Old 08-29-2006, 05:55 PM   #1 (permalink)
Places to put the chip switch?
Were have you guys mounted the dial for you multi-position chip switches? Just ordered one and am thinking where i want it to go.
03 F250 SC LB 4x4
4.5 inch DR kit. 35's
Freeflowing 4 inch lol
In SO-CAL?
Check out Southern California Powerstrokes.(SOCAPS).
desertwheeler is offline
Old 08-29-2006, 07:21 PM   #2 (permalink)
kfjensen's Avatar
Re: Places to put the chip switch?
Ive seen it all over the dash, my favorite place was right above the electric window and door lock switches on the same panel
Kevin
94.5, PSD, F-250, 4x4, Handshaker, Couple Do-Dads
kfjensen is offline
Old 08-29-2006, 07:45 PM   #3 (permalink)
i was gunna do that with mine but i asked tony about it and he steered me away from that. said that if i were to splice the wires to put it in itd have to be done again if id want to reburn the chip. ended up puttin mine on the left side of the instrument cluster kinda tucked in so its harder to see from the outside [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Joey
97 F-350,XLT, 4-dr, auto, 270xxx mi, Geolander A/T's, 4"exhaust, no ebpv, 203* t-stat, electric fans, lunar gauges, amsoil nose to tail, custom weight bracket and hitch for pullin, diy intake/air filter, hpx hose, LED cab lights, extra fuse panels, kenwood stereo system, pedestal from Rick, 4r100 out of an '01, trans mods from Jon, custom big fuel system, arb's front and rear, and 6.0 i/c, custom big oil
pics
"...the smoke rolled out and the day turned BLACK!"
stage II's
D66
THANKS BEAN!
awesome tuning
THANKS TONY!
'06 M7 153" Let it Snow!
joeyslushr is offline
Old 08-29-2006, 07:49 PM   #4 (permalink)
I thought about putting mine on the bottom side of the steering column I took the plastic cover off looked like it would fit.
1997 F-250 PSD, 130k, 4x4, Outlaw E4ODX, Standard Cab, reg bed, 3.55 LS rear, Swamps 225/146 injectors, Autometer Guages Pyro/Boost/Tranny, 3" downpipe, 3.5" adjusted exhaust, ts 6 pos chip, Tonys fun programs, Tru-Cool H7B, 285/75, factory alum rims, Western V-Plow, 6.0 intercooler installed not plumbed
I wish my lawn was Emo, cause then it would cut itself
Racerxautomotive.com for your upgraded E4OD/4R100 needs
BlindViper is offline
Old 08-29-2006, 08:29 PM   #5 (permalink)
i put mine in the little cubby by your knee, you have to look to find it, and i dont use the cubby anyway. [img]/ubbthreads/images/graemlins/grin.gif[/img]
97 f-250 powerstroke, e40d shift kit big cooler, 4:10 gears, goose neck hitch,twildmn 4 pos chip, Tymar Intake, 3" downpipe and the cat is dead. HX crossover hose, 3guage pod, Gutted EBPV. 137,000miles
86 f-250 extended cab,4x4,auto,6.9l with hypermax turbo running on veggie.
President of www.RRORC.com
greenbeast is offline
Old 08-29-2006, 09:00 PM   #6 (permalink)
mine is on the left hand side of the steering column. I love it there, easy to drive and switch positions that way.
96' F350 4X4. E4OD tranny running Amsoil synthetic, 1 big tranny cooler and tricumulator springs and accumulator valve. Autometer guages, homemade intake, TS 6 position Chip (tuning by Diesel Innovations , Factory AIC, A/C mod, MBRP 4" Exaust, BDP Stage I injectors, Brakesmart trailer brake controller, T/C lockup switch
Soon to be installed: Innercooler (sittin at the shop), Big Oil, Built Tranny, Coolant Filter, HX hose, and some others. 350k miles.
Truck pics
Houston Area Powerstrokes
TimMiller is offline
Old 08-29-2006, 09:28 PM   #7 (permalink)
My Photos: (5)
got ahold of him ehh?
1999.5 cc dually
69 mustang, 472", c/4
9 sec alky injected bracket bomber....
529" in the works as we speak
Richter69 is offline
Old 08-29-2006, 11:34 PM   #8 (permalink)
Yeah he would send an email back but i wouldnt get it for some reason so i had time to call him today and ordered one.
BTW i really like how the tranny shifts now when it shifts at 2-2.5K its a nice positive shift. Cant wait for the chip though!
03 F250 SC LB 4x4
In SO-CAL?
Old 08-29-2006, 11:43 PM   #9 (permalink)
i am trying to post a link to mine but webshots site was upgraded and its not working for me right now.
edit ok here is where my switch is located picture
RYAN
GAUGES, INTAKE, EXHUAST, SBC CLUTCH, CHIP, BDP INJECTORS, BILSTEINS, BUSHINGS...AND A WHOLE LOT MORE..
pics
B99 BIO DIESEL SUPPORTING AMERICAS FARMERS.
