04-13-2005, 07:46 PM
#1 (permalink )
Post deleted by JLester
04-13-2005, 07:49 PM
#2 (permalink )
Re: will this HPOP fit?
yep it will fit
Travis
SWAMP'S Extreme Powerstroke Performance
2L Motorsports
Charter Member of
www.FOKISD.ORG
99 F350 ext dually 2crueL (moded somewhat)
86 F250 4x4 - C6 3.55Ls[b]
The Mule 1995 F350 CC - 4x4
95 E350 PSD 190k miles
97 F250 ext lb 160k 4x4
97 FSuperduty Plumbers Truck
93 Ranger (soon to have twinned 4bt)
My Webshots
04-13-2005, 07:50 PM
#3 (permalink )
04-13-2005, 08:10 PM
#4 (permalink )
hard to say, a SD pump does see an increase in volume, However the most desirable pump is distinguised by a hump in the rear cover. That is the only distiguising charteristic that i can tell. Nobody i know of has been able to find a coorelation between that specific pump and a part #
Travis
2L Motorsports
Charter Member of
www.FOKISD.ORG
My Webshots
04-13-2005, 08:22 PM
#5 (permalink )
04-13-2005, 08:31 PM
#6 (permalink )
you need a pic to see the end of the pump the end closest the gear in that pic.
Travis
2L Motorsports
Charter Member of
www.FOKISD.ORG
My Webshots
04-13-2005, 10:06 PM
#7 (permalink )
Banned
As of now, I have an unhumped hpop and bdp stage 2's and I cant get a cel. My hpo in extreme doesnt drop any lower than 2500 at wot.
Luke
04-13-2005, 10:34 PM
#8 (permalink )
04-14-2005, 08:11 AM
#9 (permalink )
you'll need to do an accumulator with a sd pump and 95 frt cover to avoid the drain back issue.
1999.5 cc dually
69 mustang, 472", c/4
9 sec alky injected bracket bomber....
529" in the works as we speak
04-14-2005, 08:21 AM
#10 (permalink )
04-14-2005, 10:52 PM
#11 (permalink )
You may want to PM Nit for that!
Cheers!
1994 F350 CC DRW 2WD PSD (ALF4), ZF 5 Speed, 4.10 LS, SBC Con-O SMFW/Clutch,
Baldwin Filter ,
Tymar HPX Hose , DPPI DP, Bilsteins,
$12 AIC ,
Coolant Filter , Stancor GPR,
Explorer Overhead Console ,
A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro (pre-turbo) ,
Relocated Block Heater Plug ,
Modified Pedestal , Gutted EBPV.
04-14-2005, 11:33 PM
#12 (permalink )
04-15-2005, 12:00 AM
#13 (permalink )
Yeah, in that case you won't need the accumulator. As long as the engine has a 97 front cover.
Travis
1997 F-250 HD 4x4/OR SC LB XLT PSD E4OD 3.55LS, TDE1, Baby Swamps (150/146/A), BTS Trans, BTS programming, Front and Rear Replacements, Gooseneck, Autometer Pyro, Trans Temp and Boost in Rockin' S Pod, Cab/Clearance Lights installed, Tymar style intake, 6.0 Intercooler, Tru-Cool Max tranny cooler, Warn Premium Hubs, Shimmed FPR, Gutted EBPV, Super Duty 3" DP, 4" Exhaust, 175,000 mi., 7400 lbs., 310 HP 559 TQ
Truck & Other Pics -
More Truck & Other Pics
1968 IH Travelall 4x4
Work truck - 2008 F-350 6.4 PSD XL Crew Cab, Long Bed, Single Wheel, Torqueshift, 3.73LS, 4x4
04-15-2005, 12:24 AM
#14 (permalink )
04-15-2005, 12:39 AM
#15 (permalink )
Only the '94 - '95' engines need the accumulator, so your '97 will be just fine as is!
My '95 works just fine WITH the accumulator...so there is a happy ending to all years! [img]/ubbthreads/images/graemlins/smile.gif[/img]
Dale
Linear Mode
» Site Navigation
» Other Sites
» Network Links
