Try United Drive Line Services in Albany. Link here. Not sure what they offer as services. Worth a look. The double cardan joint I would leave for a shop. Or call Driveline Service in Pittsburg Ca. for info. I'd stick with Spicer over the other.
Why is this? Does the driveshaft need to be balanced after replacing the u-joints?
Aloha Folks-
So, as many of you know the dana 60 I have came from a dually. Is it correct to assume that the stub axles in this dana 60 are longer and that I need to get different ones, shorter ones because I have a single wheel setup? If so, what part number are these stub axles? same part number for both sides?
Mahalo!
'96 F250 XLT, 4WD, Ext Cab, 4.10, D60, RSK with SD Springs, Bilsteins, ATO Performance Transmission E4OD, Heavy Duty Transmission Cooler, Tymar Intake, Tymar 3x4 DP, Tymar Coolant Filter, no "kitty", gutted EBPV, FS2500 Bypass Filter, USA Made Powermaster Denso 9051 Starter!...
Aloha Rusty-
thank you for this info on the stub axles. I was wondering because the DRW has what looks like a spacer attached to the disk brake area, something that our SRW's do not have but if the lengths are the same, that is great!
Mahalo,
kyle
The spacers are there to space out the Dually wheels out properly. Your Dana 50 hubs will space everything out properly for your SRW setup. The Dana 60 ends up being a hair wider than your Dana 50.
The double cardan end is very tricky to disassemble and assemble with the new ujoints. They can be very frustrating if you don't know the correct procedure. You also need to be careful if greasable ujoints are used that the grease fittings are in compression.
Aloha Rusty-
I hope to get some pics up soon in regard to my prep work. CaryT was good to inform me how much these axles weigh! I say this because the d60 is still in the back of my truck! I have a camper shell on too. So, I am hoping to get the right hub socket so that I can take off everything down to the knuckles. This should shed some of the weight and allow me to take out the inside axle setup so I can have new u-joints installed.
I am hoping my friend and boss will let me use an apparatus like a cherry picker to get the d60 out of my truck and onto jack stands or something so I can clean it and work on it. Hope to have some photos soon.
Mahalo,
kyle
ps: now if I could just locate one of those cv yokes for the drive shaft!
Make sure that the yoke you get fits your T-case before you spend a bunch of money buying or rebuilding the F350 front driveshaft.... I was under the impression that they would all fit when I did the D60 in my F250, and after I got the 1 ton shaft rebuilt, I found out this wasn't the case. On a 97 apparently the splines on the front output of the T-case are different than previous years. This may also be the case for 96 also. After doing a bunch of research with no luck I ended up just using the 3/4 ton driveshaft which works ok, just not at high speeds. Somebody around here knows more about this than me (probably Cary T as usual)..... I just can't remember who it was.
Cheers!
1997 F250 Standard Cab Long Bed. D60 Swap.
'96 and '97 use a BW4407..which is different from the '95
Do you have to replace the dust covers or heat shields that go over the rotor? I am talking about the thin metal half circle that is up against the knuckle. I am having a hard time finding these things and the ones that came with my D60 are old and rusted out. Did ya'll leave these things out, is that ok - I wasn't sure if they are needed?
Thanks.
1997 F250 XLT Crew Cab 4x4 Short Bed
Tymar Intake, 6 pos. TW Chip
3" DP 4" w/a muff but w/out a kitty & 5" tip
TSM Rear Disc Brake Conversion, Viper Keyless Entry & Remote Start
King Pin Dana 60, SD rear B codes, Bilsteins 4600
Ranch Hand Replacement Front & Rear
16x10 Pacers W/315 75x16
Most importantly
I am the proudest member of the
Fightn' Texas Aggie Class of '07 Gig'em
No...not sure where to find..maybe Doug at Extreme axle sales..
No they are needed or no to not leave them out? I found some at Bronco Graveyard but they run $80ea. - just for dust covers? That is the only place I have found them. All yards around here have some that are in bad shape.
Most importantly
Nope pulled mine off both trucks.....I have found on occasion rocks get caught between the rotor and dust guard and make for a hell of a racket...backing up usually cleans em out...but I tossed anyways....besides they look girlie manish.....
jrc
97 XLT F250 CC ZF-5 (now ) DIY short shifter 355's D60 air locked T Wildman files, 'jectors, SD Hpop, DIY E-fans, IC, DP 4" exhaust, SS resonator, RSK, SD springs all corners, Velvet rides, Custom Aluminum Drybox/fuel tank, air bags, E-air compressor, VisionX HID/LED's, E fuel, F26D rear tank, E-fan Tranny oil cooler. http://community.webshots.com/user/jcart44
I got new ones from Powerstrokeshop.com but that was 3 years ago, seemed like $40 ea or so. Did Ford tell you they are obsolete?
Diesel Mechanic 28 yrs
