Old 05-20-2007, 08:59 PM   #1 (permalink)
Rear Super Duty Axle Conversion
Just searched 2000 posts with no luck although I'm certain the info is there somewhere....
I have a '96 Crew Cab 4x4 DRW conversion. Broke an axle Saturday morning and it looks like the housing is scrap. What does it take to put in a rear axle from a Super Duty? I'm aware I need SD wheels and that doesn't bother me. Would be nice to change out something on the front to get same bolt pattern there though. I gain disk brakes with the SD rear but I don't know how well they integrate/attach. I'd want to get a complete rear end with rotors and calipers. Do you use SD springs or retain OBS springs? How do you hook up the brake lines? Does the rear bolt in or do you need to fabricate mounts? Does the speed sesnor still work properly to run the cruise? What about parking brake cables and functionality? Will the DRW SD axle track the same? What do I do about driveshafts/yokes? What to DRW SD rears go for from the salvage yards? OBS ones seem pretty cheap. Anything I've missed here that I should be asking? Thanks.
'94 F350 4x4 PowerStroke, 5-speed, 4.10 gears, crew cab, XLT, Luk Clutch, ZF-47, 294,000 miles
'96 F350 4x4 PowerStroke, auto, 4.10 gears, crew cab, XLT, DRW conversion, 436,000 miles
'95 Lance 11'3" Model 900
Diesel_Aggie is offline
Old 05-21-2007, 11:00 AM   #2 (permalink)
Re: Rear Super Duty Axle Conversion
i have done many, many, many axles swaps and the first thing you need to do is get a tape measure and start going over the "new" axle. break lines can be adapted but your master was never intended to work with rear disks. some dont like when you change from drums and some dont care. the pinion lenght of the new axle might be longer then you would need to shorten your DS. you would use your stock springs. the spring perches might need to be moved on the new axle....
the questions that your asking lead me to think that this might be to big of a swap without some help.
start doing your homework.
1996 F-250 PSD XL single cab. homebrew intake with napa 6637, 3" DP and test pipe, Luk clutch!
reason for truck: 91 toyota rockcrawler, 36's, lockers F&R, dual transfer cases, rolled and rashed!
chrisjeep7 is offline
Old 05-21-2007, 12:58 PM   #3 (permalink)
Its not going to be worth it.
2000 F250 powerstroke diesel 4x4, 4 door, Lariat,
big injectors, 76mm turbo
http://good-times.webshots.com/photo...01105611MMKqRT
Black 2006 F250 Crew cab short bed lariat 2wd stock 120 miles as of 4/17/07
http://good-times.webshots.com/photo...01105611ywYxeQ
thedieselkid is offline
Old 05-21-2007, 03:37 PM   #4 (permalink)
i agree, i would swap in a REAL axle if i was going to mess with a swap. if you are busting shafts, i would get some aftermarket ones and forget about it. it would be cheaper.
Old 05-21-2007, 11:24 PM   #5 (permalink)
4rcFed's Avatar
My Photos: (6)
Not sure, but if you are in need of a Sterling 10.25, that came out of a 1997 F-350 SRW, I have one. Just PM me if you do.
1997 F-250 HD, XLT, PSD, Ext. Cab, Off-Road pkg., 3.55's, E4OD, 4wd, Dana 60 swap, 3" Sky RSK, Lund visor, 151,000 miles, triple Auto Meter gauges, Tymar intake, Tymar DP, Straight piped, 5" Miter Stacks, Tuning by DP Tuner, 315/70/17's.
Without data, it is just another opinion!!
4rcFed is offline
