Old 08-22-2008, 09:40 PM   #1 (permalink)
Reasonable Pyrometer, trans gauges
Does anyone have suggestions where I can get Reasonable set of Pyrometer, trans gauges. Appearance is not a big issue for me but they must function correctly.
Thank you in advance,
Kurt
97 F-250 CC, SRW (Mar. 98 MFG date) Centurion Conversion, Warn Hubs, 410 Rear, 285/75's, T-springs & sonnax valve (removed), Mobil one Synthetic Trans fluid, Hayden Cooler (679), Ceramic coated downpipe, intake open element. Otherwise stock. 91 k
klm1017 is offline
Old 08-22-2008, 11:50 PM   #2 (permalink)
Patrick Feeley's Avatar
My Photos: (18)
I don't know your price range, but I've had good experience with the ISSPRO EV series gauges. I've also had a good experience with "Ken's Performance Solutions" for both price and customer service (he was the cheapest I found on the net for the ISSPROs). Cheers!
1994 F350 CC DRW 2WD PSD (ALF4), ZF 5 Speed, 4.10 LS, SBC Con-O SMFW/Clutch, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Stancor GPR, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro (pre-turbo) , Relocated Block Heater Plug, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 08-23-2008, 01:41 AM   #3 (permalink)
Gauges
I just bought a fuel pressure gauge from WWW.Glowshift.com and I really like it. I can switch from 7 different colors, sweep through all or just keep it on one. Definately worth a look also real easy installation. For the "pod" I mounted in the strip of metal that goes across the front windshield. I painted a piece of pvc pipe it looks good IMHO.
1996 F-350 psd crew duellie,declawed, demuffed,fumotoed, home-made intake, edge evo, post triple pillar auto meter gauges,line-x (10-16-05).Seat mod (11-13-05).on-board air(viair 450c) with horns (Kleinn triple train) (8-21-06).Bilsteins (11-28-06)Upgraded headlight harness.IDM MOD by Matty, SOCAPS member <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />thanks Matt!! more mods to come.
fordmedic is online now
Old 08-23-2008, 02:46 AM   #4 (permalink)
chris u's Avatar
gauges
I just bought a set of pillar mount gages they were isspro boost press. and egt. with pillar mount for 233 dollars from thoroughbred diesel hope this helps. Look around for prices but I think I did ok.
97 F 250 4 inch lift with toyo LT 285/75/16 tires on ultra 16/ 10 wheels. Five speed manual transmission. Edge evolution programmer set on level 2 race. MBRP 4 inch turboback exhaust DYI 6637 intake and s&b cold air intake still trying to
decide what to use, ISSPRO pillar mounted gauges and a nice stereo system not going to list all that.
2007 chevy cobalt K&N cold air intake,Eibach prokit springs and 205 50 ZR 17 BFG g force sport tires on Konig wheels. With a sound system that will make you deaf.
2004 polaris sportsman 700 twin EFI with ITP 589 tires.
2001 honda cr 500 last year of the big 2 stroke.
98 polaris rmk 700 with big bore and way to much to list.
97 rmk trail 500 a little clutch work.
2005 ford focus ZX4 wifes car. Totaled 10/08
07 Mazda 6 wifes new car.
2000 F150 5.4 auto wifes truck
chris u is offline
Old 08-23-2008, 09:58 PM   #5 (permalink)
drwoodchopper's Avatar
Half of the sponsers on this site sell guages. Also check Welcome to RPM Outlet they have really good prices on autometers.
1997 F350 CC4X4 88K superclean truck Superchips custom tuned! IDM mod(it works!) Pyro, Boost and Trans Autometers over mirror. Tymar downpipe and 4" straight pipe! 285/65X18's Dune Grapplers. Shimmed FPR. Aftermarket trans cooler Tymar Intake. (intercooler,stg II's and 17*hpop to come then D66turbo) 1997 F350 XLT 4dr 125K 5" Pipe no muf and no kitty (totaled). 04/04 F350 EX Cab LWB "Leveled" Lariat FX4 Limited slip. BFG's 295/75R16. 4" pipe from back of kitty exiting in front of rear wheel. Autometer Pyro and Boost guages 65K. 422hp and 772tq (SOLD) 96 F250 powerstroke extended cab. Original E40D 132K Wood hauling machine. 10k MOD. Autometer Pyro and Boost gauges. Gutted Cat. Sold.
