Old 01-07-2007, 08:35 PM   #1 (permalink)
Rear disc brakes
It's been a year now since I put disc brakes on my truck using parts from a 99 E-350 donor D-60 axle. Only put 5500 miles on it in that time but they work great. I've had plenty of tests here in Orlando like the recent dude who pulled out in front of me from a 7-11. I just know if my truck still had rear drums it would have a Harley imbeded in the grill now. I have found dust on the rims to be less than on the front, not bad to keep clean. It's all still on our site www.fordmann.com.
I'm up to 86,500 mile now (still a baby) and just replaced the fuel pump, it started spitting out the upper vent hole. Since my heater was long dead I went ahead and did the SD upgrade mods with it all torn apart. Here is a tip, trying to restart the banjo bolt was getting to me when I had a idea. I took it back out(didn't remove the turbo you know) and wrapped it with some 3M rubber tape. It's very sticky. Put it back in and with the tips of my fingers got a good grip and it went in first try. Got loads of info on this from this site on changing out the pump and heater, just love it. I'm greatfull there's people out there willing to help us keep em running.
Stan
www.fordmann.com ~1997 Ford F-350 XLT CC, 4x4, 7.3 PSD, purchased used (21k)11-98, Auto, K&N air filter, Diamond headlights, ORU reverse shackle kit and rear add-a-leaf (2.5" total lift, not allowed more as wife is 5'1"), 3" to 3.5" to 4" downpipe and 4" DynoMax Race Bullet muffler, 35" BFG MT's on Eagle 589 16.5 x 9.75" rims, 4.10 gears, other stuff I can't remember. Other things, '77 F-150, 460,C-6, under restoration now. Butt ugly '66 E-100 van/pickup in storage, I drove it till I got the '97 PSD, '23 T-bucket rod I built in '76/77, 454 Rat, T-10, 9" rear, in storage, too many other projects, kids too. In the shop attic, my late Dad's completely disassembled '31 Model A, 68C, slant windshield, Cabriolet, have to wait till I retire to restore it.
DieselStan is offline
Old 01-07-2007, 08:46 PM   #2 (permalink)
Re: Rear disc brakes
Darn son just told me I messed up the link by putting it a the end of the sentence. Try www.fordmann.com
Stan
Old 01-07-2007, 10:17 PM   #3 (permalink)
this is pretty close to how im gonna do the rear discs on my rig, thanks for the great info on it. im just waitin for donor parts
97 F250HD 4X4 210K MI
4 LINKED FRONT AND REAR ON AIR
00 F350 4X4 CC
RIP CHRIS. 03/09/05
http://community.webshots.com/user/barebackjake
barebackjake is offline
Old 01-08-2007, 04:05 AM   #4 (permalink)
Wow! That is an impressive install!!!
'97 F-250, 4x4, SC, 8' Bed, Auto with Springs/Sonnax/Transcommand, 3.55LS, TDE1, Head Studs, Comp Cams 940-16 valve springs, Swamps 250/173 injector and 6 page chip, Shimmed FPR, MAP Simulator, JS IDM, HX mod, gutted EBP, 3 1/2 custom exhaust, K&N RE-0860, 285/75R16's, Transfer Flow 40&31 gal tanks/fill necks, Rhino Liner.
Home Page
Truck Page
Transmission rebuild and turbo stuff
'89 Turbocharged Mustang, 9.89 @ 136
Defiant Equipment - transmission parts
Mick is offline
Old 01-09-2007, 04:48 PM   #5 (permalink)
Howdy all! This is my first post here, but I've been looking for a while.
I've been pondering the disk brake conversion for a while and I was thinking, what if you had a 99 and up 10.5 axle and you used the hub off a 10.25 and then had the rotor drilled for the 8-6.5 bolt pattern. You would be using everything off the 10.5 except the hub. Would this work??? I don't know how different the hubs are and I haven't looked at the two to compare.
1995 F-350 XLT CC 2wd, ZF-6 sp, SBDD, '96 215 hp 5.9 cummins, TST 10, 4k springs, 370's, PDR35/14 and HT3B/26 Towing twins, and other good stuff
1996 F-350 XLT CC 4x4, ZF- 5 sp and powerstroker for now, Ranchhand bumpers F&R
Truck Pics
12VFord is offline
Old 01-09-2007, 04:56 PM   #6 (permalink)
tjbeggs's Avatar
I am a die hard ford guy as much as the rest of you but this is the route I am going as soon as my rear brakes wear out.
http://cgi.ebay.com/ebaymotors/ws/eBayIS...143996&rd=1,1
1997 F-350 CC LB 4x4 Auto, AD's, Chip, IC, 4Wh. Disk Brakes, and other stuff
Truck Pics
tjbeggs is offline
Old 01-10-2007, 12:18 AM   #7 (permalink)
Might want to think about having a parking brake. Look up CaryT 's posts on the TSM kit with calipers that have a parking brake.
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 01-10-2007, 02:42 AM   #8 (permalink)
SlopeTruck's Avatar
My Photos: (29)
Elderado's had rear disks with a parking brake so useing those calipers instead of the pickup's front will allow a working parking brake...
I've had the chevy brakes on the rear of my play truck for years now and even though they are a single caliper they work way better then the drums.
[color:"blue"]WEBSHOTS[/color]
'00 F350 CC 4X4 longbed, wht, Lariet pkg. She's pretty! Open element intake, 4" exhaust, A-pillar pod w/ Isspro gauges, TW 4 pos. chip, leveling kit, 315-70-17 BFG AT's on black alloy rims, and...
