Old 04-11-2006, 07:27 PM   #1 (permalink)
Pyro trouble
On the 96 I just got, it has a isspro pyro. Its a little different than I have seen as their is no power to the gauge. Anyways, When I got the truck it was in the dp. And I could easy hit 900 deg. Now I moved it to the manifold today and I pegged it @ 1500deg upon medium acceleration. I their anything I can check to fix it. Or is their a way to calibrate it. I checked all the connections. Thanks for any input.
Layne
1994 F-250 PSD ext cab 5spd 4x4 Gutted ebpv ,Valeo smf and clutch,3 pos Tony Wildman chip!, 3-4" Dp, 4" exhaust,Tymar intake, shimmed fpr, HPX crossover, 1.0 A/R exhaust housing, vdo gauges, 279,000k
http://community.webshots.com/album/549770704UdvVUs
1996 F-250 PSD CC SB 4x4, 5spd, 4:10's SMF clutch, 3" dp, gauges, 6oh intercooler(GTS Kit), Tymar intake, HPX, .84a/r housing, 203* stat, 4pos Wildman chip!
ltfox is offline
Old 04-11-2006, 08:39 PM   #2 (permalink)
My Photos: (6)
Re: Pyro trouble
You have the old direct drive ISSPRO pyrometer. They are quite reliable and rarely go out of calibration. For proper calibration they must have 10 feet of ISSPRO's thermocouple wire. If the cable is shorter than 10 feet, is a heavier gauge wire, or has been replaced with copper wire the pyrometer will read high.
900 in the downpipe is not uncommon. My 95 would hit 1000 with stock tuning and downpipe plus foam air filter. But when I put the probe in the turbo up pipe It rarely went over 1200. Going from 900 to 1500 with only moving the probe position sounds strange.
97 F-250 SC LB PSD. 4x4, BTS E4OD, 4:10LS. Baby Swamps, DP-Tuner F5 custom 6 program chip, 1.0 housing, SD-IC, SD-HPOP, IDM mod, HPX, Black Box ICP mod, Black Box MAP sim mod, Hypermax DP & 5" ex., Aero-Turbine, TYMAR intake, RW Turbo-Trac, Gauges, Airlift bags, Add-a-leaf, Superwinch hubs, Class V rear receiver, RBW Lil Rocker, DIY Tow hooks. Milemarker hyd. winch. Elkhorn 9VS slide-in, Nomad 24 ft. fifth/w slide, Century topper, old classic Sooner 18' 4 horse stock trailer. StarFlyte by DynaMax 6.8 V10
If you don't care where you are, you ain't lost.
Larry
Larry S. is offline
Old 04-11-2006, 08:45 PM   #3 (permalink)
Supporting Member
bugman's Avatar
My Photos: (15)
Re: Pyro trouble
There are a couple of different ISSPRO guages on DIS's web site. One is recomended after the trubo and the other is pre turbo. Look on the lower left side and if it has the model number of "R607VW" then it should be placed in the downpipe. I don't know what the diffeerence is but it could be in the calibrations.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter with coolant eye
bugman is offline
Old 04-11-2006, 09:47 PM   #4 (permalink)
Re: Pyro trouble
Well, I know the lead isn't but 5 maybe 6 feet. So I bet its wrong. I'll just go buy a new Pyro I guess. I really don't like the gauge display. Its too hard to read for blind guys like me!
ltfox is offline
