Problems with LED LIGHTS IN THE DIAMOND CLEAR LIGHTS
I installed my Euro clear headlamps, park lamps and marker lamps, they look awesome.But i could not get the replacement led lights for the 3357 bulbs to light, i took them back out and turned them around and they still will not light??? whats up with that, They will work when you turn the turn signal on but not on park lights all of the 906 type bulbs work ed perfectly for the markers but the big bulbs wont light up for me, and i added the the good electronic flasher allready, any ideas, Thanks [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img]
96 f250 ordered and owned since new, 4.10 gears custom built e40d by jim galatioto of ato transmissions. hypermax intercooler,hypermax stage 2 injectors, hypermax h2e turbo,downpipe,4" exhaust,, terminator pump with 2 new 17 degree pumps dp tuner F5 chip with 6 programs,Beans 3" billet intakes and dual superduty electric fuel pumps, tymar 4" intake system, gear vendor overdrive on transmission, ,new 3/8" transmission lines all the way up and v10 cooler in the bumper and dieselsite transmission filter. cat gone up the tree. Coolant filter added, A/C vent mod done. diamond clear headlamps,park lamps and cornering lamps,remote start & ford alarm. Complete inside cab doors floor and headliner completely DynaMat Extreme lined.Late model 3 pinion posi trac installed. SD Starter. LoJack installed.