1966 Mustang "mostly restored" It only takes money which is always scarce and I would rather spend it on the beast!
drwoodchopper is offline
Old 08-26-2008, 06:29 PM   #6 (permalink)
You can probably tell from my signature which brand of gauges I would recommend
Regards,
Michael Pliska
ISSPRO Engineering Manager
1995 F350 PSD Crew Cab Dually, 255k miles (Ford rebuilt E4OD at 226k)
ISSPRO Prototype Performax gauges, Tymar Intake, Gutted EBPV, Tymar 3x4" downpipe, Tymar 5" exhaust, Cat's hiding in the shed, Edge Evolution on "Tow", Tricumulator springs and Accumulator Valve, Tru-Cool 4590 Trans Cooler, Lock-Right Locker
1998 S&S 9.5' slide-in camper
33' enclosed tag trailer with 2 doorslammer drag cars (73 Vega Super-Gas & 74 Vega ET Super-Pro)
1992 GMC Typhoon, 1973 Chevy Blazer with Pontiac 400, 1973 Trans-Am 455
NRA member and certified firearms instructor
GOA member
IDPA member
MJPliska is offline
Old 08-27-2008, 09:38 AM   #7 (permalink)
My Photos: (6)
egauges.com
best prices
97 F-250HD Super Cab 4X4
Jasper E4OD, 3.55 gears
Auto Meter Dash Mounted: Trans temp, Boost, EGT, Oil Temp, Oil Pressure.Water temp. Gauges. http://photos.thedieselstop.com/show...t=1&thecat=500
Homemade Open Air Filter, 3 in SS DP, SD, 03 Intercooler. GTS kit. Modified Pedestal, ITP SS HX, CCV Mod, BABY SWAMPS & SWAMPS 6 POS Chip, 17 Deg HPOP, Gutted EPBV, Jasper Stage 1
250,000 Miles, and still going Strong.
TSM Disk Rear Brakes
Cratos is offline
Old 08-27-2008, 10:20 AM   #8 (permalink)
I'm in the same boat. those ISSPRO gauges look real nice.
i keep seeing pre and post turbo pyros. what do you guys suggest?
1999 F-450 crew cab DRW, 6spd. 4" straight exhaust, AFE high flow filter, zoodad, ISSPRO guage set, EBPV delete, CCV mod, DPTuner 80 econo, Wicked Wheel, Midwest Transmission Short Shift Kit
2004 F-150 reg. cab - bagged, shaved, and completely rid of all chrome. street queen.
Hawker is offline
Old 08-27-2008, 01:21 PM   #9 (permalink)
tbeck's Avatar
Pre-turbo. Put the sender in the exhaust manifold. Not a tough job at all.
'94 1/2 F250 4x4, SuperCab XLT, 5 spd, SMF w/ Valaeo clutch, 4.10 (syn. lube), 5w40 Rotella T Syn, manual hubs, Flip over Gooseneck hitch, authentic Tymar intake, 4" AFE exhaust, FRP mod., Isspro boost/pyro,digital thermometer, homebuilt exhaust brake, 153K
tbeck is offline
Old 08-27-2008, 04:12 PM   #10 (permalink)
chris u's Avatar
do pre turbo it only took maybe an hour witch was mostly running wires there are a bunch of links on how and were to install.
chris u is offline
Old 08-28-2008, 02:33 PM   #11 (permalink)
If you haven't installed your guages yet at least get a boost guage install kit from ITP diesel much much better quality than what comes with the guage on any brand. I would reccomend a guage kit for all guages you intend to install I have done it in 4 trucks and the last one with the kit was the easiest and cleanest.
