Well my rear tank is leaking and i need to replace it. Where is the best place to get one. Im looking for a poly tank as the rear is now steel, although my front tank is poly, doesn't make sense to me but is must to ford. Thanks.
-Shane
1997 F-250HD Reg. Cab 4X4 PSD Off-Road, ZF5, 4.10, LUK Clutch Conversion, Coolant Filter, John Deere Coolant Eye, Custom Open Air Intake, 3" to 4" DP, 4" Straight Exhaust, Gutted EBPV, 4 Position Wildman Chip, Bully Dog Boost/Pyro, HPO Crossover Line, Cali. FPR, High Voltage IDM, Upgraded Headlight Harness, Scosche Remote Starter, 285/75 BFG A/T's, Add-a-leafs in the front, One Ton springs in the rear, Owned Since 08/20/2004, 195K
Shane,
Ford had poly fronts with steel rears, did not offer poly rears.
Go figure.
I got a poly rear from MTS Company years ago when my steel rear went. Truck was like 4 years old at the time. I actually ahd a lot of trouble making their poly tank fit right, and make the filler neck and stuff fit. I guess if there's noone else out there you're stuck with them, but I wouldn't get it from them again...
I got my Bronco tank from a local salvage yard that stocks southern rust free stuff. Cost like $100 with straps.
Good luck.
Black, '96, F-350, 4x4, Day Cab.
Black/Silver, '97, F-250, 4x4, CC SB DzlJim.com for some redneck engineered projects.
www.racerxautomotive.com for your upgraded E4OD/4R100 needs.
I just got a Poly tank from MTS last week for my rear.Installation and fit could not have been better.Very pleased with there product.It was a little less than $150 to my door.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: diesel97</div><div class="ubbcode-body">I just got a Poly tank from MTS last week for my rear.</div></div>
Manitoba Telephone System??? What is MTS, better still, do you have a link??? Thanks.
'97 F250 XLT, PSD, Ext Cab, E4OD, 4.10, TYMAR 4 position flip CHIP, BD Downpipe, Isspro pyrometer pre-turbo, AutoMeter tranny gauge, info@TymarPerformance.comTymar air, Tymar coolant filter, and Tymar HPX mod, ported wind deflector, 4" Exhaust, 4" kitty, Hayden tranny cooler w/in-line magnetic filter, Sonnex Valve, Tricumulator Springs, BMM tranny pan Summit Racing, Synthetic ATF, DYNAMAT, AC Mod, Bilstein Shocks from Eshock, Joe Servo IDM Mod, rhino bedliner, custom wheels, Lil' Rocker 5er hitch, 26.5 Prowler LE
Do a Google for MTS Company, that's their name.
Maybe they've changed a few things in the past 6 or 7 years.
God I can't believe it's been that long already...
[img]/forums/images/%%GRAEMLIN_URL%%/shocked.gif[/img]
MTS only lists the rear tank for 85-96 f-series. Will is fit in a 97 F-350? Any changes? My rear tank is junk and I dont want another steel one. The tank is held in by the skid plate.
Chad
1997 F-350 4x4 Reg Cab, Long Bed, 4.10's, Powerstroke, E4OD w/Banks TransCommand, Tymar Intake, Full 3" exhaust w/Banks down pipe, gutted cat, no muffler outlet before passenger rear wheel, TS 6 Pos. Chip, Autometer Ultralite gauges, Lund visor w/cab lights, Line-X bedliner, .84 AR turbo housing, Gutted EBPV.
and only in a 19 gal--no 38 gallon plastic tank----
Will fit through '97, not sure why they list it like that...
Many parts houses dropped the 97 list because there was 2 F-250's in 97. The light duty and the HD
Thanks. I call MTS today and they said that the 97 tank was different. They said many people had tried it and had sent it back. Something to do with it leaking around the sender? Maybe a different sender in a gas truck with electric in tank pump? They could didn't specifically say which was having the problem gas vs diesel but said they didnt think it would work. Ford dealer lists the same rear tank for 96-97 and didn't designate gas vs diesel (from what the guy told me on the phone). I tend to trust those who have actaully installed one. If you guys say it will work I'll go for it. I have the type that is held in by the skid plate. Dont know if that would make any difference.
I'm looking at the MTS #4253. That is the correct one right?
If anyone has any more guidance please share. I want to make the right decision the first time.
Chad
Hey Chad if you want to talk to a total ford guru give this place a call. He specializes in ford and should be able to set your mind at ease.
To my knowledge the senders are the same size, holes are the same size for gas or diesel. That is why the bronco tanks work in the pick-ups.
Anyhow the guy you want to talk to is Eric Woodman. If he is not there the tech is Ben. Ben is very nice and knowledgeable, but I think Eric is the know all when it comes to Fords.
Place he owns is E+W Auto. He is in Loudon on chichester drive. I do not have a concord phone book in front of me, but I know it is in there.
Thanks, I'll give them a try. I have a Concord book here. I'm not far from their place. I live in Barnstead. I appreciate the help. The more stuff I look up the more confusing it seems to get. Just want to get the leak fixed!!
Chad
