Old 03-17-2005, 10:40 AM   #1 (permalink)
gnxtc2's Avatar
Rear Springs opinion
When I first got my truck, I had approximately 4"-5" between the overload spring and its perch. As of today, it is touching. I went to the leaf spring shop and the guy told me this:
You have 2 choices.
First choice-There is a spring pack that has 5 leafs (thinner) instead of the stock 4 (thicker). $90 per sided. The 5 leaf pack is more common that the reason for the cheap price.
Second choice- Exact stock replacement will cost $195 per side. The stock replacement ones are not that popular and he has to build them vs. the 5 leaf ones that come pre-build from the factory.
He has both in stock but would rather sell me the 5 leafs ones vs taking my money.
I asked about ride quality and height. He said that it should ride the same due to the thinner leafs. He then stated that he has no problem taking my money.
I am leaning towards the 5 leaf pack. I would be re-using the overload spring.
Billy T.
gnxtc2@aol.com
'97 Black F250HD,XLT, SC, LB, 4x4, Suncoast E40D, Triple Disk Converter, Dana 60, 3.55LS, built 12/97, US GEAR downpipe, Bilstein 5150s, Front add-a-leaf w/urethane bushings, VDO EGT, Trans Temp, and Boost gauges, Hellwig rear swaybar, Shimmed fuel regulator, 4" Exhaust-Straight piped,FORD AIC, Custom triple A-pillar gauge holder,B&M Supercooler, gutted EBPV, B&M Transpan, ART Cryo slotted rotors, Tony Wildman 4 position chip, Joe Servo IDM, MAP sensor mod, Blackbird rear disc conversion, RSK w/ "V" & "F" code SD springs, 149K
PICTURES OF IT ALL
Fort Lee, NJ
gnxtc2 is offline
Old 03-17-2005, 11:00 AM   #2 (permalink)
Stymie's Avatar
Re: Rear Springs opinion
from my expierence, generally a pack of springs with more leaves that are thinner ride better, as they springs are more progressive, i would go with the 5 pack.
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 BFG M/T KM2's
Try the SEARCH Button
Stymie is online now
Old 03-17-2005, 08:30 PM   #3 (permalink)
Stop... Get some SD rear takeoffs, free sometimes from a 4x4 shop. Much better ride and easy to install. All you need to do is drill out shackel for the larger bolts. You acn eather use your stock overload or use the SD .
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 03-17-2005, 11:14 PM   #4 (permalink)
Will the SD rear takeoffs raise the rear end any?
1996 F250 4x4 5sp shortbox, ats intercooler, DIY Tymar, 3" dp, Dual 5" stacks, South Bend Con-O clutch and SMFW. BDP Stage 1's up and running!!! my truck
TS 6 pos. chip-High idle, Economy, Tow, Jody Tipton Hot (75 hp), Diesel Power Extreme, and TWildman's "Move it or lose it" Extreme
"A man can always stand a little bit more horsepower" - Chris Ledoux
Strokerin is offline
Old 03-18-2005, 11:21 AM   #5 (permalink)
Nit
just back to normal height, all Ford rear springs for SD models anyways are teh same, somethign like 79-03 teh size is the same , so take offs would work very well, I bought a set of nice 4-5 thin leaf ones and tehy rode great, nice and soft and bouncy, and bouncy, and I hate them now. Take-offs would be best
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel
pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
dirty30
Nit is offline
Old 03-18-2005, 05:47 PM   #6 (permalink)
gnxtc2's Avatar
But how do you know how much wear and tear the SD springs have? One is installing a used spring. If I see the SD go from the dealer lot into the spring shop, then I won't have a problem.
The spring shop guy might want to make a quick buck and lie about the condition of springs. Then you go back to him and tell him that the truck is sagging. Then he says you bought a used spring.
I bought the 5 leaf ones, just like the SD has. $90 per side.
Billy T.
gnxtc2@aol.com
PICTURES OF IT ALL
Fort Lee, NJ
gnxtc2 is offline
Old 03-26-2005, 06:34 PM   #7 (permalink)
I just purchased a pair of Ford 5560 replacemant rear spring's for my F-350 and they have 5 leafs instead of my stock 4. All appear to be the same thickness. I was wondering if anyone has any experience with these as too ride height and ride quality. They would be on already except the old bolt's are frozen to the shackle bushing.After I get new bolt's I will burn the ols ones off. Just wanna know what I can expect.
97 F-350-4X4-AUTO 355 GEARS--NO KITTY--177,000+ MILES-- RUNS BETTER THAN NEW.-BTS TRANS WITH SCHAEFER'S OIL --HYDROBOOST BRAKE SETUP-DPP DOWNPIPE--TS 65HP CHIP--TYMAR INTAKE & HX MOD--HAYDON TRANS COOLER--FS 2500 BYPASS OIL FILTER--AMSOIL 5-30 OIL--COACHES COOLANT FILTER-EVANS COOLANT-203 STAT--WINDSTAR ELECTRIC FAN--DTRL--SYLVANIA SUPERSTAR BULBS--SPARKY'S AIC --PEDAL POT TUNED--ROYAL PURPLE SYNTHETIC IN BOTH REARS--ISSPRO GAUGES IN AUTOMETER 3 GAUGE POD--XL CRUISE MOD--EXPLORER OVERHEAD CONSOLE-AC MOD--BILSTEIN SHOCKS----WESTERN PLOW--CARGORAILS--NRA LIFE MEMBER--LIFE MEMBER SAFARI CLUB -
2002 HARLEY SOFTAIL CUSTOM -SPECIAL CONSTRUCTION ---1999 HARLEY DAVIDSON ROAD KING
flintshtr is offline
