Old 03-22-2007, 03:38 PM   #1 (permalink)
4rcFed's Avatar
My Photos: (6)
Rear axle from a 1997 to a 1976 question
Does anyone happen to know if a rear axle from a 1997 F350 will fit up under a 1976 F150?
Or what modifications are needed?
1997 F-250 HD, XLT, PSD, Ext. Cab, Off-Road pkg., 3.55's, E4OD, 4wd, Dana 60 swap, 3" Sky RSK, Lund visor, 151,000 miles, triple Auto Meter gauges, Tymar intake, Tymar DP, Straight piped, 5" Miter Stacks, Tuning by DP Tuner, 315/70/17's.
Without data, it is just another opinion!!
4rcFed is offline
Old 03-22-2007, 11:12 PM   #2 (permalink)
brahamfireman's Avatar
Re: Rear axle from a 1997 to a 1976 question
I doubt the spring perches are the same, prolly have to cut and weld, the yoke is difffernt so custom drive shaft I doubt you can find a special U-Joint from Spicer. shock mounts prolly different. I can't say weather the wheel width will be the same either.
Diesel Rod
Formerly Diesel Rod.
A '97 F250 with 295K miles, 90 LED's and 5" stacks, among other things....
A '96 F250 Reg cab with 210K miles, Needs to go away. PM me.
'86 359 Peterbilt SHORT HOOD. The ongoing "project" it aint pretty but its got a 425 air to air Cat motor .....13 speed Eaton. Corvette Dash, 17 gauges, 8" black stacks, 63" flat top---> 36" sitting here waiting for paint. 1.305 Million Miles.
I don't know what I am doing, I just know I don't have time to do it.
brahamfireman is offline
Old 03-23-2007, 12:26 AM   #3 (permalink)
RSP
My Photos: (17)
Not sure the width is the same but I am pretty sure they make a u-joint for it. But the driveshaft will be too long taking out a 9inch and installing a Sterling 10.25.
2006 F250 CrewCab Lariat FX4 6.OH AFE, MBRP SS Cool Duals, Elite SCT, 4 Up the pillar, Bed Rug and Retrax Lockable cover.
1997 F350 CrewCab XLT 4x4. ?hp/?lb-ft Intercooled, BTS Trans, BTS Dual HPOP, Big Full Force Diesel Jectors, Big Turbo, Ford AIC, Rockin S Custom 5 inch Exhaust w/AeroTurbine Muffler, AFE Stage II Intake, Total Diesel Performance 4 Positon Chip, White Face Gauges,
1979 F250 SC Lariat 4X4 5.9 CTD, BTS E40D, Dana 60/Sterling 10.25, SD HydroBoost brakes, 440HP 992lb-ft, Intercooled, BFG All Terrains on Eagle Alloy 102s. Custom Rockin S Dual stack Exhaust system. DDP Stage IV injectors, HTB2 Turbo, Snow Water/Meth injection
My Webshots page
RSP is offline
Old 03-23-2007, 02:34 AM   #4 (permalink)
TheRubberDuck's Avatar
The spring perches on the 97 are wider. Set the axle up on jack stands to where the spring perches are level. Then just cut the perches off with a grinder and air hammer, or hammer and chisel. Take the measurement off the old 76 axle and weld them back on level. With the shock mounts, just cut the old mounts off the other axle and weld them in their places on the new axle. As far as the U-joint. Spicer absolutely makes a joint to fit your application. I put an 80 F100 driveshaft (1310 U-joint) to a 14 bolt (1410 U-joint). It's a hybrid joint. I don't have the #off the top of my head, but I can get it if need be. It's funny looking, 2 caps are big and 2 small and different lengths. Looks like a plus sign that got squished. And any good drivetrain shop or driveshaft shop will have them. That swap is VERY doable if you can cut and weld. Hope that helps.
TheRubberDuck
1995 F350 Crew Cab 4x4 dually
Stage 2 DIY inj
RSB 140v IDM
Tymar Intake
DP Tuner 2 pos. chip w/custom switch
FPR Shim 70psi
3"dp to 4" straight piped to 5" Stacks
Hot Pedal
I miss you No.3
RIP #17
TheRubberDuck is offline
Old 03-23-2007, 07:25 AM   #5 (permalink)
4rcFed's Avatar
My Photos: (6)
Awesome feedback!!!! [img]/ubbthreads/images/graemlins/smokin.gif[/img]
A great big thank you for your help and info!! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
4rcFed is offline
