Old 06-24-2008, 11:41 AM   #1 (permalink)
purpose of idm mods
Hi what is the purpose of idm mods what kind of results will come of it like reliability , throttle response , power gains , mielage , ect ? is there any real advantages to it and why do people do it ? Thanks for input guys also if anyone has a link to a website or pics of where to install it great also what resistor would be used and how to tell if the idm is 100v 110 v or 120v i have a new sd idm that i could mod or i could mod the one in my truck doesn't matter Thanks
1996 F350 2WD DRW CC BLACK BEAUTY STG1 160 CC INJECTORS , 3.5" DOWN PIPE 4" MAGNAFLOW EXHAUST, SD HPOP , CPR FUEL SYSTEM , AFE AIR FILTER IN STOCK HOUSING , DP TUNER WITH F5 , AUTOMETER GAUGES PYRO - BOOST - TRANS TEMP - COOLANT , DIPRICOL HPOP GAUGE .
FUTURE MODS ARE D66 TURBO FROM BEANS , SD INTERCOOLER MOD AND WATER METH KIT TO HELP LOWER EGT'S ON HILLS
2002 FORD WINDSTAR SPORT
2007 SPORTSMAN 500HO STEALTH BLACK
2008 SPORTSMAN 800HO STEALTH BLACK
2009 POLARIS RZR NEUCLEAR ORANGE 2" LIFT, 27"SWAMPLITWES ON ITP RIMS , POLARIS PERFORMANCE EXHAUST KIT (THIS THING IS CRAZZZY I LOVE IT )
2008 COUGAR SRX (KEYSTONE) 30FT HOLIDAY TRAILER
drford is offline
Old 06-25-2008, 10:02 AM   #2 (permalink)
The mod will net 140v. It makes the bottom end respond quicker and adds some HP .. lower rpm. I had Joe Servo do mine 6 years ago..150k and it still is working! Great mod.
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 07-03-2008, 04:49 PM   #3 (permalink)
where can i purchase a moded IDM? Please pass along contact info.
matmartens is offline
Old 07-04-2008, 01:28 AM   #4 (permalink)
I can do them for cheaper than most shops charge. I have done 3 so far with no problems. PM me if interested. I think I have 3 resistors left for IDM 100 and 110's.
NoLimitsRacer is offline
Old 07-04-2008, 02:03 AM   #5 (permalink)
Greasy_Dually's Avatar
On that subject, is the idm mod doing smoething that would be done by a tuner? What I mean is if you get a tuner, is there any reason to still do the idm mod?
97 7.3 CC 2wd Dually 140,000 mi. stock except for
DIY Intake
Transmission Just Rebuilt, Tugger Kit, Billet Converter, Steel Gear Sets, Larger Cooler
Greasy_Dually is offline
Old 07-04-2008, 09:08 AM   #6 (permalink)
How do I figure out which idm I have? I have seen the numbers 100, 110 and 120.
Matt
________________________________________
'02 F-250, '05 Chrome grill, headlights, bumper and emblems, BDS 5" lift, 20" Moto Metal 955's with Mickey Thompson ATZ 36/15.50/20, 4" turbo back Magnaflow, MAC intake, Bully Dog programmer and Outlook monitor, PFI 40hp injectors, GDS Ball Buster turbo w/ EBPV mod, Banks torque converter and trans computer, Fabtech ladder bars, modded IDM, AGR Performance Rock Ram, Super pump and Saginaw steering box conversion, Aero Tank 60 gallon replacement tank, ITP Pre-Pump kit and regulated return kit
Old 07-04-2008, 12:56 PM   #7 (permalink)
Yes it still helps. I did this mod to my truck (stock) and made a huge difference. The other 2 trucks I did had superchip programs on them and both guys said they noticed a difference in acceleration.
Your IDM is located on the driverside inner fender near the brake booster. On the wiring harness that plugs into the IDM has a label on that says IDM-###.
IF anybody wants to talk to me about doing this mod PM me and I will give you my number so I can answer any question you might have about it.
Old 07-04-2008, 05:08 PM   #8 (permalink)
I did a new motor with 100hp injectors from Pensecola Diesel. The buzz test passed each injector individually, however there was a noticable difference in sound from the three injectors. The contribution test however failed 1, 2 and 8. I am looking at the IDM replacement first before I go back to the new stock injectors.
Funny thing is I had the same rough idle, hard start and generally running like crap when cold even with the old motor. Old motor had compression on 4 cylinders under 300 lbs. If your aftermarket intake tube comes off the filter, you should never just ignore it.
Matt
Old 07-05-2008, 07:02 AM   #9 (permalink)
DZLJIM's Avatar
...The buzz test passed each injector individually, however there was a noticable difference in sound from the three injectors. The contribution test however failed 1, 2 and 8. I am looking at the IDM replacement first before I go back to the new stock injectors.
FWIW, Buzz test is useless, just ignore it. Contribution is most helpful.
If the CCT shows 1, 2, and 8 running the test 3 or 4 times, then I would swap those injectors with 3 others (Move 1 to 3 which is next to it, move 2 to 4 and 8 to 6) then run the test again. If CCT still shows 1, 2, and 8 then it's electrical. If the problem follows to 3, 4, and/or 6 then it's most likely an injector issue.
I have not heard any positive things about modified injectors from Pensacola, but it could be something else.
Good luck.
Black, '96, F-350, 4x4, Day Cab.
Black/Silver, '97, F-250, 4x4, CC SB
DzlJim.com for some redneck engineered projects.
www.racerxautomotive.com for your upgraded E4OD/4R100 needs.
DZLJIM is offline
Old 07-06-2008, 02:11 PM   #10 (permalink)
Beans Diesel Performance does em for $100.
94-97Chip bottom of that page
1997 PSD #34 15.093 @ 88.63mph(on BDPstage1s) Beans electric fuel, FFD 230cc stroked acodes TWildman 6 position Tymar intake, 17*hpop, IDM mod, diamond back 4" turbo back dual exhaust (3" DP), Arp studs, comp valvesprings, 7.3 intercooler, Rough Country 4" lift, 315 Cepeks FC 2 on MT classics, Bdog electrolum gauges (pre turbo pyro), E4OD auto, 4.10LS, TC ind light, DIY EBPV brake w/ ind lights, CCV mod, Richter69 TC and accum body, 203* tstat, clear turn signals, toolbox with light, ford manual hub conv., ext trim gone.
Highest hp 362, highest tq 723 corrected onstage 1s
future mods: bigoil, 2nd fuelpump, H2E
Work truck: 03 7.3 excab lb F250
New Family rig: 2002 7.3 Excursion edge evo II, mbrp 4" tb exhaust, tymar intake
Big_Dan97's Photos
Big_Dan97 is offline
Old 07-10-2008, 08:29 PM   #11 (permalink)
My new IDM arrived today. Thanks everyone for the info. It is greatly appreciated.
Matt
Old 07-14-2008, 10:49 PM   #12 (permalink)
Rtxcoon's Avatar
only 3?
hardee, har, har....
1997 F350 CC 4x4 Auto
a little over 400 at the rear wheels
thanks to Wildman, Bean, Cass, Luke and Visa
www.northtexaspowerstrokes.com
Truck Pictures
Truck Movies
Rtxcoon is offline
