Old 07-09-2006, 12:33 PM   #1 (permalink)
Supporting Member
4door96's Avatar
questions on installing an intercooler
I was looking at the 6.0 intercoolers, do they fit ok and do I need to find a new y pipe to make it work?? If so who sells them? Thanks in advance!
1996 f350 2wd dulley, 7.3psd, 190k, 5 speed, 3" down pipe,5" exhaust pipe no restrictions, edge evolution programmer, stage 1 injectors, k&n air, and gauges.
4door96 is offline
Old 07-09-2006, 04:06 PM   #2 (permalink)
Re: questions on installing an intercooler
I believe it's the early '99 "Y" is the one you want. The early ones will connect up to our turbos with no modification. After mid '99 they are bigger.
I believe that is correct.
1997 F250 2wd Crew Cab, Auto. Mods: New Katzkin seats, Home made Tymar, 3" DP, Kitty ran away, New Tranny, & Fuel pressure gauge.
2004 Excursion 6.0L Limited ( wifes ) BullyDog Tripple Dog downloader w/ Outlook Monitor, Banks Intercooler, Banks Monster Exhaust, Volant air intake, zoodad mod, & added pusher fan to a/c condensor.
brians1997crew is offline
Old 07-09-2006, 04:19 PM   #3 (permalink)
Early '99 y-pipe works, 6.0 i/c fits good too! Maybe someone will chime in with some part numbers.
'01 F-250,4x4,SC,LWB, Evans coolant/coolant filter, ATS Stage 5 tranny/torque converter, V-10 tranny cooler, 3.73 w/Detroit locker, Truetrac front, Bilstein 5100's, Auto-Meter Phantom's, 5" Hypermax exhaust
BDP
'02 F-250 4x2 CC SWB 4R100, 3.73ls(shimmed carrier), DI chip, CCV mod, 203* t-stat, coolant filter, AIH delete, Tymar HPX oil line, AIS, WW, Banks 1.0 "slowspool" housing, pedistal mod, Banks elbow&BHA, 4" turbo back w/btm, Isspro's
6.0 intercooler install(OBS)&truck pics
<span style="color: red">RDRCM #10 </span>
Sniper's credo "If you run, you'll just die tired"
richmondfarms is offline
Old 07-09-2006, 06:24 PM   #4 (permalink)
ThreeStarJR's Avatar
Here you go Pat....
spyder= F81Z-6K889-BA = $ 105.05
clamp= F81Z- 8287-DA = $11.44
O-ring= F4TZ-9E436-A = $6.03
sources = powerstrokeshop.com
Prices are a few months old, talk to Cris or Bob for the updates.
The reducer 2 3/8" to 2" boots to fit the intakes are best found @ an International dealer. 12 to 15 bucks each....
Jim
529/1220 10 17 08
BDP "DOMINATOR 66,"
BDP/Casserly's stage 3 HI-BIRDS
BDP Fuel system
Hypermax rods
Wildman Tunes
Caltracs
96 F-350 CC, XLT, drw, 2wd,...
TRUCK PICS AND ALBUMS
play it loud!
#3
ThreeStarJR is offline
Old 07-09-2006, 06:58 PM   #5 (permalink)
what about putting the bigger intakes on, will they mate up right then or are the bigger intakes too big? of could you just use intakes off of a early 99.
Ford certified diesel tech
96 PSD reg cab 4x4 auto 4.10 LS rear xlt. 4" superlift 35" BGF Muds on 16.5 mickey thompsons, dual stabilizers, 3" glass cowl hood, custom american patriot headlinner, Beans stage I's, TS Performance 6 pos. chip, SD HPOP, BB in fuel regulator, custom intake, 3" downpipe, 4" straight pipe exhaust and 5" tip. All aluminum radiator, 6.0 trans cooler. Banks pyro, trans temp and boost gauges on the pillar. TransGo shift kit, billet converter. 10" rear drup bumper, custom droped hitch receiver billet grille, custom front bumper with fog lights and billet grille, diamond cut headlights, clear corners and markers. Viair compressor, one gal. tank and dual air horns.
