Old 11-19-2005, 05:26 PM   #1 (permalink)
OLD STYLE HPOP MOD ?
<font color="black"> </font> i have 95 psd with original hpop. was wondering if anyone knows how to do the swashplate? fuel pressure reg? shimming mod &amp; if it will increase fuel delivery with stock injectors. [img]/ubbthreads/images/graemlins/confused.gif[/img]
-95 F350,PSD,CC,All White,E4OD,- 250 RWHP 560 TQ
-Stage 2 AFE Magnum Force Intake - Custom Flip Chip - Isspro 60 lb. Boost,Scaled Pyro & Tranny Temp in pillar pod - <font color="red">Turbonetics Ball Buster Windmill</font>[img]/ubbthreads/images/graemlins/cool.gif[/img] - Homemade Downpipe - Homemade Reg. Return Fuel System - HPX mod - CCV Mod - Homemade 4" Exaust - 3" Intake Plenums - TransGo HD2 Shift Kit - Soon To Come; Custom I/C - BDP Stage II's - Bigger Oil - Still Looking For that 400+ RWHP!!! [img]/ubbthreads/images/graemlins/cool.gif[/img]
-97 F350,PSD,CC,ZF5SPD. - 3" DP. - LuK Single Mass Flywheel & Clutch. - Isspro 60 lb. Boost & Scaled Pyro in pillar pod.- 100 a/r Non EBPV Turbo - Edge Evolution Race Tuned - 260,xxx Miles And Counting [img]/ubbthreads/images/graemlins/smile.gif[/img]
God,Guns,And Guts Made America. Lets Keep all 3
Gun Control = Using Both Hands!!! &gt;&lt;&gt; &lt;&gt;&lt;
CUR3406B is offline
Old 11-20-2005, 12:41 AM   #2 (permalink)
Patrick Feeley's Avatar
My Photos: (18)
Re: OLD STYLE HPOP MOD ?
Welcome to the forum!
Modifying the HPOP would not be one of the DIY variety mods (it would be easier to swap in a later-model pump). For fuel regulator shimming, it will give you a bit quicker throttle response, but nothing earth-shattering. You can use a BB between the regualator spool piece and spring or you can get the "California Kit" from Ford that will do essentially the same thing (Ford part F6TZ-9K061-AA). Cheers!
1994 F350 CC DRW 2WD PSD (ALF4), ZF 5 Speed, 4.10 LS, SBC Con-O SMFW/Clutch, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Stancor GPR, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro (pre-turbo) , Relocated Block Heater Plug, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 11-20-2005, 04:41 AM   #3 (permalink)
wow only one post and already got a sig filled out!!! Thats worth a couple stars in my book!
Thanks,
Jeff
1996 F-250 Powerstoke Diesel XLT, smokes bad, rides kinda rough.
open element air filter, H2E turbo, Custom Tranny, 6.0 Charge air cooler, Swamp 175/173 squirts, TS chip, A Cool Radio, COBRA truck condom.
WEBSHOTS--&gt;http://community.webshots.com/user/dieselwiezil
--&gt;http://houstonareapowerstrokes.com
DieselWiezil is offline
Old 11-20-2005, 01:20 PM   #4 (permalink)
if i swap to a later model super duty hpop will i have problems with oil drainback in hpop resivoir? my engine is a 95 psd in an F350.
how much pressure does the hpop normally build @ WOT?
how much is too much?
also on the fuel pressure reg, i checked my pressure last night,it reads 65psi. is this normal? sufficient? if so will increasing FP above 65psi increase throttle response or fuel delivery?
sorry if i ask too many questions. [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img]
CUR3406B is offline
Old 11-20-2005, 02:11 PM   #5 (permalink)
Powerstroke2000's Avatar
My Photos: (17)
Stock injectors can only put out so much fuel, no matter where you put your fuel pressure, albeit at 65 PSI you are close to being right on anyway.
I have the '95 PSD and run an '01 HPOP, and yes, there would be a drainback issue, but if you look in my sig, I've added an oil accumulator tank which takes care of the issue.
