug a chip in it over rides whatever pcm code you have and makes it the chip code right? so this essentially is mnaking his pcm a 49 state truck with the mle1 code right? cool glad to hear this will work. ryanpsd i will keep you in mind if we have any problems. thanks for the offer. my dad with splits should be making more power than me right? due to increased amount of fuel. [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
RYAN
pics
US NAVY
Old 07-01-2005, 01:58 PM   #6 (permalink)
I don't really know how the chip works to control the pcm parameters and all that. But I don't think it will "change" the pcm code as you were saying.
Before I could run the single shot pcm I had to make sure the chip was on it. I replaced the pcm only and tried firing it up (single shot pcm on splits with no chip) and the idle was crazy. I didn't try the chip though on the split shot pcm as you are doing but it should go fine. The worst that could happen would be it won't run right but it won't hurt anything, so either pull the chip and have it reflashed, or pull the pcm and replace with or reflash to a code for single shots (like TDE1, which is what mine is, even though this code's for an auto it won't affect having a 5spd).
And yes...the split shots have quite a bit of power in store once the chip is in [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img] Check my sig for the chip install link and I have videos of my truck with the chip/pcm only (no injectors). The splits have tiny more power on the low end compared to my Stage I's (though quite a bit more overall than the stock singles), but since the I's once you get the rpms up a little and the turbo starts singing...hold on! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
BTW, where does your old man live? www.socaps.com [img]/ubbthreads/images/graemlins/smokin.gif[/img]
- Ryan
285HP
ryanPSD is offline
Old 07-01-2005, 02:14 PM   #7 (permalink)
If you install a "4" bank chip with the MLE code onto a pcm with the original code of, say a SOD4 for instance, the chip will overide the pcm. If you have a single bank chip then it will need to match the original code of the pcm in order to work.
You will have no worries, the chip you have with the MLE prgrams on it will work fine, the truck will think it has regained its senses [img]/ubbthreads/images/graemlins/eek.gif[/img] and begin to act normal [img]/ubbthreads/images/graemlins/smirk.gif[/img], it will no longer be a liberal [img]/ubbthreads/images/graemlins/mad.gif[/img], Clinton luvin [img]/ubbthreads/images/graemlins/bleh.gif[/img], tree huggin squirrel kissin [img]/ubbthreads/images/graemlins/crazy.gif[/img], no smoke blowin [img]/ubbthreads/images/graemlins/blush.gif[/img], might as well use it for an anchor because its soooo slow [img]/ubbthreads/images/graemlins/zombie.gif[/img], POS [img]/ubbthreads/images/graemlins/vomit.gif[/img], and will immediatly be transformed into a hard rockin [img]/ubbthreads/images/graemlins/smokin.gif[/img], soot blowin [img]/ubbthreads/images/graemlins/smokin.gif[/img], Greenpeace hatin [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img], Bush lovin [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img], roaring beast that every time your Dad rips into it off the line it will send a thick [img]/ubbthreads/images/graemlins/cool.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img], black cloud of nasty ozone killin [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img], beautiful smellin diesel [img]/ubbthreads/images/graemlins/phoney.gif[/img] soot at the "save the spotted field mouse" crowd [img]/ubbthreads/images/graemlins/eek.gif[/img], and make them run for cover [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]!!!!!
Oopps [img]/ubbthreads/images/graemlins/phoney.gif[/img] sorry, that just kinda slipped out [img]/ubbthreads/images/graemlins/blush.gif[/img]
Old 07-01-2005, 02:20 PM   #8 (permalink)
I think he's lost it. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
- Ryan
285HP
ryanPSD is offline
Old 07-01-2005, 02:31 PM   #9 (permalink)
i love you that was great!!!!! i bet george bush has a psd on that ranch of his in texas!!!!!!!!!!! [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img]
RYAN
pics
US NAVY
Old 07-01-2005, 03:35 PM   #10 (permalink)
My Photos: (6)
so it sounds like you are sayin that the S0D4 chip is a cali burn? Hmm.. I needs to get me a new burn then.. I live in Oregon now anyway.
Also, I thought all trucks in 97 used the split shots? if that is the case, you wouldn't be mixing normal shot programming with a spitshot injectors?
Just shoot me if I got this all mixed up!
'95 F250 XLT 4X4 Ext Cab long bed, 5 speed, SMFW, custom kevlar LuK clutch by Superior Friction San Jose, 3.55 LSD, '88 kingpin D60, Sky RSK with SD V code springs, 175K miles, ATS 1.15 BB turbo, BDP Stage 2.5 injectors, BDP fuel system, 4 line Stealth, '02 120V IDM, ARP studs, Spearco 7.3 intercooler, 3" intakes, Northern Diesel Performance 6-pos TS chip w/TW tunes, guages, Tymar intake, EBPS bypass mod, IH bellowed uppipes, 4" DP, straight exhaust, 200PSI train horns and 215A alternator..
Home of the 94 and 95 HPOP anti bleed down mod
General Truck pictures..
radarman is offline
Old 07-01-2005, 03:38 PM   #11 (permalink)
My Photos: (21)
Nope, just the California trucks.
JIM
His: 1997 F350 PSD, CC, 4X4, 4.10's, 35/12.5/16.5's BFG's
Hers: 1997 F250 PSD, X-Cab, 4x4, 4.10's, 315's
All My Photos
Toys/Blown Head Gasket
Drag Videos
motor/turbo/fuelsystem pics
Traction Bars
Father & Son Time
THE_ALASKAN is offline
Old 07-01-2005, 04:50 PM   #12 (permalink)
No I didn't say the SOD4 was a Kali burn, I just used that for an example. The SOD4 is a 49 stater burn.
Old 07-04-2005, 11:57 AM   #13 (permalink)
George does have a psd its a white crew cab 4x4 swb SD. I saw a picture of it In a news paper one time with him and some president from some other country riding in it.
Justin
1983 F-250 2wd Diesel 4 spd man with 3in Body.
1996 F-250 extended cab 4wd MLE) with 230k miles,4" TC Lift, 79'D60, full spool, Warn hubs, 3.55, 5 speed, 6 pos TS chip, 3" downpipe, straight piped, 5" tip, Open element home made setup, Luk, autometer boost and pyro, cali. fpr kit, ranchhand front, 35" Cooper ST 's 2005 F350 emblems, big dent in side of bed [img]/ubbthreads/images/graemlins/frown.gif[/img]
Next: 4"or 5" Exhaust, injectors, traction bars
Truck and misc pics
black_smoke6.9 is offline
Old 07-04-2005, 05:31 PM   #14 (permalink)
yes george is a good man. i knew deep down inside he owned one and you just confirmed. i gotta tell my dad about this. i wonder if george has any mods. i wonder if we can get him to join tds. login name the_pres's_psd?? sounds cool to me. [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
RYAN
pics
US NAVY