US NAVY
looking for an ext cab 4x4 short bed DURAMAX!!! keeping the obs of course.
1997PSD4ME is offline
Old 08-30-2006, 12:29 AM   #10 (permalink)
ThreeStarJR's Avatar
Joey, Yes that would be a bad thing about splicing the wires, definite no-no....It can be done without out touching the wires, did mine a couple of years ago....here is a switch pic...
Jim
529/1220
10 17 08
BDP "DOMINATOR 66,"
BDP/Casserly's stage 3 HI-BIRDS
BDP Fuel system
Hypermax rods
Caltracs
96 F-350 CC, XLT, drw, 2wd,...
TRUCK PICS AND ALBUMS
#3
ThreeStarJR is offline
Old 08-30-2006, 11:55 AM   #11 (permalink)
Mine just hangs from the turn signal switch. my instrument panel trim is cracked. seems to work fine there.
Dan
1995 F-250 powerstroke. extended cab. Dana 60 front axle. 33x12.5" tires. 6 position chip. autometer ultra light gauges - pyrometer, boost, trans temp. 3 inch DP and 4 inch exhaust, 280,000 miles. goose neck hitch.
Im currently in college at Pennsylvania College of Technology majoring in Diesel Technology. WORKIN ON THE BIG TRUCKS!!
http://community.webshots.com/user/tweak124
tweak124 is offline
Old 08-30-2006, 07:20 PM   #12 (permalink)
I'm running the 4 position chip I got from Dale, and was wondering if any of you guys have had problems with switching positions while running. Mine seems to stumble on swithes and sometimes completely dies.
96 F250 4X2 CrewCab PSD 4" Fabtech, Authentic Tymar Intake, Dales 4 postiion chip, 3-4" DP, Side exit open exhaust. http://community.webshots.com/user/pjabdel
SOLD--99 F250 4X4 CrewCab PSD 6" Full Traction Suspension, Banks Power Pack, Pyro, ISSPRO TTM, Boost gauge, Rancho 9000s, Custom rear bumper w/ lights,Warn 15,000-that's right 15,000, BFG MT/KO's 37 X 12.5R17's, full custom dash panel
PowerFiend is offline
Old 08-31-2006, 11:02 AM   #13 (permalink)
Dieselfever78's Avatar
Send a message via AIM to Dieselfever78
Mounted mine Here
-Michael
Michael Paul
1995 F250: Regular cab, 7.3L PSD, 5-Speed, 4x4, 4.10 LSD, gauges, 2L chip, injectors, turbo, 4" downpipe - 6" tip, clutch, fuel system, Medium oil, Headstuds, Valvesprings, Cab lights, Dana 60 - New Look Soon!
1995 F250: Regular cab, 7.3L PSD, 5-speed, 4x2, 3.55 open, Intake, Downpipe, 4" exhaust, clutch, 2L chip, short throw shifter - To do list!
My Webshots
Dieselfever78 is offline
Old 08-31-2006, 11:58 AM   #14 (permalink)
i put mine in the dummy panal beside the WAIT TO START light.
1996 psd reg cab f-350 xlt 4X4 automatic, w/4:10LS, downpipe, 3" exahust, never even saw the cat, dieselsite.com 6pos. chip with high idle, home made tymar air filter system, gauge pod with autometer ultra lite gauges (trans,pyro,boost), shimmed fpr, tru-cool 4590 tranny cooler
Pictures http://photos.thedieselstop.com/show...0&thumb=1=link
"If guns kill people I can blame misspelled words on my pencil."
"If your up to you'r eyes in sh*t than you had better keep you'r mouth shut"
ben_fluke96 is offline
Old 08-31-2006, 01:33 PM   #15 (permalink)
i didnt like the fact that ppl could just peek in and see that i have flip chip so i mounted mine under the dash. it is very accessible but keeps it out of sight. looks totally stock. however i also used the empty space next to my WTS and 4x4 indicator lights for my OBA psi gauge and switch
-cutts-
My Picasa Web Album
96 F350 PSD 4x4 CC/LB 5spd XLT Ranch Hands F/R, 6637 mod, 4.5" straight pipe, tymar 3-4" DP, Dominator 66 turbo, Banks IC system, DIY Stage-I's, TW 4-pos chip, 37" SuperSwampers, autometer gauges,RAM laptop mount w/AI OBD diagnostics, fold down g/n hitch, OBA system with York and dual trumpet air horns, bronco 33gal fuel tank
72 bronco 302/435/twinsticked D20/D60/10.25 welded F/R, hydro assist, 39.5" stretched WB to 105", 1410 yokes/shafts, Staz custom double beadlocks, CroMo shafts front shafts with 35 spline outers and sexy lady drive slugs, GLO diamond tread diff covers, custom cage, mesh floor, custom diamond aluminum dash overlay, wristed radius arm, homemade shackle ladder bar
Fishmanndotcom is offline