As for how many PSI of pressure for the HPOP...it depends on the pump! I believe the idea, is to see a steady 3000 PSI (constant) which isn't available with the stock HPOP's as far as I know? There are aftermarket HPOP's out now that can hold that and increase it, but "cost" is the main "Con" to adding one, and isn't necessarily going to help a set of stock injectors enough to pay for itself in my opinion. If your looking for larger power increases, there are other modifications worthy of looking at for less $$ than the aftermarket HPOP's.
In most cases the Superduty type HPOP's with a 17° swash plate design would give you a higher oil output for your stock injectors (if that's only what you are looking for).
Aftermarket injectors &amp; programming, along with other supporting modifications would give you the most power for the dollars spent! The folks here can give you a whole host of information with regard to "the best bang for the buck" with regard to Powerstroke power add-ons.
There also is a SWAMP Performance 20° swash plate designed HPOP available for those wishing for a greater increase in pressure holding oil.
Personally, I found doing the IDM (injector drive module) modification, gave me a much better throttle response, and then adding programming to that made it even better.
Some say my throttle response is too great (truck wants to jump too soon) for every day driving, but that of course depends on what setting my chip is at.
As for questions...there is no such thing here as "too many questions", so fire away, read the responses, and make up your own mind as to what is valid for your own purposes.
Best of luck with your mods, and welcome to the site!
(Any info here that others disagree with, please say so, so the new members have a better reflection on making their decisions).
Dale
IDM mod
TYMAR intake
Amsoil dual by-pass
Precision Ind triple disk Torque Convertor & Pro build tranny
Transgo Tugger shift kit
Ford AIC & full gauges
Mini-Me/SWAMP 250cc Hybrid 530 injectors
17° HPOP
5" custom exhaust
Superduty Intercooler & GTS pipe kit
CCV mod
TS 4 position Flip Chip
<span style="color: blue"> My truck </span> & <span style="color: blue"> Dual Idler Tensioner mod </span> , <span style="color: blue"> Superduty HPOP & Mini-Me ~ Swamp Injectors </span>
Powerstroke2000 is offline
Old 11-20-2005, 03:24 PM   #6 (permalink)
IDM Mod? I'm green so help me here. Does this modify the injector drive voltage or does this have something to do with timing? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
CUR3406B is offline
Old 11-21-2005, 01:09 AM   #8 (permalink)
YES on both counts, it increases the voltage that the IDM puts out, which opens the injectors a bit sooner which has the same effect as advancing the timing and making the pulse width a little wider.
more about it:
Powerstroke Diesel IDM mod
Ok I am intrested. Is this a DIY mod? If so does anyone know how it is done? [img]/ubbthreads/images/graemlins/cool.gif[/img]
CUR3406B is offline
Old 11-21-2005, 08:46 PM   #11 (permalink)
Thanks for the info &amp; the link Bluemule,very informative. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Anyone know where to find these high quality 75,000 ohm resistors?
Oh by the way,can anyone tell me what this 10k mod is that i keep seeing mentioned? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
CUR3406B is offline
Old 11-21-2005, 09:22 PM   #12 (permalink)
Banned
Radio shack will have resistors.
lukecline is offline
Old 11-21-2005, 10:00 PM   #13 (permalink)
I think someone said the resistors that radio shack sells are low quality jobs? [img]/ubbthreads/images/graemlins/shrug.gif[/img] Does Anyone Know? [img]/ubbthreads/images/graemlins/confused.gif[/img]
CUR3406B is offline
Old 11-21-2005, 10:59 PM   #14 (permalink)
My Photos: (6)
yes, Radio Shack will not have what you need. You need to get the specialized stuff at http://www.digikey.com.
'95 F250 XLT 4X4 Ext Cab long bed, 5 speed, SMFW, custom kevlar LuK clutch by Superior Friction San Jose, 3.55 LSD, '88 kingpin D60, Sky RSK with SD V code springs, 175K miles, ATS 1.15 BB turbo, BDP Stage 2.5 injectors, BDP fuel system, 4 line Stealth, '02 120V IDM, ARP studs, Spearco 7.3 intercooler, 3" intakes, Northern Diesel Performance 6-pos TS chip w/TW tunes, guages, Tymar intake, EBPS bypass mod, IH bellowed uppipes, 4" DP, straight exhaust, 200PSI train horns and 215A alternator..
Home of the 94 and 95 HPOP anti bleed down mod
General Truck pictures..
radarman is offline
