possible to get down into the 12's or at least 13's with 4.10 gears and a 5 spd?
That is my target area but if I can't get that kind of speed, then I want to trade off on an auto. Just wondering if you guys think I can get into that range.
96 F250 PSD ext cab SB, 5 spd 3'' DP with straight piped exhaust, tymar intake. 135k mi.
Re: possible to get down into the 12's or at least 13's with 4.10 gears and a 5 spd?
I hope you can shift very fast LOL i think you would need a built auto and alot of fuel and maybe some nos
94.5 F-250 5sp 3.55 3inch down pipe pyro boost gauges 285\85 bfg mud luk smfw cluth pedal mod Edge Evo Fuel pressure BB 3 body lift Bronco tank K&N cone air filter Rancho shocks 180ccDIY injecters 2 D8 batteries and 2 1750 powerinverters and much more to come
The latest video of David Lott shows what looks like a 6 speed in the other lane being shifted rather quickly.I could be wrong.(I know you said five speed)
94 F-250 4X4 SC 5 SPD,ORIGINALLY IDI,355s,CURRENTLY 97 PSD ENGINE,97 F-350 SPRINGS,AXLES 410s,ALL OF THE BELOW.COPYCAT TYMAR,3"DOWNPIPE,STRAIGHTPIPED,RDS STAGE II's,SOUTH BEND CON OFE,GUTTED EBV,GUAGES,6.0 INTERCOOLER PICSGUAGEPOD
ok, I'm just looking to get that kind of acceleration I'm sure being in the 14's or 15s would throw me in my seat, I never had that kind of power yet though
I dont know why you couldnt. Getting a short throw shifter would be the first thing. People have been shifting manual tranys faster than automatics can shift for years on the strip. If you really wanted to get serius you can get a 5 speed built to shift quickly, it just takes some tricks that work with all manual transmissions because they are all basicly the same.
Just wondering what your et is now if you have one.
Nick
01' Powerstroke Excursion, 4x4, DR 9" lift, 39.5 x 13.50" IROK radials on 16x10 Eagle Alloys, Autometer ProComp Guages mounted on dash pyro, boost, tranny, CB radio custom install in dash were cubby hole under 4x4 select switch used to be, DP Tuner chip 60, 80, 120, and High Idle(1200 RPM), DIY gears and lockers, Lockright up front, Detroit locker in the rear, 4.30 gears, Dynatrac front hubs (REAL HUBS), BTS Tranny, 4"dp to 5" exhaust dumps infront of rear pass. tire NO MUFFLER, Tymar intake,WW, AIH Delete
Not impossible but totally impractical. You would have to spend way more $$$$$ on the engine to make way more power to get there compaired to a less powerfull motor with a auto. My stock 95 injectored truck was 2seconds quicker to 60mph than my brother in laws 00 SD...really pised him off [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
I've already got my flame suit on but don't see any use
for a manual transmission other than preference. All
transmissions break and clutches go. The auto is much
more flexible for me and isn't operator sensitive. It
allows me much more choice in getting fishing partners! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
1997 F250 HD PSD 4x4 OR Auto 3.55LS CC SRW SWB 265x75x16 Michelin LTX DP 211K mi.; Ford AIC; Fuel milege; 20.3 mpg @ 70 mph. 12.5 mpg pulling my boat,12.5K, along two lane rural roads. A number of mods ordered from DaleI. Nice round replacement DP. FS2500 by-pass oil filter installed. Fumoto drain valve. Tymar Intake installed! HX mod from Tymar installed. TFI fillneck kits installed. Auto-Rx cleaner in engine & transmission done. Switched from Rotella dino to Rotella synthetic. Amsoil 5W-30 Series 3000 installed!
FS-2500 Bypass filter installed.
Velvet rides installed. Joe Servo IDM mod installed. Rear air lift springs.
Well there is a big difference between drag racing and seat of the pants feel. There is also a big difference in your wallet. My buddy got his 6 speed dodge down into the high 14's, but it was at the cost of his transmission, his truck burned 514/1500 on the dyno that same day. Two other guys lost their autos that weekend, too much boost at launch welded internals. Point? Nothing really, just made me not want to race my daily driver, and had to tow two rings home that weekend. Anyways...
