Old 04-23-2005, 08:28 PM   #1 (permalink)
Posts: n/a
Post deleted by JLester
Old 04-23-2005, 08:47 PM   #2 (permalink)
ThreeStarJR's Avatar
Hey Rich....
gotta shop vac that you don't mind getting a little oil in the hose? Put the smallest attachment you got to go with it, the crevise one is the best, get the 3/16th clear tubing and electrical tape the tube into the end. ( looks silly as all hell but it works)! make sure you remove all the filters, etc. from the vac. don't run it too long each time you use it, kinda heats up the vac motor.....wonder why? [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
Jim
529/1220 10 17 08
BDP "DOMINATOR 66,"
BDP/Casserly's stage 3 HI-BIRDS
BDP Fuel system
Hypermax rods
Wildman Tunes
Caltracs
96 F-350 CC, XLT, drw, 2wd,...
TRUCK PICS AND ALBUMS
play it loud!
#3
ThreeStarJR is offline
Old 04-23-2005, 08:59 PM   #3 (permalink)
BlueMule's Avatar
My Photos: (12)
Re: injector install question.
When I did mine I used a shop vac and a 1/2 gallon gatorade bottle and 2 foot section of 1/4" clear vinyl hose.Punch a small hole near the top of the bottle and insert and attach the hose (I used silicone)
Stick the vacumn nozzle in the mouth of the bottle. Now your shop vac has a catch can that keeps all the oil out of the main vacumn chamber [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
BlueMule is offline
Old 04-23-2005, 09:34 PM   #4 (permalink)
I found a syringe for injecting turkeys at Target. I cut the end square and then attached a short hose. Its a trick to get the hose through the hole in the injector cup but it works.
96 F-350 4x4 CC LB, International block and heads from Mcandless IH in Denver, <span style="color: red">Baby Swamps </span>, Luk Cerametallic Clutch, 5" straight exhaust,5 speed ZF, 4.10's, Evolution programmer, Banks brake, non-EBPV IH turbopedestal, AFE Magnum force, CA reg. kit, 12,000 lb. Milemarker on reciever mount, 215amp ambulance alt., 33" muds on factory aluminum, Class 5 bumper hitch, hidden gooseneck, pillar gauges, fosgate amp, 12" sub.
Colorado National Gaurd.
"Firearms stand next in importance to the constitution itself. They are the American people's liberty, teeth and keystone under independece. When Firearms go, all go's. We need them every hour!"
President GEORGE WASHINGTON
bigbore is offline
Old 04-23-2005, 10:29 PM   #5 (permalink)
Rtxcoon's Avatar
another option, and what I used....
boat places sell what they call a "topsider"....basically a vacuum
pump/tank...its hand pumped and can pull the oil out of the cylinders
I use it too change the oil in my boat, and came in really handy for the injector swap [img]/ubbthreads/images/graemlins/smile.gif[/img]
before I even pulled the injectors...I undid the oil rail plugs and sucked that clean before removing the rearmost injector...
worked for me [img]/ubbthreads/images/graemlins/smile.gif[/img]
1997 F350 CC 4x4 Auto
a little over 400 at the rear wheels
thanks to Wildman, Bean, Cass, Luke and Visa
www.northtexaspowerstrokes.com
Truck Pictures
Truck Movies
Rtxcoon is offline
Old 04-23-2005, 10:35 PM   #6 (permalink)
I wouldnt crank the engine with the key, as you will be pumping fuel and oil back intp the head rails. [img]/ubbthreads/images/graemlins/smirk.gif[/img] You can roll up a GOOD paper towel like a cigar and place it into the hole and turn the engine over by hand, atleast thats what I did [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Justin
00 F550 PSD Work truck......
99 F250 PSD Toy.............
06 2500 Cummins4x4........
00 F250 PSD NEW Toy......
Powered BY:
Diesel Innovations
BeansDieselPerformance
Tuned by: Tony Wildman
Truck PICS
Engine Complete
Block w/8 sleeves
Crower Rods--Terminator HPOP--DI Intercooler DieselInnovations
BD Injectors Diesel Innovations
Beans Large Frame Turbo/Kit
Head/Main studs
DI Fuel System
catdiesel0631 is offline
Old 04-23-2005, 10:50 PM   #7 (permalink)
Sounds funny but I taped a McDonalds straw to the end of a shop vac hose. It was long enough to reach all the piston tops and clean them off good. When I had injectors in, I was able to leave the vc's off and turn the engine over without any spray coming out of gp holes. Mind you, I drained the oil and fuel rails first [img]/ubbthreads/images/graemlins/wink.gif[/img]. Not sure if this is what you want but it sure worked for me.
