I could kick myself in the a$$ right now, back in '03 when I had the 'ol gal tore down, I noticed corrosion on the face of the block in way of the front cover seal. I didnt think the pitting was all that bad, but, now I have a coolant leak that is coming from that area and is present were no other componet that carries coolant is, meaning, its not a hose, waterpump, etc. I dont have oil in the water or water in the oil, the leak is external. Has anyone been faced with this type of problem? Can I have that area welded up then filed back down? Back in '03 I wasnt aware of this site and I purchased all the software "blind" and got ripped off because I went through the stealership, so, where's the best place to get software ie rear main, front oil seal, front cover seal, etc? Sorry for the long post.
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 4:10 * cc/lwb * RSD Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP 1.0 exhaust housing * Hypermax 3x4" dp * Authentic Tymar intake * gutted ebpv * 4" exhaust & 5" tip * AlumaCraft diamond plate toolbox * custom antenna mount (108" whip) * Uniden cb * diamond plate bed rail caps * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25 * ccv mod * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * poly bushings (front) * Rancho RS9000 shocks * dual steering stabalizer * 60,279 on rebuilt engine (myself) as of 1/08
I put a little silicone all the way around mine when I replaced it just to make sure it sealed. The grey IH stuff is unbelievably sticky, if it doesn't seal it I don't think anything will. You could probably weld/grind it but it would be a pain. Make sure you get it very flat if you do it or it might make it worse. I bought my parts from Powerstrokeshop.com, best price I could find even with shipping.
2000 F-250 Ex.Cab 4x4 Auto with Homemade Intake, 4" Exhaust, DP Tuner Chip, Tugger Kit, 2 HPOPs, ITP Fuel System/Boost Regulator, AC injectors, and Van Turbo/WW
clean it of real good, then mix up some JB weld. smear it in the pitted spots. once it start to set up sand/file it down flat and smooth. it's easier to do it just after it starts to set rather than waiting for it to dry all the way, as it gets pretty hard. then reassemble. i've used this "trick" quite abit on 302's they pitted alot around the cover and the block.
<span style="color: #FF0000">#18</span> not all trucks are created equal
THE COWBOY'S CADILLAC,<span style="color: #FF0000">my pics.</span>, 96 F-350 XLT SC DRW PSD, 4x4 conversion(D60),more oil than you, auto tranny by faubion motorsports, tuned by a backwoods hack(thanks tony), 230cc injectors, D66 turbo, head studs, 910 valvesprings, open element intake, homebuilt fuel system, 3-4"DP, intercooler with homemade spider and piping, 5" chrome stacks with turnouts, front hitch(for my weight bar), member of the <span style="color: #FF0000">WNYPA</span>
