popping under floorboard - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 01-17-2008, 04:52 PM   #1 (permalink)
I have noticed when turning right sometimes that there is a popping sound under the floorboard .I cannot find anything loose.Could it be the front sway bar?
95 f350 powerstroke crewcab 4x4. 4" exhaust 5" tip . Tony wildman chip,no cat. Tymar intake.Autometer guages,pillar mount.FPR shimmmed,160cc injectors.Superduty intercooler. 4.10 gears. Detroit Truetracs front and rear. Idm modded. Airlift 57215 airbags in rear.Sky RSK with Superlift 4 inch lift in back and V codes up front.Homemade 6 foot traction bars.TC lockup switch installed on newly rebuilt tranny (3rd time)DC1 17x 9 wheels with 37 inch extreme all terrains
oldblue31 is offline
Old 01-17-2008, 05:16 PM   #2 (permalink)
My truck is almost identical to yours and does the same but not all of the time. When I replace the shocks it seems to go away for a while.
Good Luck
Midwestman
95 350 CC SRW 4X4.456K. Amsoil everwhere w/dualbypass filter. Early Centurion model custom paint (white with grey striping) Grey shell, brushguard, Flexsteel leatherseating wood trim and overhead console. BTS hold on tight E4OD tranny. Custom chip by Cale Thompson at BTS. Hypermax DP. Tymar Open element intake. Tru-Cool 28,000 GVW trans cooler plus Super Duty trans cooler. Super Duty Intercooler with GTS pipes. CCV mod. 3 pod A pillar guages with Isspro Pyrometer,Boost and Tranny temp guages. Fumoto oil drain. John Deere coolant eye. Sylvania Ultra Silverstars. Joe Servo IDM. BABY SWAMPS. Magnaflow 4" exhaust. Tymar Coolant Filter. Sirius satellite radio. Kelderman Air Ride on the rear. Autolights clear diamond headlights. Mods as the budget will allow.I think I am almost finished.
midwestman is offline
Old 01-17-2008, 05:26 PM   #3 (permalink)
Soaggydogg's Avatar
My Photos: (11)
Feedback Score: 2 reviews
I know they are different but on my 4wd Ex it did that. I found bad ball joints and the lower shock bolts were smaller than the diameter of the lower shock hole.
'95 F250 Ported Snorkle, Foil Delete and a little more
'02 Excursion Matched Perfect and Staggered Special
Total Diesel Performance Custom Tuning
Rockin S Performance BTS dealer
good-times.webshots.com/photo/2120855500037306169oDlfMF Well did you touch it?
Soaggydogg is offline
Old 01-17-2008, 06:26 PM   #4 (permalink)
Try tightening your fender bolts by the hood hinge, That ended up being what was popping on my tuck, and mine sounded like it was coming from the floorboard.
My Trucks,
1999 Dodge 2500... 438HP, I just got a superchip...
1997 F250 ext cab 7.3, 5spd, 4x4, with some modifications (Sold)
2007 Q&S Gooseneck, 25+5 with tandem duals.
1966 Mustang coupe, (Sold)
1984 Chevy K10, Built motor, lift, all the good stuff. (Sold)
1997 F150 XLT ext cab, sb. (Sold)
http://community.webshots.com/user/pogrelis97
Myspace: http://profile.myspace.com/index.cfm...ndid=103875904
Ben97 is offline
Old 01-17-2008, 06:58 PM   #5 (permalink)
Hook'em Horns!'s Avatar
Send a message via Yahoo to Hook'em Horns! Send a message via Skype™ to Hook'em Horns!
Oh man, that would really bite! Selling/unloading your truck after being convinced it needed a completely new front end under it, instead of a few turns on a fender bolt.