90 mustang 347 race car.
05 f250 red supercab 6.0, suncoast auto trans, 4x4, long bed fx4, grey interior. atc 275cc injectors, turbonetics ceramic coated 70mm turbo, head studs, aeromotive fuel system, sct with innovative tunes, dual 5" stacks.
fordboyyfm is offline
Old 07-09-2006, 07:06 PM   #6 (permalink)
The newest 06 intercooler p/n is 6c3z6k775a it is just under 300 dollars and thats with washington state tax.I got it online thru Millennium ford.Seems a lot of the Ford Dealers are trying the online thing.I picked mine up on will call.I just installe the .o6 cooler over the forth of july weekend.
97 f350 XL CC 4X4 SRW 145K OXFORD WHITE,AUTO,A/C,CRUISE ,HX MOD,,TYMAR INTAKE SYSTEM FROM DALE,STANS HEADERS 3" DP 4" EXHAUST;FRP SHIMMED,VIAIR ONBOARD AIR, GROVER AIR HORNS,STANCOR GPR, GUTTED EBV.MonsterBox 06 intercooler with GTS kit. 328hp on a dynojet,
rosse is offline
Old 07-09-2006, 07:09 PM   #7 (permalink)
From what I understand, the bigger intakes are 3", the early 99 are 2" just like what we have. Some have said they have pushed intake spyder into the old 2" boots. I would feel better with the correct boots.
Curt
1997 F350 cc/lb, 4x4, E4OD, 4.10, Pyro/Trans Temp/Boost Gauges. Torn apart- installing h2e, sd intercooler, bronco tank, bosch 044 fuel pump, dahl 150, regulated return, big oil, b codes.
CEMeyer is offline
Old 07-09-2006, 07:25 PM   #8 (permalink)
And to finish your question.Yes they fit fine. I mounted it up higher then the 99 and up intercooler.I use the GTS pipes and spyder and lower brackets. Had a friend cut 3 inches and weld the forward passinger side pipe since the ports on the intercooler are different from side to side(the passinger side is up higher then the driver).
rosse is offline
Old 07-09-2006, 08:16 PM   #9 (permalink)
I can not tell by your sig, but if you have a 2wd you will need to lower your sway bar at least 3".
Here is a pic of mine:
http://home.austin.rr.com/jkmr/ic02.jpg
Jeff Blumenthal
Austin, Tx
97 F350 CC SWD 4X2 4:10, Wildman chip, AFE Stage 2, 6.0 IC, BD 4" Exhaust System, BD Exhaust Brake, BD AutoLoc, Tranny Shift Kitted, Billet Torque Converter, Tru Cool 4739 w/Thremal Bypass, EGT Shutdown Monitor, Air bags, EGT/Boost/Tranny Piller Guages
warpdriv is offline
Old 07-09-2006, 09:08 PM   #10 (permalink)
Does anyone have their AC conednsor OVER their IC? Also, where can I pick up some rubber bushings for the top mounts?
Thanks,
Jeff
1996 F-250 Powerstoke Diesel XLT, smokes bad, rides kinda rough.
open element air filter, H2E turbo, Custom Tranny, 6.0 Charge air cooler, Swamp 175/173 squirts, TS chip, A Cool Radio, COBRA truck condom.
WEBSHOTS--&gt;http://community.webshots.com/user/dieselwiezil
--&gt;http://houstonareapowerstrokes.com
DieselWiezil is offline
Old 07-09-2006, 10:14 PM   #11 (permalink)
Supporting Member
4door96's Avatar
I can't thank everyone enough!!! You all have been a great help, I love this site. It's kinda like diesel's for dummy's 101(and I fit in that class)
4door96 is offline
Old 07-09-2006, 10:48 PM   #12 (permalink)
markccalhoun's Avatar
DieselWiezil, Jeff:
One guy I read about, Tim's IC install maybe, used rubber shock bushings. Maybe there's some rubber thingies in the "Help" section of Autozone or O'Reillys. How about several layers of old inner tube. Maybe a piece of old tire sidewall.
