rear disc brake conversion - Diesel Forum - TheDieselStop.com
post #1 of 32 (permalink) Old 01-20-2010, 11:11 PM Thread Starter
customhaying4u's Avatar
My Photos: (5)
I spent mon and tues working on my TSM rear disc brake conversion for my 1997 F-350 CC. It went pretty well, I haven't hooked up the e-brake's because I have one cable that is froze up, so I need to get a new one. I really like the feel although I havn't had much of chance to try them out. I will try and get some pictures posted. I had a lot of trouble with the drums locking up from dirt.
customhaying4u is offline
post #2 of 32 (permalink) Old 01-26-2010, 02:15 PM
gls
I plan on doing the TCM rear brake mod soon. I checked my local NAPA dealer for the calipers and pads. Looks like the pads may be hard to come buy since they arn't an item they have listed.
96' F250SC, 4X4 PSD,E40D,285 Toyo M55's, 28K trans cooler,Chip, sonix, tricumulator, HX mod, Autometer in overhead console, open air filter, shimmed, 7.3 intercooler, superduty turbo, 17*,electric fuel,4" exhaust, Fumoto Valve, Bigfoot camper. 160cc DIY injectors. ATS turbo housing.
gls is offline
post #3 of 32 (permalink) Old 01-26-2010, 04:25 PM
mikevyota's Avatar
Do a complete write up on this! I'm very interested in the swap. Pics, tech, yada, yada!!
30k original mile(now 79k) 97 F-250 CCSB, 7.3l PSD, S&B intake, 4" SS Diamond Eye exhaust w/o muffler, PHP tuned TS-6 chip, 7.3L Al. tank SD CAC, John Wood built E4OD, 6.0L F-550 Tranny cooler, Mag-Hytec trans pan, 4.10 gears, Dana 60 Front, 08 SD rear diff cover, 285/75R16 BFG's, stock 16" Alcoa's, AutoMeter 3 gauge pillar pod, Desert Runner Fab rear bumper with swing-out tire carrier, Line-X'd bed, dual Optima's, Valley class V hitch, Air-Ride overload bags.
mikevyota is offline
post #4 of 32 (permalink) Old 01-27-2010, 07:11 AM
DaveBey's Avatar
My Photos: (203)
I've had the TSM kit(s) on my truck longer than anyone else and if you're looking for increased stopping power, you're better off converting to Hydroboost rather than disc brakes.
If you do decide to go with the TSM kit, wanna sell me everything you take off? I wanna go back to the drum setup.
Cheers from Claremore, OK!
Dave
1996 F-350 XLT CC SRW 4x4
-E4OD●4L10●Tyrant Diesel chip●Hypermax H2E, intercooler, exhaust●TE-T500●7.3L Regulated Return Fuel System●215 amp generator●International water pump●Hydro-Boost●APCM
250,000 happy miles
DZLJIM 3:16
- Hold my beer and watch this.~~
DaveBey is offline
post #5 of 32 (permalink) Old 01-27-2010, 10:36 AM
mikevyota's Avatar
Dave
Did you lose pedal with the TSM setup? I looking for ease of repair with the disc setup. My drums constantly fall out of adjustment, and I hate drums brakes.
post #6 of 32 (permalink) Old 01-27-2010, 12:22 PM
Dave
x's 2--and i dont have hydro--but mine will stop pronto with the stock brakes--thats a future project tho--
94_turbo is offline
post #7 of 32 (permalink) Old 01-27-2010, 03:34 PM
FMTRVT's Avatar
My Photos: (16)
Pardon my wandering over into this forum.
With that TSM conversion, you guys are still using the prop valve spec'd out for a rear drum brake right? Or did they have you change out the Prop?
I know the '97 F-350 had a 400/.61 prop. The front and rear pressures are the same up to 400 psi, then pressures added above that ceiling are at 61% of the input.
Code:
Front  Rear
   0       0
 200     200
 400     400
 600     522
 800     570
1000     663
1200     728
1400     810
1600     882
1800     960
2000    1034
That prop is great for a duo-servo rear drum brake that will get more effective at higher pressures, but a disc brake is linear.
Jack
Truck Pictorials on Facebook. Google - Facebook TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
FMTRVT is offline
post #8 of 32 (permalink) Old 01-27-2010, 05:43 PM
DIESELDUTTON's Avatar
Code:
Front  Rear
   0       0
 200     200
 400     400
 600     522
 800     570
1000     663
1200     728
1400     810
1600     882
1800     960
2000    1034
Hey Jack, Do you know where the valve is in our system? I went to rear disc, hydroboost, super duty M/C, super duty pump and bypassed the RABS valve and my truck wont stop o'yeah 4 sets of pads. Im ready to go back to drums. Thanks
Frank
2004 Pitbull Motorsports rigid chopper...Traded on 2010 F-250 5/30/14
121 TP 130rwh 250 avon
04 CRF250 mine....Gone
02 CR80 sons...Gone
03 XR100 daughters..Gone
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyone
2011 Cougar 325 SRX Toyhauler
2010 F-250 4 door 6.4 with all the fixins
DIESELDUTTON is offline
post #9 of 32 (permalink) Old 01-27-2010, 06:39 PM
DaveBey's Avatar
My Photos: (203)
The proportioning valve is "integrated" with the brake master cylinder.