Steve
2005 Dodge Ram 2500 SLT 4x4 CTD Manual
5" stacks, Modified air intake
dirtmover is offline
Old 04-23-2005, 10:53 PM   #8 (permalink)
Posts: n/a
Old 04-23-2005, 11:03 PM   #9 (permalink)
sea97stroker's Avatar
I used one of those hand pumped vacume thingys, i used a piece of medical oxygen hose and stuffed about 2 ft of mechanics wire up the hose so it would hold whatever shape you put it , it made it a snap to get it in the cyl and the wire is longe enough that even if it came out of the tube you can get a hold of it.
Steve
1997 F350 CC 5 Speed 4x4 , BDP Stage 2's, Wildman Chip, Isspro Gauges, 5 inch stacks, SD Turbo Setup,Banks Intercooler,Tymar Intake, SD Leather Seats. Dyno 427hp/813tq
www.BeansDieselPerformance.com
sea97stroker is offline
Old 04-23-2005, 11:28 PM   #10 (permalink)
i just put my injectors back in, pulled the idm fuse, pull them glow plugs lay a towel over the holes and letter rip. this will prime your oil and fuel system back up and blow all the crap out of the cylinders all in one step. i cranked it about 10 times over about an hour bout 5 seconds a time. seemed like after the 3-4th time there wasnt any thing else coming out.
97 F250HD 4X4 210K MI
4 LINKED FRONT AND REAR ON AIR
00 F350 4X4 CC
RIP CHRIS. 03/09/05
http://community.webshots.com/user/barebackjake
barebackjake is offline
Old 04-23-2005, 11:32 PM   #11 (permalink)
I couldn't find a 100cc syringe, but I just went down to the vet clinic and picked up a 60cc. Works really well for the cylinders. I think I only had to empty it once and refill it a little on the same cylinder. Just a thought if you have any clinics in your area.
1996 F250 4x4 5sp shortbox, ats intercooler, DIY Tymar, 3" dp, Dual 5" stacks, South Bend Con-O clutch and SMFW. BDP Stage 1's up and running!!! my truck
TS 6 pos. chip-High idle, Economy, Tow, Jody Tipton Hot (75 hp), Diesel Power Extreme, and TWildman's "Move it or lose it" Extreme
"A man can always stand a little bit more horsepower" - Chris Ledoux
Strokerin is offline
Old 04-23-2005, 11:41 PM   #12 (permalink)
I used an air power AC vacuum venture deal. Worked good. If you try the turn over with the starter with GP's out plan on spraying your hood liner and the wall next to the truck, well anything with in 20 feet!
Did you drain the rails before you pulled injectors?
Rick H...
Omaha Metro Powerstroke Diesel Club
Pres Omaha Metro PSD Club
Biodiesel Calculator
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp
[color:"RED"] RDRCM#20 [/color]
RickHredf250 is offline
Old 04-24-2005, 12:32 AM   #13 (permalink)
Posts: n/a
Old 04-24-2005, 04:08 AM   #14 (permalink)
Is there some kind of law against working on a vehicle in your parents driveway? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
If you have a vetrinarians clinic close by you should be able to get a 60cc or 100cc syringe from them. If not, do the shop vac trick....
95_stroker is offline
Old 04-24-2005, 04:37 AM   #15 (permalink)
Banned
Go to your local motorcycle shop. Tell them you want fork oil level setting tool. It is like a big syringe with a small hose attached to it with a small metal pipe on the end. It works perfect for getting down in the small hole and actually getting the tip of it right where you want it unlike trying to stick a limp hose in there and it going where it wants to. I use this attached to a power brake bleeder to such the fuel/oil out. If you drain the rails first it goes a lot quicker and easier though. You can bump it over if you have the injectors back in it but if you don't have injectors in the heads when you crank it it will pump more fuel/oil into the rails and into the cylenders. If you use the remove the glow plugs and turn it over method I'd recomend sticking the valve covers back on it and holding them down with like 2 bolts to hold them there. A towl will go flying if you crank it and the oil comes shotting out. It really does make a huge mess. The problem with blowing it out the glow plug holes is you get fuel in the oil so if you do that make sure you change the oil at the same time you do injectors. Also DO NOT HIT THE INJECTORS WITH A HAMMER!!! There is a special installtion tool for instlling them. Dammage can happen to the solenoids if you tap them in with a hammer. If you can't get them to go in and you don't want to spend the money on the proper tools to do the job then push on the retaining collar that the bolts go through to get the injectors to seat. Just don't smack the solenoids.
gtspowerstroke is offline