You have a PM too.
Mark
1997 F-350, 4x4, CC, LB, BTS E4OD, 3.55 Gears. Bean's Stage II 160cc Injectors With Custom EDM'ed Nozzels. Tony Wildman 6 Position Chip. Dieselsite H2E; 203° Thermostat; Tru-Cool Max LPD-47391, V-10 Trans Cooler. DIY Fuel System - 10 Micron Pre, Bosch 984 Pump, 2 Micron Post, Aeromotive Regulator, pressure safety switch. Tymar Intake. Full Boar 4" Open Exhaust w/3" Down Pipe. Warn Premium Hubs. Autometer Pro-Comp II Trans Temp and Pyro, Banks Boost Gauge. HPO Crossover Mod. Dual Tensioner Installed. CCV Mod.
UPCOMING MODS: 17° HPOP, Turbo Timer
http://community.webshots.com/user/markccalhoun
"What is a weed? A plant whose virtues have not yet been discovered." Ralph Waldo Emerson
Mensch tracht, un Gott lacht” (“Men plan, and God laughs”) -Yiddish proverb.
markccalhoun is offline
Old 07-11-2006, 09:39 PM   #13 (permalink)
My Photos: (5)
pretty sure you can get those rubber vibration isolators from mcmaster-carr, thanks for reminding me I need to order a couple too [img]/ubbthreads/images/graemlins/grin.gif[/img]
Truck: '97 F250 PSD , ext. cab, shortbed, 5-speed, 4wd, 4.10L
Upgrades: BDP Stage I's, Stealth HPOP, BB Turbo with 1.0 wastegated housing, 6 pos DP Tuner chip, SBC OFE, dual SD fuel pumps, traction bars, US Gear OD, MAP regulator, SP Dongle, downpipe, extra 45 gal fuel tank, EGT-boost-TIP gauges, bilsteins, TYMAR, no cat, 3.5" flowmaster into 4" exhaust, gutted EBPV, XM SKYFi2, cab lights, BFG AT 285/75/16, Autoenginuity, 169k on 5/10/06
Coming soon: 6.0 Intercooler
Dyno'd 298/575, 296/582 before Stealth and Turbo
swh22 is offline
Old 07-11-2006, 10:15 PM   #14 (permalink)
Jeff,
I have 2 part numbers and am not sure which one is which.
I think this is the rubber pad that fits in the bottom part of the IC that rests on a mount.
F81Z-6C681-AA ISOLATOR
I think this is the part number for the grommet whice are at top.
F81Z-6C680-AA GROMMET
Have the parts guy @ ford show you a pic first to make sure.
Jeff Blumenthal
Austin, Tx
warpdriv is offline
Old 07-13-2006, 01:06 PM   #15 (permalink)
My Photos: (32)
The grommets for the upper mounting ears were avaiolable from Ford but the price was outrageous, to the tune of $15/ea??? It was simply the money that pushed me to get creative!
Hope that is helpful...
God Bless,
TC
97 F350 XLT, 4x4, Toreador Red, CC, PSD, MLE0, ZF5, 3.55 l/s, LUK clutch,Velvet Rides, ISSPRO gauges, v/cover vented to tailpipe, DPPI downpipe - modded to 4" right below firewall seam, open element intake using Duralite filter, coolant filter mounted between washer fluid bottle and jack, gutted EBPV, 99+ I/C installed using early 99 Y-pipe and custom pipes, 4-pos chip, BigBopper Seat Mod, Bilsteins, 130cc injectors, homegrown 4" exhaust, uses 36" Magnaflow muffler (Model #12773 body is a full 30" long - nice and quiet!) Custom Fuel System using Carter electric pump, Aeromotive regulator and frame-mounted filters...
2003 Tahoe MS27TT (27' Lite travel trailer), Prodigy Brake Controller.
1991 5.0 LX, runs 12.57 @ 109 mph
My Intercooler/Fuel System Install Webpage (section on CCV Mod too): http://members.localnet.com/~boys3/
TimC63 is offline