2007 Chev Duramax LBZ/6-spd Allison 3500 LT3 DRW CCLB, Sulastics, Putnam XDR 15K, B&W 30K-Turnover GN, Ride-Rite Air, Roll-Top Cover
2006 Chev 6.0L/4L80e 3500WT DRW Ex-Cab 9'Flat-GN
A/T Revos
Use-ta-Haves
2005 Chev Duramax/Allison 3500LS DRW CCLB
2002 Chev Duramax/Allison 3500LS DRW CCLB
DON'T STEAL! The Government Hates Competition
Hook'em Horns! is offline
Old 01-17-2008, 08:04 PM   #6 (permalink)
orrrrr--as in mine--the rear spring bushings were gone!!!!! i replaced them with urethane ones--end of problem---the eye of the spring was banging the frame-----also--some springs had a rub pad between the leaves--they will go bad--and can make the same sounds---
94_turbo is online now
Old 01-17-2008, 08:10 PM   #7 (permalink)
I think I will try all of the above tomorrow except for selling the truck
Old 01-17-2008, 11:10 PM   #8 (permalink)
Its the rivets in the frame. There is an upgrade that you can remove them and go back with some type of bolts...
1996 f350 crew cab.
SPEED COST MONEY, HOW FAST YOU WANT TO GO?
nojeffgordon is offline
Old 01-18-2008, 09:08 AM   #9 (permalink)
Patrick Feeley's Avatar
My Photos: (19)
Here's the TSB on the Fastener Replacement: "TSB 97-03-10". Try tightening the fender bolts first! Cheers!
1997 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Mostly Stock
SOLD - 1994 F350 CC DRW 2WD, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 01-18-2008, 10:43 AM   #10 (permalink)
MarkEkberg's Avatar
My Photos: (13)
I did the fender tighten last year. All my crunches, pops, and noises are gone!!!!!
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
Old 01-22-2008, 10:35 PM   #11 (permalink)
That tsb link goes to FTE but it does not bring up the actual tsb.Anybody know where I can find it?
Old 01-22-2008, 10:48 PM   #12 (permalink)
Steve83 over on FSB has some GREAT links on his supermotors, check this out...
1983 Ford Bronco 97-03-10 Frame Noise pictures, videos, and sounds | SuperMotors.net
1983 Ford Bronco TSBs & FSAs (Recalls) pictures, videos, and sounds | SuperMotors.net
TSBs & FSAs - FSB Forums
'95 XLT-302-39.5 IROK's, D60/10.25-Detroits/4.88 ~7" lift
'95 4dr Bronco C150 351, '05 60/10.5 swap with 4wheel discs. ~5" lift on 315's
'95 4Dr Bronco C350 PSD-AFE stage 2 intake, Tymar 3-4" DP, 4" exhaust, EBPV delete, FPR shim, IDM mod, and Wildman 4pos chip.
JoeBob1901 on Supermotors for pics/info
JoeBob1901 is offline
Old 01-23-2008, 12:21 AM   #13 (permalink)
My Photos: (19)
OldBlue, were you refering to the link in my post? It goes to the link here at TDS for the full pdf version of the TSB (all 10 pages of it).
Cheers!
Old 01-23-2008, 12:48 AM   #14 (permalink)
CaptinCrash's Avatar
check your body mounts
sorry about frequent miss spellings I'm severly dylexic
A true Desert Racer For life
1997 f250 4x4 ex.cab long bed 7.3l Scalzo Racing Chase 1
Airraid stage 2intake
Real Men Use The Green Pump
CaptinCrash is offline
Old 01-23-2008, 10:30 AM   #15 (permalink)
Cheers!
YEs. For some reason it goes To Ford trucks Enthusiasts
Similar Threads
floorboard vibrations jetflyr Power Strokes 1994-1997 General 2 07-05-2007 06:05 PM
Popping noise and feel under floorboard texasquail 6.0L Power Stroke Engine and Drivetrain 3 02-08-2007 04:23 PM
Clunking under passenger floorboard az350x Power Strokes 1994-1997 General 1 01-29-2007 06:18 PM
Bumping Noise In Floorboard ?????? knhooper 1999-2007 General Questions 24 03-01-2006 04:09 PM
A/C drips in passenger floorboard Justin C. Power Strokes 1994-1997 General 5 07-22-2005 08:11 AM
