for blackbird, they want $550, for complete kit with rotors, brackets, loaded calipers, plus $45 for RUBBER extension lines.
for TSM, they want $730, for complete kit with rotors, brackets, loaded calipers and either rubber or stainless braided lines.
for me i would have to add sales tax to the TSM units since i live in their state
there seems to be a greater number of parts in the TSM kit.
just wondering if anyone has used either one and their pros and cons; my concern is the quality of rotors and pads they each supply. i could forgo the loaded calipers and source my own i suppose, but...?
Both use the same calipers..SS lines should be bought for all.
get the newest obs van rearend from a junkyard and swap that in with brakes and all its disk brake and fits the wheels you now have one guy on the idi forum did it
then you need stock replacement brake pads and that not some aftermarket ones that may only be avaible through the manufacturer
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, class 5 bumper hitch welded to frame and gusseted, front mount hitch and off road lights,93 front clip, headache rack, 37" humvee tires, ac power converter,factory buckets from quadcab, power windows and locks,cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, huge front bumper, oba,
in progress western style mirrors, holset turbo, airhorns, and some other goodies
I can't speak for this kit on a these trucks, but I bought a kit for my 67 F250 from TSM and they are a good company and very helpful. The disc brakes are convienent but I am not sure if you will get more braking power out of the kit compared to the orginal drums.
Also, will you need to change the master cylinder and proportion valve on the truck for disc brakes? something to look into and I had to change on my 67 project truck.
TSM list that you can by your kit with E-brake. I bought my 67's kit with E-brake.
__________________ 07 F-350 xlt 6.0 PSD LB CC SRW 4x4, black on tan, A/T, 5" exhaust w/4" downpipe 67 F-250 Project truck, currently in a billion pieces 70 F-250 4x4 (highboy)
Past trucks: 04 F-250 xlt 6.0 PSD SB extcab 4x4, 6spd, all stock and 97 F-250HD xlt 7.3 PSD extcab LB 4x4, 5spd, Superchips tuner, 4" turbo back exaust, K&N CAI, 02 intercooler installed, Sold
did mine with tsm..... brakes are way better I could never get the drums to work right, I do not have the cables for the e-brake setup but the calipers will work once I get a bracket fabbed up
__________________ Ford F250 Short Bed Extended Cab/190K/5 speed/BDP Tranny Savers/Redline MTFin tranny/410 gears/open diff./No cat. conv./4" warped speed exhaust w/5" chrome tip/Gutted EBPV/3.5" downpipe/ Tymar open air intake/95 dana 60 / 6" skyjacker Lift/ Factory Manual hubs/HX hose/Ranch Hand Rear bumper/ Fumoto drain valve/Baldwin bypass/Coolant Bypass/Energy Suspension bushings(red)up front/bilstein 5100 shocks/Valeo clutch/31575R16 Cooper SST mt/K-9 Remote Security System/Mag Tech Diff. Cover/(ALF 6 Factory Program) TS 6 Position flip chip/Diamond Cut Headlights/203* Thermostat/Autometer Gauges/TSM Rear Disc Conversion
I went with the TSM kit and could not be happier. I highly recommend TSM.
I did not buy the e brake with my kit. I never used the e brake and could not justify the extra money. I also did not replace the master cylinder or proportioning valve it is not needed.
The calipers, pads, and parts the kit came with were all great. The instrustions were good enough but the best thing is that Skip the owner of TSM drives and OBS and can walk you through any problems, questions, or issues you come across. He is extremely helpful and super guy to work with - I know I called him a hundred times throughout my install - but it really is not that bad.
Over all I would buy from TSM again and would send anyone to them for a kit like this. I was so happy to just to get rid of my drum brakes - it was night and day difference once I got my rear disks installed.
Good luck on you decision and let me know if I can help.
1997 F250 XLT Crew Cab 4x4 Short Bed
Tymar Intake, 6 pos. TW Chip
3" DP 4" w/a muff but w/out a kitty & 5" tip
TSM Rear Disc Brake Conversion, Viper Keyless Entry & Remote Start
King Pin Dana 60, SD rear B codes, Bilsteins 4600
Ranch Hand Replacement Front & Rear
16x10 Pacers W/315 75x16
Most importantly
I am the proudest member of the
Fightn' Texas Aggie Class of '07 Gig'em
The Calipers and pads are Cadilac Eldorado, late 70's
Diesel Mechanic 28 yrs
But that would be a D60 Rear end.
1997 F250 Crew Cab Short Bed 4x4 Auto 4" skyjacker lift 130K Dana 60 Front 4" Straight pipe lost kitty 5" Silverline tip Factory Alcoas on 315/75/16 All Terrains
