Old 05-15-2006, 05:03 PM   #1 (permalink)
questions about the RS kits with SD springs
Thinking of getting this for my truck, not sure yet though. First, everyone says to get a dana 60 axle, would that be part of helping the ride quality, or is that just something to do while I am putting the kit on? Main purpose is to increase ride quality, so would I need the D60 or is that "optional"? Will it help the ride quality? I guess that's all I have for now, thanks guys.
96 F250 PSD ext cab SB, 5 spd 3'' DP with straight piped exhaust, tymar intake. 135k mi.
psu927 is offline
Old 05-15-2006, 05:20 PM   #2 (permalink)
Re: questions about the RS kits with SD springs
The D60 is a to make it as close to a SD as possible I dont think it could be done with a TTB front end anyways. I feel that my truck rides almost as good if not better in the front then SD's.
03 F250 SC LB 4x4
4.5 inch DR kit. 35's
Freeflowing 4 inch lol
In SO-CAL?
Check out Southern California Powerstrokes.(SOCAPS).
desertwheeler is offline
Old 05-18-2006, 06:36 AM   #3 (permalink)
i wanted to bump this hopeing to get some more replies and I thought of one more question, AI have a 4 inch lift on my truck allready, how is this kit compatible with that as I want to keep at least 4'' of lift. (I think the kit is three inches?) also want to get front end up 2 more inches to level it off.
psu927 is offline
Old 05-18-2006, 01:53 PM   #4 (permalink)
So you want 6"s total lift? I'd imagine you could install the RSK and take a leaf or two out of your lift springs to adjust your total lift. Not sure what lift you have and how many leafs it has. You may not be getting many responses because this has been covered here SO MUCH. Just use the search, there is plenty of info.
1996 F350 XL, PSD, CC, LB, SRW, Green/White, 4x4, 4L10, ZF5, LUK clutch & flywheel, 295/75/16 BFG AT on 16 x 8 Centerlines, Bill's Race chip, gutted EBPV, Ceramic coated Hypermax downpipe, Tymar 4" exhaust w/Donaldson muffler, Tymar Intake, Tymar boost pop-off valve, Tymar HX hose, Tymar coolant filter, JD Coolant eye, AC & fuel tank mods, Autometer Pyrometer & Boost gauges in pillar pod, Warn Premium hubs, Powerslot rotors, Smittybilt nerfbars, add-a-leaf & poly bushings, Bilstein shocks, Drawtite front receiver, Optima red tops, 130W Stainless KC Daylighters, stainless Ventshades, Eclipse CD player, MB Quart speakers, JL sub, Phoenix Gold amps, Viper alarm, Cobra CB, 2001 Honda CR250, 400EX & ATC 70 in the bed, not much more to come...
1996CC is offline
Old 05-18-2006, 06:42 PM   #5 (permalink)
actually I just want to keep the 4inches (not really higher than that) and level the front up. So the front might be 6''
psu927 is offline
Old 05-18-2006, 08:00 PM   #6 (permalink)
Well with what i think are X code SD springs i got about 3 inches of lift, i forgot to measure before. SO you could probably do stock SD springs with the mini leaf pack that deaver makes to lift 1-2 inches. thats what i might do here soon to run 35's.
03 F250 SC LB 4x4
In SO-CAL?
Old 05-18-2006, 08:53 PM   #7 (permalink)
BTW I'm not totally against getting up to 6 inches of lift, not much more than that.
psu927 is offline
Old 05-19-2006, 12:12 AM   #8 (permalink)
i checked against a stock 350 today and i gained just shy of 3 inches from stock.
03 F250 SC LB 4x4
In SO-CAL?
Old 05-19-2006, 09:49 AM   #9 (permalink)
What is the spring part# of your fronts.
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 05-19-2006, 08:37 PM   #10 (permalink)
i'd have to look. I'm not sure. Dark out now. :-)
psu927 is offline
Old 05-19-2006, 11:04 PM   #11 (permalink)
Cary
Who you asking Cary?
03 F250 SC LB 4x4
In SO-CAL?
Old 05-20-2006, 09:12 AM   #12 (permalink)
Part# when ya have time [img]/ubbthreads/images/graemlins/wink.gif[/img]
Cary
2006 Yamaha FJR1300
caryt is offline
Old 05-20-2006, 08:17 PM   #13 (permalink)
ok no prob.
03 F250 SC LB 4x4
In SO-CAL?
