[img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img], that sums it up!!!!
Thats it Rich, never give up! [img]/ubbthreads/images/graemlins/wink.gif[/img]
Is this the dually your working on?
If NOT, I would guess with stock fuel system low 15's.
Put some juice in the fuel, something to raise the C tane.
If you got a single peel, your going to have to do 4x4 launchs.
And do not even trie to get your tire(s) hot in the water in the burn out area. Might consider dropping tire pressure down. I think I had mine down to 40 or 45 when at the track. Normally I run them about 60 unless loaded down then 80.
And yes you will have smoke, I do not thing tons of it aftering watching lukecline with his stage 2's. He was able to almost clear it all up. Which is good that means your using what your putting in the cyl.
On changing the HPOP, I think if it was me, I would do it all at the same time. That way only gotta drag the tools out once.
That is if it aint raining or snowing or some other wierd weather where you live! [img]/ubbthreads/images/graemlins/phoney.gif[/img]
And luck ain't got nothing to do with it! When you get em in and look back all the thorns in your side will be forgotten! [img]/ubbthreads/images/graemlins/cool.gif[/img]
Rick H...
__________________ Omaha Metro Powerstroke Diesel Club
Pres Omaha Metro PSD Club Biodiesel Calculator
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp [color:"RED"] RDRCM#20 [/color]
Do the hpop now so that when you go to start you dont have to second guess weather somethin is wrong with it, do one mod at a time so if there is a problem you know where it is.
<font color="red">bdp</font> Custom Injectors
<font color="red">bdp</font> Custom Fuel systems
<font color="red">bdp</font> Custom Turbo systems Stealth Dual HPOP Systems Get Destroked W/Destroke Cummins Conversion Kits
Whatever else you may need to go fast or tow with your truck. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
95 5SPD F350 4X4 4:11LS For Sale
New Truck- 02 F350 Dually 4x CC 6spd- 05 CR Cummins Built For Pullin And Raisin Hell
Rich,
I'll be praying for you brother. We probably wont hear from you since you'll be playing with your new toy!! [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img] Al
'95 F350 Red cc,zf5,157k miles,3"dp with 4" exhaust,Di Pricol egt and boost gauges,DP-Tuner F5,295/75/R16 BFG AT, SD IC, 1.0 A/R,IC pipe kit, and Stage 1's from GTS, South Bend smfw with the con O from BDP.
Shoot I done 15.2 at a mile above sea level with the sissy injectors. [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
2006 F250 CrewCab Lariat FX4 6.OH AFE, MBRP SS Cool Duals, Elite SCT, 4 Up the pillar, Bed Rug and Retrax Lockable cover.
1997 F350 CrewCab XLT 4x4. ?hp/?lb-ft Intercooled, BTS Trans, BTS Dual HPOP, Big Full Force Diesel Jectors, Big Turbo, Ford AIC, Rockin S Custom 5 inch Exhaust w/AeroTurbine Muffler, AFE Stage II Intake, Total Diesel Performance 4 Positon Chip, White Face Gauges,
1979 F250 SC Lariat 4X4 5.9 CTD, BTS E40D, Dana 60/Sterling 10.25, SD HydroBoost brakes, 440HP 992lb-ft, Intercooled, BFG All Terrains on Eagle Alloy 102s. Custom Rockin S Dual stack Exhaust system. DDP Stage IV injectors, HTB2 Turbo, Snow Water/Meth injection My Webshots page
i hope you would do better than 15's cause i was running 15.5 with stock injectors, stock turbo, 100 hp chip, and pane. thats it. looks like we won't know until you head to the track though.
good luck
New truck 1984 f-250 xlt ext cab. in progress
Newer truck 95 ctd
*SOLD*1997 f-250 auto, 4x4, 132,000,crewcab,remote start,relocated batteries, beans custom stage II's, beans custom 6 pos. chip, beans headstuds, 2002 intake plentums, 2002 HPOP, custom cold air intake, dual 6-in stacks, 4-in lift, 35-in MTR's, auto meter phantom gauges, (3rd) monsterbox tranny, billet input shaft, triple disk TQ, 4:10 Limited slip, snow performance water/meth injection. block painted sonic blue pearl
HP= 388 TQ= 732 w/o water/meth
1/4 mile= 14.4 @ 96mph with dp tuner 6 position chip PICS
What are you calling sissy injectors?
[img]/ubbthreads/images/graemlins/blush.gif[/img]
Tom
With the CTD or the PSD?
Rick H...
HIS
HERS
Rick that was with the PSD and the 175 injectors. I have not ran the CTD because I am waiting on my BTS to be built before I try to drag race it. Im a thinkin its gonna do alot better then any 15s [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Sorry Tom [img]/ubbthreads/images/graemlins/grin.gif[/img]
