Rear S\D Springs WOW!!! - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 02-05-2008, 09:54 AM   #1 (permalink)
DIESELDUTTON's Avatar
I installed a set of rear S\D springs that I have had for about six months now. They were on a 01 350 DRW, my truck sits 1" higher which is what I wanted and the ride is unreal. I have not towed yet, but you would think 350 springs would have a higher capacity. I wish I would have done this a long time, it rides great
Frank
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
DIESELDUTTON is offline
Old 02-05-2008, 10:19 AM   #2 (permalink)
Feedback Score: 3 reviews
maybe I know what I'm doing...I keep telling ya guys
Cary
Cary
caryt is offline
Old 02-05-2008, 10:19 AM   #3 (permalink)
Were the SD springs a bolt-on swap, or did you have to do any fab work to make them fit?
'96 F350 XLT CC 4x4 PSD auto LWB 4.10 open, white, open intake, Tymar HX, 3"DPP downpipe, 315 General A/T on factory Alcoas, big front bumper w/4 really bright lights; F add-a-leaf, new alt x3, fuel pump x3, water pump x2, vac pump x 3, PS pump x3, SD starter, rebuilt seats, total poly bushing kit, serious noise reduction, new tan interior and vinyl floor, Bilsteins, Bean's Stage 1s, Tony Wildman 4-pos chip (wow), etc ad infinitum, black Lab in backseat, locally rebuilt tranny & new TC @ 211k, complete body 'makeover' and repaint @ 213k, 265k miles on 25 Dec '10 and counting...
JoshR is offline
Old 02-05-2008, 10:29 AM   #4 (permalink)
Fordpowrstroke73's Avatar
My Photos: (6)
Send a message via AIM to Fordpowrstroke73
What he said.
'95 Ford F-350, CC,4x4, 7.3 Powerstroke,RDS Stage 1's,Tony Wildman 6 position chip,3.55LS,modded IDM(Thanks Dan),3" downpipe-5" mitre cuts,ebpv gutted, 6" tip,Napa 6637 air filter,Autometer ultra lite triple pillar gauges,Dana 60,Rancho RS 5000 schocks,E40D junk trans,,Aluminum tool box with 7 LED's, headache rack,bed protectors,Hayden Trans. Cooler,Custom Homemade SD Stainless Steel Nerf Bars,285/75/16 BFG All Terrains on Factory Alcoa's,'02 SD Intercooler with homemade IC pipes,Gooseneck hitch
Fordpowrstroke73 is offline
Old 02-05-2008, 12:51 PM   #5 (permalink)
Cary
Yeah, you were right on the money with the S\D front springs, but I didnt see much talk about the rear's. I went by what you said and yes they fit and the rear shackle is straight up and down Thanks Cary.
Frank
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
Old 02-05-2008, 01:44 PM   #6 (permalink)
It was very easy, I had to drill the front spring bushing and the frame mount holes to 3/4, if I had the metric S/D bolts I would have only had to drill the front spring mount. Then for the rear I was using the S/D shackle so I had to grind a little on the bottom where it sits in the hanger due to the S/D shackle being made of thicker metal.
Also I had to drill the rear mount holes out to 5/8, I ended up using the original front bolts in the back mount because they were in perfect shape, even though I had new grade 8 5/8 x 5" for the rear and 3/4 x 5" for the front.
I did the drivers side first with no problems, then on the other side the bottom thick straight spring was about 3 1/2" longer then my obs spring and was hitting my exhaust, so I cut 3 1/2" off and it was fine. I reused my stock over load spring because the S\D over load was to long.
If your rear shackles are in good shape you can reuse them and not worry about drilling the spring mount, not that any of the drilling I did was a big deal. I cant believe that uses a spring hanger like they do, mine are rusted very bad. I have a couple of frame pieces that are rusted pretty bad and everything else looks fine, go figure.
I will get the numbers off the springs and post them, but I thought it was going to be a horrible ride until I pushed down on the bumper and could move the truck. I will be moving boats out of the A/C show Sunday night, so I will find out if I will need air bags, but I am very happy with the ride, I didnt think it would make such a improvement. My old springs had 4 leafs plus a over load the new springs are 5 leafs plus the over load. Good luck
Frank
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
Old 03-02-2008, 05:33 PM   #7 (permalink)
gnxtc2's Avatar
Frank
How did the truck do when hooked up to the trailer? Rear end squat down?
Did you get a chance to get the numbers off the spring?
Was the swap with it?
Billy T.
gnxtc2@aol.com
'97 Black F250HD,XLT, SC, LB, 4x4, Suncoast E40D, Triple Disk Converter, Dana 60, 3.55LS, built 12/97, 3"-4" DP, Bilstein 5125s, VDO EGT, Trans Temp, and Boost gauges, Hellwig rear swaybar, CA fuel regulator, 4" Exhaust-Straight piped,FORD AIC, welded EBPV, B&M Transpan, Cryo slotted rotors, Tony Wildman 4 position chip, Joe Servo IDM, MAP sensor mod, Blackbird rear disc conversion, RSK w/ "V" & "F" code SD springs, Hydroboost conversion, replacement 38 gal rear tank, Swamp's Baby Hybrids, CJC Traction blocks, 209K <---STOLEN
PICTURES OF IT ALL
Fort Lee, NJ
gnxtc2 is offline
Old 03-02-2008, 06:18 PM   #8 (permalink)
im interested as well, how well did it do woth a load.
