Old 11-21-2006, 11:08 PM   #1 (permalink)
Overboost code
Now that the injectors are done when i really get into the throttle its sets off an overboost code. I know on the super duties it will defuel when this happens but does it happen to our obs trucks? If so, how do i go about changing it? Thanks.
96 f-250 4x4,ext. cab long box,4.10ls,auto,shimmed fpr,tymar intake,4"exhaust w/5" mitre cut stacks,DP tuner F5, 4" lift and stage 1's.
green600zr is offline
Old 11-22-2006, 12:37 AM   #2 (permalink)
Re: Overboost code
Are you sure it's overboost and not hpop pressure too low? I have always heard that obs won't defuel, but the MAP boost regulator from dieselsite or others will solve your light coming on for overboost.
'01 F-250,4x4,SC,LWB, Evans coolant/coolant filter, ATS Stage 5 tranny/torque converter, V-10 tranny cooler, 3.73 w/Detroit locker, Truetrac front, Bilstein 5100's, Auto-Meter Phantom's, 5" Hypermax exhaust
BDP
'02 F-250 4x2 CC SWB 4R100, 3.73ls(shimmed carrier), DI chip, CCV mod, 203* t-stat, coolant filter, AIH delete, Tymar HPX oil line, AIS, WW, Banks 1.0 "slowspool" housing, pedistal mod, Banks elbow&BHA, 4" turbo back w/btm, Isspro's
6.0 intercooler install(OBS)&truck pics
<span style="color: red">RDRCM #10 </span>
Sniper's credo "If you run, you'll just die tired"
richmondfarms is offline
Old 11-22-2006, 07:41 AM   #3 (permalink)
Dieselfever78's Avatar
Send a message via AIM to Dieselfever78
Re: Overboost code
It will set a code and defuel, but won't show a CEL when it happens. Get yourself some type of MAP sensor regulator to only show the MAP sensor about 20#
-Michael
Michael Paul
1995 F250: Regular cab, 7.3L PSD, 5-Speed, 4x4, 4.10 LSD, gauges, 2L chip, injectors, turbo, 4" downpipe - 6" tip, clutch, fuel system, Medium oil, Headstuds, Valvesprings, Cab lights, Dana 60 - New Look Soon!
1995 F250: Regular cab, 7.3L PSD, 5-speed, 4x2, 3.55 open, Intake, Downpipe, 4" exhaust, clutch, 2L chip, short throw shifter - To do list!
My Webshots
Dieselfever78 is offline
Old 11-22-2006, 11:09 AM   #4 (permalink)
Re: Overboost code
What inj. [img]/ubbthreads/images/graemlins/confused.gif[/img] Your setting a low HPOP more than likely.
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 11-22-2006, 11:59 AM   #5 (permalink)
Re: Overboost code
Nope its an oveboost code, and your right the light doesnt come on. I didnt know it set it till i ran my scanner on it. But yea everynow and again it does set off the 1211 code. Oh by the way their stage ones. It easily hits high 30's for boost.
Old 11-22-2006, 02:42 PM   #6 (permalink)
Re: Overboost code
Just get a way to only show the MAP sensor 20# of boost or less. Dieselsite sells a blow off valve that works great, and you can also use it for your gauge.
-Michael
Michael Paul
My Webshots
Old 11-22-2006, 04:24 PM   #7 (permalink)
PSDan000's Avatar
My Photos: (11)
Send a message via AIM to PSDan000
Re: Overboost code
those little valves that go in the map line go after the fitting for the boost guage correct? Tubzz gave me one of these but i never put it in, i may throw it on there see what it does.
-Dan
1996 F-250 PSD, 195k, 4x4, Supercab, LB, 3.55's, 4" lift, Built Auto with Precision converter, 150cc injectors, Autometer Z-series Pyro/Boost/Tranny/Diff guages, DIY open element intake, Sandpiper Diesel Performance 4" exhaust, TS 6pos. chip with 2L Motorsports tunes, Shimmed FPR, Modded IDM, Stainless HPX mod from ITPDIESEL.com , Baldwin Coolant Filter from Dieselsite.com , Bilstein shocks on all 4 corners, 315/75 BFG A/T's on 16x10 black Rockcrawlers, Custom front bumper, Ranch hand rear bumper, Warn manual hubs, Sparky's AIC, Full chrome grille,
318hp 643tq
#24
sitting in the garage: 6.0 Intercooler
My Webshots
[URL="http://www.thedieselstop.com/forums/
PSDan000 is offline
Old 11-22-2006, 07:20 PM   #8 (permalink)
Re: Overboost code
I thought a p1211 DTC was an ICP code and was usually set off from low HPOP pressure [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Clete is offline
Old 11-22-2006, 07:37 PM   #9 (permalink)
Banned
Re: Overboost code
-Michael
no it won't.i have run down the track with this code and no defueling
the obs truck are not as smart as the SD trucks that will defuel.
it will just set a code,get a plow off valve and put in the map line.mine is set at 24lbs to blow off.this has been talk about before
but the 1211 code is icp not controllable
over boost code is 0236
tubzz is offline
Old 11-22-2006, 07:57 PM   #10 (permalink)
Re: Overboost code
thanks for the carification T T T T Buzzzzzzz [img]/ubbthreads/images/graemlins/cool.gif[/img]
Thanks Clete
1997 F250 XLT PSD,CC,4wd,E4OD,4.10L,Hypermax 3" DP,Beans Stage I's, Tymar intake, 5" exhaust w/muffler rear exit, Intercooled, pedal mod, HPX cross over, 4 Position chip with some badazz burns, FPR shimmed, modded IDM, Isspro EV trans.temp in collum pod, and pyro guage and boost set in "A" pillar, tranny cooler ,remote trans filter, Fuel heater in the scrap iron, Precision Industries Stallion TC, Mag Hy-tech transmission pan.
Galaxy 959 peaked and tuned ,DM452 mic, Predator 10K
Pulling 30' Jayco 5th wheel
#12
http://good-times.webshots.com/photo...99722885MOkzUQ
Clete is offline
