I have no experience with chips. I have always used a programmer. My question is can I pull the chip and run the truck without it or does it need a stock chip put back in to run? I think the chip is bad. I bought the truck and the previous owner said it had a chip of some kind in it. He did not know what type.
1997 Ford CC 2wd 7.3 powerstroke
Yes. Remove the three nuts that hold the e-brake chassis. Slide the chassis off of the studs. You will then see the back of the pcm. If done right, it will have a piece of tape holding the chip tight to its seat.
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 3:55 * cc/lwb * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP D-66 Turbo * IDM Mod * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