When I converted to Hydro-Boost, I even swapped the brake master cylinder fluid control valves for the one used on the F-Super Duty which has 4-wheel disc brakes from the factory.
Dave
250,000 happy miles
DZLJIM 3:16
DaveBey is offline
post #10 of 32 (permalink) Old 01-27-2010, 06:52 PM
Dave
you mind clarifying this more???--i found a total hydro setup--for 125.00, but i dont want to put it on, and have less than i do now!!! and i got good brakes--but want better--
94_turbo is offline
post #11 of 32 (permalink) Old 01-27-2010, 08:13 PM
Exclamation
this thread attracted my attention because I have read several posts that said that the rear disc brakes makes a NIGHT and DAY difference.
I need more brake power and was thinking to convert to hydroboost. Dave, do you have any write up about this with #parts, etc?
Thanks.
96 F250, PSD, XLT, SC, SB, E40D, 2WD, 3.55, 142K.
DIY air intake and exhaust brake. Tymar Hypermax DP 3-3.5" ceramic coated; Tymar HPX; GPR switch; upgraded headlight harness; Isspro gauges; 14.7K cOOn´s mod; shim FPR; tranny cooler; CCV mod.
MX_STROKER is offline
post #12 of 32 (permalink) Old 01-27-2010, 08:24 PM
Thanks.
The hydroboost is simple, just make sure you get the push rod with the unit. I think I used a 1997 Super Duty = 450 to look up the parts. I trashed all my old drum parts so I need to gather up everything to go back to drums, I pull a trailer 6 days a week in the summer and my trailer brakes are stopping me. Anyone have a complete 10.25 with 3:55's they want to sell? Thanks
Frank
02 CR80 sons...Gone
425 Polaris magnum
post #13 of 32 (permalink) Old 01-27-2010, 08:42 PM
Talking
Frank
Frank, Thanks.
Oh, BTW I want bad a CC short bed. I like your rig.
post #14 of 32 (permalink) Old 01-27-2010, 09:55 PM
DaveBey's Avatar
My Photos: (203)
Fluid Control Valve, Brake Master Cylinder
You're basically replacing the factory vacuum booster/master cylinder assembly with the factory Hydro-Boost/master cylinder assembly. You'll also have to replace the power steering pump and the power steering hoses.
Steering and Hydro-Boost Plumbing
Power Brake Booster: E8TZ-2005-B
Brake Master Cylinder Fluid Control Valve: E7TZ-2C161-A
Power Steering Pump: F1TZ-3A674-DBRM
Power Steerting Return Line Hose: E8TZ-3A713-B
Power Steering Right Turn Pressure Hose: F4TZ-3A717-A
Power Steering Left Turn Pressure Hose: F4TZ-3A714-A
Power Steering Return Hose (Steering Gear-to-Pump): F4TZ-3A713-E
Brake Master Cylinder Reservoir: E8TZ-2L454-A
While I did not use a Ford brake master cylinder, the part numbers I have are:
Brake Master Cylinder (w/Speed Control): F4TZ-2140-C
Brake Master Cylinder (w/o Speed Control): F4TZ-2140-D
Dave
250,000 happy miles
DZLJIM 3:16
DaveBey is offline
post #15 of 32 (permalink) Old 01-27-2010, 10:05 PM
FMTRVT's Avatar
My Photos: (16)
Dave,
From what F-SD did you get the master from?
Frank,
The prop valve on the '97 is screwed into the master cylinder rear brake port, an aluminum hex body. Props can be exchanged with other props of different values, but the port is not the same thread as the brake tube, so it can't be pulled and the tube inserted. Ford had some vehicles with a empty prop housing, so it was just a pass through when no proportioning was needed. I didn't retain that data when my facility was closed.
The GM caliper has plenty of piston size though. Here is some data from both 1997 and 1999 F-350 test trucks. I included a conversion of the piston sizes to overall surface area, including a line for the GM caliper. Without proportioning of the rear hydraulics, there should be plenty of clamping force on the rear brakes.
I'm not sure what friction material your getting for the GM caliper, though. OE it probably came with DM 128 FE, which was a semi metallic but it had a decreasing friction range with more temperature, shown in the FE designation.
The D52/D122 pad design was relatively high in production, mostly as the D22 on the front brake of pickups (K10/K15). Companies like Hawk do make a high friction pad for it, which may be something to look at if your not getting good braking without a prop valve. And may be a better choice then removing the prop. But I'd probably end up putting the same friction on the front if a rear friction change brings you into a more comfortable deceleration rate for a given pedal effort.
Jack
FMTRVT is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
