Old 07-10-2006, 04:47 PM   #1 (permalink)
Pop goes the head gasket!!!!!!!!!
That's right.It has happened again,but this time I think the rest of the engine is alright.I have already installed the new gasket and torqued it the way it should be.The way I did it this time is 65 ftlbs.in sequence;80 ftlbs. in sequence and then 105 in line sequence.The last being starting at the bottom front bolt going in a straight line back.There is 4 lines.I didn't do last part when I rebuilt the engine.I just did them all in sequence to 95 ftlbs (international spec)and 105 ftlbs being Hanes.I do have ARP studs with stock head gaskets and haven't been over 35 psi of boost.I have though for the last month been running the same chip that was in it when it through a rod.Could this be the culprate????????????When it let go I was not racing it just taking off from a stop light.
Clifford A.Thomas III
Dyno'd 343 hp and 685 ft.lbs. torque #2 tow setting
http://community.webshots.com/user/cliff1972
1996 F250 4x4 Reg Cab,(3rd)rebuilt engine 9/2007.DYI Stage II 170cc,stock turbo,3" dp,ARP mains,open air filter,DP Tuner F5,4 1/2" s.s. exhaust w/ Borala muffler,Joe servo IDM mod,HX MOD,stock E4OD w/ up graded valve body,TCI convertor,4.10 posi,315/75R16 BFG MT's
Waiting to install:stock 6.0 intercooler and DIY hybrid kit
Wanting to buy:head studs, Comp 910,FASS 150/180 and Modded H2E
1964 Impala 468BBC 6.98 at 98 mph in the 1/8th
1969 Nova 408BBC 6.96 at 96mph in the 1/8th
cliff-1972 is offline
Old 07-10-2006, 04:49 PM   #2 (permalink)
Re: Pop goes the head gasket!!!!!!!!!
What chip?
99.5 F-350 C/C Dually, Stealth HPOP, Full Force Diesel stroked A code injectors, Holset turbo, AEM intake.
Vengeance is offline
Old 07-10-2006, 05:00 PM   #3 (permalink)
Banned
105???? I torqued mine to 135 (beans h-11 studs). I have 3k miles on mine already with many trips to 40++ psi and no pop for me. Could also be the difference in tuning though. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
lukecline is offline
Old 07-10-2006, 05:12 PM   #4 (permalink)
GSXRTURBOQUAD's Avatar
Uh oh. I got stock head bolts running 39lbs. [img]/ubbthreads/images/graemlins/phoney.gif[/img] [img]/ubbthreads/images/graemlins/vomit.gif[/img]
95 F350 Crewcab4X4: TE Twin Turbo(BB fed by a Turbonetics TN76 from BWD), DDP BD Injectors, DIIC with custom stainless 3" piping, <span style="color: red">Terminator HPOS</span>, DI headstuds, BTS tranny, TruCool 40GVW cooler, <span style="color: blue">DP LIVE TUNED F5 with Extreme ICP!</span> , Custom fuel system, MagHytec diff cover.
01 F350 Regcab4X4: soon to be sold.
97 F350 Regcab4X4: Project(everything to make power).
02 Excursion4X4Limited: Wifes ride(stock)
<span style="color: red"> www.TerminatorEngineering.com, Proud Sponsor of the Diesel Stop.</span>
<span style="color: blue">Terminator High Pressure Oil Systems</span>
http://community.webshots.com/user/gsxrturboquad
SDRCM #7
GSXRTURBOQUAD is offline
Old 07-10-2006, 05:55 PM   #5 (permalink)
DaveBey's Avatar
My Photos: (212)
Send a message via AIM to DaveBey Send a message via Yahoo to DaveBey
Cylinder Head Retaining Bolts Torque Sequence
105 ft-lb is the specification for the factory retaining bolts; maybe the ARPs require more?
Cheers from Tulsa, OK! [img]/ubbthreads/images/graemlins/smile.gif[/img]
Dave
1996 F-350 XLT CC SRW 4x4 with plenty o' Redneck Bling: APCM●BTS-E4OD●4L10●MADDOG injectors●Hypermax H2E, intercooler, & exhaust●TYMAR intake & HPX●TSM disc brakes●Hydro-Boost●International water pump●215 amp generator●CCV re-route●285/75R16 Wild Country XTX tires●Centramatics●Denon DCR-830RD & DCH-520 203,000 happy miles
DZLJIM 3:16
~~NTxPSA - Hold my beer and watch this.~~
DaveBey is offline
Old 07-10-2006, 06:58 PM   #6 (permalink)
I dont know why ARP has thier tqu so low on the 7.3. I do 130lbs on H-11 studs with moly grease and do not have hg problems. I had one customer that rebuilt his motor and with Stage II's blew a hg and with a stock turbo on a OBS truck, something that would not happen with stock bolts but did happen with ARP studs.
