Old 04-14-2007, 02:40 PM   #1 (permalink)
Rear End
I had my truck in the for sale section, now I can't find my post, and that's OK, because I've decided to keep it. The fuel mileage isn't bad for a 1-ton truck, and I like the amount of room I've got in it.
I've been wishing for a high speed rear end and a flat bed.
I know the bed can be changed (but suggestions on where to get one are gratefully accepted). I have the 410 rear end, can I get a 355, or something even higher?
I never tow over about 7,000 pounds. I'd really like it if the five speed worked like a five speed, as it is I never use first and fifth isn't high enough.
Charlie Brown, North Alabama
'97 F-350 Crew Cab, 5 speed, Dually. Pretty Stock. Traded
'07 GMC Sierra 1500 Crew Cab
hayhauler is offline
Old 04-14-2007, 02:57 PM   #2 (permalink)
PSDfreak's Avatar
Re: Rear End
yes you can put 355 in...I've even seen a guy on here with 3.08 I think [img]/ubbthreads/images/graemlins/shrug.gif[/img]
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is offline
Old 04-14-2007, 03:01 PM   #3 (permalink)
kfjensen's Avatar
Re: Rear End
Try to find someone on here to trade, that would be the cheapest route, as for the flatbed's, I have been seriously looking at the Bradfords, they are pretty sweet looking
Kevin
94.5, PSD, F-250, 4x4, Handshaker, Couple Do-Dads
kfjensen is offline
Old 04-14-2007, 03:10 PM   #4 (permalink)
johndeerebones's Avatar
Re: Rear End
I have 3:55's, I think for a some time tower I would say they are the best, as far as get up and go I can smoke a comparible 4:10 truck empty since I can stay in the turbo and subsequently power band longer. I would say anthing lower that that would be absolute overkill, stock I could get over 21 on the highway if I babied it, I know average about 16 or 17, but a gasser with my power would probably get 7 to 8, or less.
As far as towing, the biggest load of towed with it was 10-12k, and it had NO problem with it, and still got good mileage.
I still don't use first a whole lot, it is geared very low intentanally to get heavy loads moving, so unloaded you probably won't use it much, I only do taking off on hills, or wet ground. Have to slip clutch too much on hills, and on wet roads taking off in 2nd it is VERY easy to obliterate rear tires...
I know they are expensive, but an overdrive unit would be the ticket, then you would have best of both worlds, towing power, or mileage power. If you have too high gears behind a stroke you will only burn more fuel cause you will have to keep it spooled to maintain speed.
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
My Pics
Truck Pics -Updated-
johndeerebones is offline
Old 04-14-2007, 03:49 PM   #5 (permalink)
Re: Rear End
I would love an overdrive unit, but that's way out of my price range. I would think I could get rearend changed for a lot less than an overdrive would cost. I'm guessing I could get the rearend and the flatbed for what the overdrive would cost.
Johndeerebones, how many rpm are you running at 70 mph?
Old 04-14-2007, 03:56 PM   #6 (permalink)
Re: Rear End
You are right depending on how good you are at dealing.
My speedo is a few percent off, but at 770 in OD I am running a little over 2000 rpm's.
For a comparison on a hard acceleration run I can run 65 in third before the rpms scare me, but I'm pretty brave on the tach [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Oh, I also run 265-75 tires, so a little taller than stock..
I get my best mileage at 65 and down, but you get run over on the highway around here at that.
My Pics
Old 04-15-2007, 02:09 AM   #7 (permalink)
Re: Rear End
So, where do I look for the new rear end, or do I get someone to put new gears in the one I've got?
Old 04-15-2007, 11:00 AM   #8 (permalink)
Re: Rear End
I would post in the for sale section and let the word out that you want 3.55's, there is always someone who wants 4.10s, you can probably work out a swap.
My Pics
Old 04-15-2007, 12:41 PM   #9 (permalink)
4rcFed's Avatar
My Photos: (6)
Re: Rear End
I have a complete, drum to drum, rear axle that I would like to sell. It is from a 1997 SRW F-350, with 3.55's. [img]/ubbthreads/images/graemlins/grin.gif[/img]
1997 F-250 HD, XLT, PSD, Ext. Cab, Off-Road pkg., 3.55's, E4OD, 4wd, Dana 60 swap, 3" Sky RSK, Lund visor, 151,000 miles, triple Auto Meter gauges, Tymar intake, Tymar DP, Straight piped, 5" Miter Stacks, Tuning by DP Tuner, 315/70/17's.
Without data, it is just another opinion!!
4rcFed is offline
Old 04-15-2007, 06:48 PM   #10 (permalink)
Re: Rear End
I wish you lived a little closer, I would have to see that!
<span style="color: #000099"> 96 F-250 CREWCAB POWERSTROKE... Stage 1 injectors... 6 position Tony Wildman chip: stock, economy, daily, tow, hot tow, & Luke Cline Extreme... Superduty IDM mod... Tymar intake... Tymar 3"X4" down pipe... Tymar 4" exhaust... Tymar high pressure oil crossover... 6.0 intercooler-PIPES thanks to GTS... CCV mod... V10 transmission cooler... 203* thermostat... shimmed FPR... gutted EBPV... Monster Box trans... 4.10s... Dana 60 front... LS rear w/ extra qt and a half diff cover... three gauge pod full of Autometer's... AIC... Turbo pedestal mod by Rick96F250 and a 3/8inch shorter bolt on the rear passenger side of the pedestal... Nippondenso starter... THINGS TO DO: get a big turbo, big oil, and big fuel... RSK with SD springs.</span>
<span style="color: #CC0000"> #26</span>
krowell is offline
Old 04-15-2007, 10:30 PM   #11 (permalink)
Re: Rear End
Me too [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Just remember you have a slushbox, you're not a "similarly equipped truck" I don't care how good you shift gears with a manual, more shifting means more looses.
My Pics
Old 04-15-2007, 11:48 PM   #12 (permalink)
Re: Rear End
Yeah, I didn't even notice you had a MANUAL. It definitely makes sense about the shifting.
krowell is offline
Old 04-16-2007, 04:41 PM   #13 (permalink)
Re: Rear End
More shifting means more "looses" I don't understand.
Old 04-16-2007, 05:51 PM   #14 (permalink)
tjbeggs's Avatar
Re: Rear End
should have been more "loses" manual trans trucks aren't as fast as an auto. no way to shift as fast and you lose alot of boost when you can't shift fast.
1997 F-350 CC LB 4x4 Auto, AD's, Chip, IC, 4Wh. Disk Brakes, and other stuff
Truck Pics
tjbeggs is offline
Old 04-16-2007, 07:01 PM   #15 (permalink)
Re: Rear End
I guess I would say "losses." I'm not racing, so that's not a concern for me.
