Im installing a overhead console out of an explorer, I think I have all the parts I need but am unsure about the temperature sensor...I have cut a few off of some different explorers at the junk yard but it seems that every explorer I have seen has 2 of them right next to each other...they look identical so maybe either/or will work...the only difference visually are the wire colors...
They both have two wires coming out of them...
One has: Blue w/ White Tracer<font color="green"> & </font>Blue w/ Yellow Tracer
Second has: Pink w/ Black Tracer<font color="green"> & </font>Orange w/ Red Tracer
I am colorblind so those colors may not be perfect [img]/ubbthreads/images/graemlins/crazy.gif[/img]
I just read the whole thing and it says he used the blue/yellow and blue/white for the temp sensor. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
Casey
Can you get the part number for either one of them? According to THIS WRITE UP F87Z-12A647-AA is the one to use.
The part number on the sensor is hard to make out but reading further down the write up, I found this...
Blue/Yellow
Blue/White
Temp Sensor:
These wires are to be ran to wherever you mount the temperature sensor. Some mount it inside the car, some outside.
Guess that answers my question [img]/ubbthreads/images/graemlins/grin.gif[/img] Thanks Rodney
Aloha Casey-
just curious: I see that the Bronco looks like it has a slight "hump" in the ceiling in the picture and the overhead console seems to rest on this area. Whereas in our trucks we have have a flat/upward arching ceiling. So, I am curious as to how you will compensate for this? hope it goes well!
Mahalo,
Kyle
'96 F250 XLT, 4WD, Ext Cab, E4OD, 4.10, ATO Performance Transmission, ATO Heavy Duty Transmission Cooler, Tymar Intake, Tymar 3x4 DP, Tymar Coolant Filter, no "kitty", gutted EBPV, USA Made Powermaster Denso 9051 Starter!...
Aloha Casey-
Mahalo,
Kyle
Shouldnt be a problem..I haven't modded mine at all to fit into my truck and when I stuck it up to the roof this evening it looks pretty darn close...a little shaving of the contoured part to fit around the trim piece and I should be A-OK...
