Old 05-18-2007, 07:08 PM   #1 (permalink)
Question about replacing shocks with Bilsteins
OK, so I have the shocks but have never installed shocks before. I'm not a mechanic but have done a few things like replace the fuel pump, vacuum pump, turbo downpipe install, etc. Are there any tips or tricks I should be aware of before I try to change out the OEM shocks? I see the Bilstein shocks have a nylon band around them (wrapped from end to end) to I guess keep them from expanding to much? Why is that? Is that something I need to worry about? Thanks for any help.
Luckenbach
1997 F250HD, PSD, 4WD, SuperCab, SRW, LB, E4OD tranny. Shimmed FPR. Bilstein shocks. 152k miles.
drcart is offline
Old 05-18-2007, 07:46 PM   #2 (permalink)
Re: Question about replacing shocks with Bilsteins
The nylon band is for shipping and to ease installation. it is a reall bear to compress a new shock and try to get it lined up and stay compressed while trying to align the mounting bolt all at the same time.
ShawnMyk is offline
Old 05-18-2007, 08:20 PM   #3 (permalink)
Real men cut the band before installing the shock [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 05-18-2007, 08:29 PM   #4 (permalink)
Cary
So do little kids playing around while 'helping' their dad. [img]/ubbthreads/images/graemlins/blush.gif[/img] [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
Dad promptly sends his little 'helper' inside to fix a lemonade, knowing that will take until just when the job is done.
Said 'helper' was about 6 at the time.
'96 F250 XLT, PSD, 4x4, ExtCab, LB, Auto, 3.55.
11-06: DIY Open Element, EBPV & TC exhaust brake.
02-07: 40 gal '05 F550 aft-axle tank = ~60 gal total.
03-07:DIY/RDS stage 1's, 220,356mi, BTS downpipe & 6pos chip.
04-07: 226,000mi 277HP, 543TQ, Graph
05-07: EGT, Boost, Trans from Tymar
06-07: 4" exhaust, 31 row 6.0L trans cooler
08-07: BTS Transmission.
09-07: 80.76 @ 16.527
My picture & diagrams
danjreed is offline
Old 05-18-2007, 09:03 PM   #5 (permalink)
It's very straight forward, just two bolts for each shock. I found it easier to install the top first and then clip the band to install the bottom.
1997 F250 HD 4x4 5speed Reg Cab, 4" MBRP exhaust, 1.0 turbo housing, Tymar Intake , 17* HPOP,Swamps 150cc, TW 4 position chip, Dana 60 w/RSK, Crossover steering, sittin on 35's
bosefes is offline
Old 05-18-2007, 09:19 PM   #6 (permalink)
BadDogPSD's Avatar
The band is nothing to worry about, it's there to hold the shock compressed to make it smaller for shipping. Install the top first, but don't tighten it all the way, cut the retainer, and try to slip the bottom on as the shock is extending... not big deal if you miss, but it does take some effort too compress the shock again.
1997 F250 4x4 Crew Cab PSD; Dana 60; Sky RSK w/SuperDuty springs.
BadDogPSD is offline
Old 05-19-2007, 08:20 AM   #7 (permalink)
Thanks everybody. I'm going to try and get those on this weekend.
Luckenbach
drcart is offline
Old 05-19-2007, 11:57 AM   #8 (permalink)
My Photos: (9)
The only thing I would add is use anti sieze when you put it back together. When I did the shocks on my '94, I would up having to take a grinder to the rear passenger side because it just wouldnt come loose. Before it was all said and done, I wound up with the top of the shock jammed into the bottom of the bed, and the bottom stuck on a piece of the bolt. Had to slice the shock open (very, very carefully) with a hacksaw to release the pressure so I could get it out. Dont want to have to do that again...
2002 F-350 crew cab, DRW PSD 4x4 automatic. 158,000 miles, Ford AIS, otherwise completely stock.
'94 2WD F-250 PSD 5 speed. 302,000 miles, DIY open intake, 5" single stack, Banks pyro and boost gauge, Grover air horns, DynaMat. Still on the original CPS!
Foxx is offline