SOLD '95 F350 CC 4X4 (ex-slope truck) flatbed. Open element intake, 3-4" dp, 4" straight pipe through bumper, shimmed FPR, IDM mod, TW 4 pos. chip, DIY RSK/shackle flip, 315-70-17 BFG AT's, H2 rims, 4.10's, rebuilt E40D, 3 guage a-piller pod w/ Isspro guages, DIY rear disks, SD front bumper, Warn 8000# winch, Explorer power buckets, Dodge center console/seat...
Play/plow truck '81 F250 on 40X17's. Bored 351W, S/C bobbed 3', 4 wheel discs, solid axles, Detroit, 2 winches, lots of DIY stuff.
Commute Vehicle: '07 American Lifan LF200GY, 1 cylinder, 16 hp, street legal enduro bike of Chinese origin. Top speed= maybe 70 mph but gets 80 mpg
SlopeTruck is offline
Old 01-10-2007, 09:55 AM   #9 (permalink)
My Photos: (5)
the chevy swap set up looks good....
are we sure the eldorado calipers are a bolt on in this application?
what year eldo?
Belleville, MI (Detroit / Ann Arbor)
'97 F250 4x4 7.3PSD ZF5spd 4L10
PA2818 diy intake, wicked wheel diy turbo rebuild, .84 turbo housing, no muffler, I LOVE MY BEANS TS'ers! ;-), new pedal box bushings, Fleetgaurd coolant filter, Seat Mod, electric fan, Eagle 16x8 w/265 75 Firestone Steeltex AT, cooling pkg front bumper
'69 Mustang 428CJ(ongoing project)
'99 escort zx2 commuter
'86 Supra classic ski boat 351W PCM power
'54 Belair sedan, all original
milner351 is offline
Old 01-10-2007, 11:06 AM   #10 (permalink)
just did the rear brake conversion here is what I did:
tsmmfg.com-for the conversion kit with the braided hose brakeline extensions-450.00shipped
Oreileys-for the 76-78 El Dorado calipers and pads-170.00
blackbirdcustomtrucks.com-for emergency brake hardware-45.00 shipped you will need this because rebuilt calipers do not have and this was the only source I found....I looked long and hard.
Carquest for rear seals-75.00
I went ahead and seviced the rear axle while I was there so new gear oil as well. You will need a flare tool to hook up the existing brakelines with the new braided hoses pretty straight foward I went ahead and pulled both existing brake lines and pinched off hose to keep from leaking. Also you need a special socket similar to the one for the front to pull the rear hub.
There will be some minor welding for new tabs included with new braided hose this will anchor the new junction to the axle tube. The TSM kit is first rate with all the necessary parts no mods what so ever but the caliper will have to be bolted at a 90* angle on the rear of the rotor. I will try and get pics this weekend.
Andy [img]/ubbthreads/images/graemlins/smokin.gif[/img]
also the performance is is way better stops on a dime.....the existing emergency brake cables will hookup but too much slack I will be replacing mine for some new ones will update.
Ford F250 Short Bed Extended Cab/160K/5 speed/BDP Tranny Savers/Redline MTFin tranny/410 gears/open diff./No cat. conv./4" warped speed exhaust w/5" chrome tip/Gutted EBPV/3.5" downpipe/ Tymar open air intake/2.5" Tuff Country Lift/ Factory Manual hubs/HX hose/Ranch Hand Rear bumper/ Fumoto drain valve/Baldwin bypass/Coolant Bypass/Energy Suspension bushings(red)up front/Rancho 5000 shocks/Valeo clutch/31575R16 Mastercraft Courser MTS/K-9 Remote Security System/Trail Boss Tool Box/Trail Boss Brush Guard/Mag Tech Diff. Cover/(ALF 6 Factory Program) TS 6 Position flip chip/Diamond Cut Headlights/203* Thermostat/Autometer Gauges/TSM Rear Disc Conversion
agomez is offline
Old 01-10-2007, 11:51 AM   #11 (permalink)
tjbeggs's Avatar
yes the eldorado will bolt up the same as the chevy truck calipers. I will probably be using line locks front and rear for emergency brakes. here in michigan parking brake cables don't last very long. The only issue with line locks is if I loose all service brakes then they won't work. but if I do install 2 one on the front one on the rear then if I loose a rear line I set the rear line lock then have good pressures for the front brakes and vis versa.
Truck Pics
tjbeggs is offline
Old 01-10-2007, 01:13 PM   #12 (permalink)
My Photos: (5)
Yea, I'm on the other side of the state from you and I'm quite happy that my '97 Ebrake cables are still working well, that's likely because I brought the truck up here from Georgia a couple years ago.
I like the line lock idea, I'm guessing they can be had pretty cheap used on ebay too.
Old 01-10-2007, 01:47 PM   #13 (permalink)
tjbeggs's Avatar
new they are around $30-50. also they would make for nice burnouts!!
Truck Pics
tjbeggs is offline
Old 01-10-2007, 05:12 PM   #15 (permalink)
tjbeggs's Avatar
no but I can't legally take my cat out either, or modify the intake and a number of other things that your not allowed to do. Besides around here if michigan ever went to inspections about 70% of the car would need new parking brake cable and hardware anyway to be operational due to road salt.
line locks were regularly used on medium duty trucks as parking brakes but that was in the 70's and 80's they were called Mico locks I think.
Truck Pics
tjbeggs is offline