I would say they need atleast 115-120ft lbs to hold effectivly even with thier magic grease.
Ryan Bean
beans diesel performance
<font color="red">bdp</font> Custom Injectors
<font color="red">bdp</font> Custom Fuel systems
<font color="red">bdp</font> Custom Turbo systems
Stealth Dual HPOP Systems
Get Destroked W/Destroke Cummins Conversion Kits
Whatever else you may need to go fast or tow with your truck. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
95 5SPD F350 4X4 4:11LS For Sale
New Truck- 02 F350 Dually 4x CC 6spd- 05 CR Cummins Built For Pullin And Raisin Hell
BIGBEAN is offline
Old 07-10-2006, 08:10 PM   #7 (permalink)
From my experience studs should clamp more evenly than bolts.Well the engine is buttoned up on the side that blew,so it will be staying at 105 ftlbs (10ftlbs more than before)But I am going to retorque the other side.Now if someone can prove to me why 115-130 ftlbs is better,I would think 105ftlbs is good enough [img]/ubbthreads/images/graemlins/shrug.gif[/img],then I might redo to that?
Old 07-10-2006, 08:13 PM   #8 (permalink)
What chip? It was a DPS tune spec done by a friend of the site
Old 07-10-2006, 08:17 PM   #9 (permalink)
You talking about a program that Ken did?
Old 07-10-2006, 08:23 PM   #10 (permalink)
Ken,didn't do the program itself,but sent the info to someone who could.The program seemed better than the extreme one I had from Bill,it didn't smoke as much,but maybe the timing was to high???
Old 07-10-2006, 08:39 PM   #11 (permalink)
That all depends on who did it.
Old 07-10-2006, 09:01 PM   #12 (permalink)
Any vendor who associates with Ken is not "a friend of the site" [img]/ubbthreads/images/graemlins/vomit.gif[/img]
Proud Recipient Of The \\\ 01 F-350 CC/LB 4x4 BTS Auto XLT Toreador Red W/Gray Lower Accent
10" Lift 38 PJs, EDGE Trac Bar Relocate, ORU X over, Weld Outbacks, AFE Stage 2,Hypermax 5", Hypermax Mod BJ Code Injectors, Hypermax H2E (broke, replaced with something bigger), Hypermax Rev Kit, ITP Fuel Sys, Aeromotive fuel pump, forged rods, main studs, head studs, billet intakes, WOP fire rings, BTS Trans & HPOS,
99 F-250 Reg Cab 4x4 Auto, Project truck,
97 F-350 Reg Cab 4x4
96 F-250 Reg Cab 4x4 Auto, Stock/Wrecked AVAILABLE
03 F-250 Reg Cab 4x4 Auto 6.0, Studded, EGRless, Hypermax Injectors/Firerings/5" exhaust, AFE Stage 2, Electronics vary DEAD
SDCRM #13
Agree? Disagree? Wanna Talk Trucks?
(785)243-4879
<font color="red">KANSAS members, PM me. </font>
Nick Gerard is offline
Old 07-10-2006, 09:24 PM   #13 (permalink)
SeeYa's Avatar
Nick your absolutely right. What Cliff probably is referring to are programs that Jody was asked to do for Ken a good while ago. Probably close to 1 1/2 years ago. Won't make that mistake again. [img]/ubbthreads/images/graemlins/tongue.gif[/img] Lesson Learned. [img]/ubbthreads/images/graemlins/wink.gif[/img]
Diane Tipton
828-221-0076
DP-Tuner®/Customer Service
Proud Sponsor of The Diesel Stop
www.dp-tuner.com
diane@dp-tuner.com
sales@dp-tuner.com
http://www.myspace.com/dptuner
For pricing and questions about our product please call or email us.
"Great minds discuss ideas,
average minds discuss events,
small minds discuss people.
~ Eleanor Roosevelt ~ "
SeeYa is offline
Old 07-10-2006, 09:31 PM   #14 (permalink)
SeeYa's Avatar
Cliff,
I will have Jody check that for you. He did say that he was pretty sure that it wasn't more then 15* in your programming. He will check it out when he gets home tonight.
Diane Tipton
828-221-0076
www.dp-tuner.com
diane@dp-tuner.com
sales@dp-tuner.com
SeeYa is offline
Old 07-10-2006, 10:01 PM   #15 (permalink)
I don't know but I always thought tighter was better...at least I like it that way [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img]
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