Start with an intake, you already have the DP, get a 4" exhaust, upgrade to a smfw and at least a LUK clutch but a South Bend would be better. A really good chip and edge ez will help a lot, make sure and get some guages. That will be a good start, plus improve your fuel milage, and your seat of the pants feel will be a big difference. My biggest improvement so far was my injectors and HPOP, next will be a turbo, then a chip... I won't be running a cac, I'm rebelious.
You will also want to control wheel hop, two ways to do that are ladder/traction bars or remove your blocks and replace with taller springs. Or go with an all out 4 link... but you may not want to go that far. One way to off set the 4:10 gears is taller tires, I don't know what size would equal 3:73's though, downside you will lose some bottom end, but gain on the top end.
97' F250 CC 4x4 SB PSD 5spd 188,000 4:10's LT265/75R16 Cooper Discoverer ATR's Tymar Intake, HPX, 3X4 DP, 4" Street Exhaust
Custom Injectors
17deg HPOP
SD HT Starter
Shimmed FPR
Uniden Pro520XL
MaxRad Antenna
1000cca Everstarts
AIC
Autometer Gauges
Disconnected EBPV
ES bushings
Warn Premium Hubs
Rhino Liner
Custom goose neck
Chrome bed rails & body skirts
Custom wife dents
Stickers that make it faster (no really)
There is an organization of stick shift drag racers, do a google search. A guy comes out to Milan dragway on our club nights with a 65 mustang coupe, stroked Windsor, and a Liberty 5 speed manual ($$$)
He uses a cintered iron clutch disc.
Launching with this set up is not a problem, the car launches like non I've ever seen, harder than a car with an automatic and a trans brake. The car LEAPS off the line and carries the front wheels no less than 2 FEET off the ground until he pulls second gear at about 40 feet, then the front end stays on the ground for the rest of the run, he uses all 5 gears in the 1320 and routinely blasts of 9 second passes.
This is a totally unrelated powertrain and vehicle, but, the point is, it can be done, all the fast cars in the good old days were stick shifts, cause autos couldn't handle the power.
At this point, you really have to ask yourself what you want to do with your truck. Trucks were never indended to be race cars!
Belleville, MI (Detroit / Ann Arbor)
'97 F250 4x4 7.3PSD ZF5spd 4L10
PA2818 diy intake, wicked wheel diy turbo rebuild, .84 turbo housing, no muffler, I LOVE MY BEANS TS'ers! ;-), new pedal box bushings, Fleetgaurd coolant filter, Seat Mod, electric fan, Eagle 16x8 w/265 75 Firestone Steeltex AT, cooling pkg front bumper
'69 Mustang 428CJ(ongoing project)
'99 escort zx2 commuter
'86 Supra classic ski boat 351W PCM power
'54 Belair sedan, all original
That right there says a whole lot. I think it comes to a point where you need to end up buying a second rig. Then decide what you plan to do with the truck. My buddy wasted his 6 speed drag racing but his truck is really set up better for pulling. My other friend who helped him change the tranny out said enough is enough and bought a second truck just for racing.
Custom Injectors
17deg HPOP
SD HT Starter
Shimmed FPR
Uniden Pro520XL
MaxRad Antenna
1000cca Everstarts
AIC
Autometer Gauges
Disconnected EBPV
ES bushings
Warn Premium Hubs
Rhino Liner
Custom goose neck
Custom wife dents
It's not so much the launch of the auto but that you can't sit at the line and build boost so you can't get off the line that fast because your turbo has to spool up before you can get going. Then trying to shift a ZF5 fast is a whole nother story. It's not like you are shifting a Mustang or Viper or some other sports car with a tranny that you can shift quickly easily. You will need to have a LOT more power to get a 5 speed down the track that fast than you will with an auto.
"My buddy got his 6 speed dodge down into the high 14's, but it was at the cost of his transmission, his truck burned 514/1500 on the dyno that same day."
Those TQ numbers sound WAY off for the hp number. Where did he dyno that at? Did they have a tach hooked up? If not then the TQ reading isn't right.