1996 Ford F350, 7.3 PSD, crew cab, 8ft bed, 4x4, 5 speed manual, 4.11 gears. 184,000 miles. 3x4" down pipe, 4" exhaust with 5" polished SS tip, gutted EBPV, chrome nerf bars, autometer ultra lite pyro and boost gauges, alpine cd player, alpine speakers,garmin GPS.
"Real trucks have 3 Pedals, 2 Sticks, and No Spark Plugs"
gilroyracing is offline
Old 03-02-2008, 07:05 PM   #9 (permalink)
Sorry for taking so long to reply. The new springs were a great improvement, I have a 18' open trailer and before the S\D springs I would put a jeep on the trailer and keep it over the trailer axles so my truck wouldnt squat to much, after the S\D springs I can drive the jeep all of the way to the front of the trailer and the truck sits good, maybe 3\4" down in the rear. I installed air bags last week so when I put some real weight on it, I can keep it level.
I'll try to get the spring code tomorrow. This Florida weather is unreal, it was 80* today and I had nothing better to do so I detailed my entire truck even replaced my wiper blades and fixed my passenger side rear window motor. The people at the hotel thought I was crazy, but its not often when I have time like this, no kids no wife and nothing but time, so I worked on my truck . Thanks
Frank
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
Old 03-03-2008, 10:54 PM   #10 (permalink)
My Photos: (11)
Is there something special about the dually springs or were they something you just happened to have? If 350 dually springs ride so good is it possible 250 springs might be even better.
What option got overload springs on a 97 250 4x4? Mine has the towing package but has no overloads. Doesn't really seem to need them either. On my 95 I didn't need the airbags until installing the front add a leaf.
2010 Ram 3500 Cummins, AT, 4x4, CC, LB, Line-X, B&W Turn Over Ball, RBW Lil Rocker modified to fit B&W, Milemarker hyd. winch. Elkhorn 9VS slide-in, Nomad 24 ft. fifth/w slide, Century topper, old classic Sooner 18' 4 horse stock trailer. StarFlyte by DynaMax 6.8 V10.
Formerly: 97 F-250 SC LB PSD. 4x4, With lots of Goodies. Twas a good truck.
If you don't care where you are, you ain't lost.
Larry
Larry S. is offline
Old 03-04-2008, 01:57 AM   #11 (permalink)
Nit
wicked that's jsut what I needed to hear, now I jsut need to get the springs
Sold to JCart , 1997 F250 FireTruck Red,CC SB,auto( Presicion TC, HD-2Tugger),5" exhaust, Swamp 140cc injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, ,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,she's well taken care of now pictures
2004 Dodge 3500 twin turbo 525hp rocket
Nit is offline
Old 03-05-2008, 07:48 AM   #12 (permalink)
When I picked the springs up I didnt read the add real close to notice the DRW in the members sig, not to mention they were only $50.00. Once I got home I noticed in the members sig it said DRW and I said O'well when I get time I'll give it a shot, I wish I would have done this along time ago.
I probably dont need the air bags but I hate the way the truck looks when hauling heavy with the rear down more then the front I want it level. I know at work we have a 97 and it does not have over load springs, go figure. With S\D springs you dont need the overloads. Good luck
Frank
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
Old 03-05-2008, 08:08 AM   #13 (permalink)
Hey guys, I have some stock front springs from my 02 F350 and some rears from an 02 F250, in the for sale section.
2002 F350 XLT Crew/LB/PSD/6SPD/4x4/AIC/ISSPRO Gauges-Pillar Mount, DPPI 4" Stainless Steel, Ranchhand front and rear. Build date 6/02 Pulling 99 American Star 30WBRL Fiver.
EarlGT is offline
Old 03-05-2008, 10:14 AM   #14 (permalink)
Ok,
You do not need to move the hangers on the frame do you?
Just match the holes on the hangers to the holes in the spring eyes, right?
And, my truck does not have overloads either???
'95 F250HD XLT XC LB, 4:10's. K&N filter (kept dirty haha) 6 Pos Wildman tuner, Tymar DP straight piped to 5" miter stacks, Autometer Ultra-Lite Pyro/Trans/Boost Guages in an Autometer triple pillar pod. Diamondplate Weatherguard Toolbox, Diamondplate bed caps, full Diamondplate tailgate protector, 6" Drop bumper, Diamond headlights/marker lights/turn signals, tinted windows. Lots of interior stereo mods. Dana 60 swap in the works.
1993 F150 Lightning, CAI, Valvebody Shift kit, Eaton Posi, LFP Traction bars. Totally upgraded Sound system.
2003 Ford Mustang Cobra, 2.81 pulley, Dropped 2", 18" wheels, Full Bassani exhaust, JLT CAI, Accufab 100mm TB, Custom Tune. Totally upgraded sound system, and then some.. 430RWHP 466RWTQ
1982 F150 RC LB 4x4, Plow TRUCK
weareweird69 is offline
Old 03-06-2008, 01:30 PM   #15 (permalink)
Originally Posted by weareweird69 View Post
Ok,
On the rear you dont have to move anything and if your rear shackles are in good shape you can reuse them. I used the S\D shackles because they came with the springs and looked heavy duty, but I had to grind a little off of the bottom of the shackle so it would fit down in the rear hanger. Then I drilled the front hanger out to 3\4 and that was it. On the passengers side I cut about 3" off of the large bottom spring because it was hitting my MBRP tailpipe, it wont hit if you have stock exhaust my exhaust comes out on a 45* angle. I just got back from a 2771 mile trip towing a boat and these springs were great. Good luck
Frank
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
