Is it possible to lose power when you have an intercooler installed.I installed a 6.0 cooler a few weeks ago and just recently to my chip out to have some work done,and I could not beleive the lack of power on the bottom end.I swear I could get beat by an Ford escort.I popped the hood and checked for cracked or broken hoses and such and there was none.I have about 15 pounds of boost without the chip so I guess all is normal.Just didnt think it would rob that much on the lower end. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
I am expecting to have MORE turbo lag when I add my intercooler. might even lose a few pounds of boost. thats what I've heard about the instal. of an IC
<span style="color: #000099"> 96 F-250 CREWCAB POWERSTROKE... Stage 1 injectors... 6 position Tony Wildman chip: stock, economy, daily, tow, hot tow, & Luke Cline Extreme... Superduty IDM mod... Tymar intake... Tymar 3"X4" down pipe... Tymar 4" exhaust... Tymar high pressure oil crossover... 6.0 intercooler-PIPES thanks to GTS... CCV mod... V10 transmission cooler... 203* thermostat... shimmed FPR... gutted EBPV... Monster Box trans... 4.10s... Dana 60 front... LS rear w/ extra qt and a half diff cover... three gauge pod full of Autometer's... AIC... Turbo pedestal mod by Rick96F250 and a 3/8inch shorter bolt on the rear passenger side of the pedestal... Nippondenso starter... THINGS TO DO: get a big turbo, big oil, and big fuel... RSK with SD springs.</span>
of course, you have to pressurize all that more volume in teh cooler and pipes etc. , lose power no, slower spool up, hell yes.
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
I was talking to one of the vendors about what I want to do to my truck. He said he would need to reburn the chip after I got my IC. Call the company that burned your chip to see what they can change.
get some larger injectors and then call Wildman, I can get boost up in millisecs way past 1 psi per 100 rpm too, it can run 30# at just over 2000 rpm.
Your suffering turbo lag. That tiny turbo is not built for the long distance of piping and IC(about 9 ft further then stock). Air volume is your problem. That is the main reason I switched to a BB turbo. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Boost loss is expected, about 4lbs. If you have NO loss, your not cooling the air charge. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
I was at 29lbs with my stock injectors(.84 exhaust housing). Intercooled it, and dropped to 25lbs. And now, well I'm moded a little since then. [img]/ubbthreads/images/graemlins/wink.gif[/img]
__________________ 95 F350 Crewcab4X4: TE Twin Turbo(BB fed by a Turbonetics TN76 from BWD), DDP BD Injectors, DIIC with custom stainless 3" piping, <span style="color: red">Terminator HPOS</span>, DI headstuds, BTS tranny, TruCool 40GVW cooler, <span style="color: blue">DP LIVE TUNED F5 with Extreme ICP!</span> , Custom fuel system, MagHytec diff cover.
01 F350 Regcab4X4: soon to be sold.
97 F350 Regcab4X4: Project(everything to make power).
I have found that Dale (Powerstroke2000) is correct too, that the right chip will fuel quicker and make up for the lag...
My injectors aren't near as large as Nit's but lag is definitely not an issue with my current setup! [img]/ubbthreads/images/graemlins/cool.gif[/img]
Good luck to all of you doing these i/c installs now!!!
God Bless,
TC
97 F350 XLT, 4x4, Toreador Red, CC, PSD, MLE0, ZF5, 3.55 l/s, LUK clutch,Velvet Rides, ISSPRO gauges, v/cover vented to tailpipe, DPPI downpipe - modded to 4" right below firewall seam, open element intake using Duralite filter, coolant filter mounted between washer fluid bottle and jack, gutted EBPV, 99+ I/C installed using early 99 Y-pipe and custom pipes, 4-pos chip, BigBopper Seat Mod, Bilsteins, 130cc injectors, homegrown 4" exhaust, uses 36" Magnaflow muffler (Model #12773 body is a full 30" long - nice and quiet!) Custom Fuel System using Carter electric pump, Aeromotive regulator and frame-mounted filters...
2003 Tahoe MS27TT (27' Lite travel trailer), Prodigy Brake Controller.
1991 5.0 LX, runs 12.57 @ 109 mph
My Intercooler/Fuel System Install Webpage (section on CCV Mod too): http://members.localnet.com/~boys3/
Agreed your problem is the added volume. You can fight this a couple ways. The chip programming will make a huge difference. You can also install a smaller exhaust housing. How small you go depends on your injectors. Stock=.84, 150-160cc=1.0, anything bigger stick with the stock 1.15. May need to shift one way or the other slgihtly depending on driveing habbits. The injectors will also make a big difference.
Thanks guys I am in the process of putting in my SD HPOP this week on my spare time,then I was gonna call Bean to get some stage 2 injectors.Should I give him the chip to reprogram or somebody else?Its a DP Tuner.Thanks again.
