Old 07-04-2006, 06:22 PM   #1 (permalink)
Relocating the driver's side battery
I conducted a search on this topic but came up short, unless Im loosing it, I know Ive seen past posts. What all is involved and what materials do I need? What are the downsides to this, for those that have done it? Thanks in advance!
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 4:10 * cc/lwb * RSD Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP 1.0 exhaust housing * Hypermax 3x4" dp * Authentic Tymar intake * gutted ebpv * 4" exhaust & 5" tip * AlumaCraft diamond plate toolbox * custom antenna mount (108" whip) * Uniden cb * diamond plate bed rail caps * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25 * ccv mod * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * poly bushings (front) * Rancho RS9000 shocks * dual steering stabalizer * 60,279 on rebuilt engine (myself) as of 1/08
To do list:IDM mod
94strokerace is offline
Old 07-04-2006, 07:23 PM   #2 (permalink)
Re: Relocating the driver's side battery
I think i have seen something about it some where also.
What about relocating them both to the tool box? stacking them on a custome made shelf? That would be cool. I think all you would need would be a big enough cable. My local contractor supply sells it by the foot.
Let us know Thanks
Jordan
96 f350 7.3 206kmiles 4x4 stage 1's downpipe and gagues.
jray3369 is offline
Old 07-04-2006, 07:45 PM   #3 (permalink)
Briansshop's Avatar
I relocated 2 yellow top Optimas to a custom made mount under the bed on the outside of the frame,pass side,between the axle & cab.Man, it REALLY cleaned up under the hood! Lots of room for whatever.
Brian
95 F350 CC XLT,bought new as 2x Dually,owner converted to 4x4,open intake,SD IC,1.0 Housing,Pedestal Mod,Gutted EBPV,dp,5"no muff, Baumann TCS controlled e4od,"I LOVE that thing"!,Baumann VB kit,UCC Custom Billet T/C-VERY low stall speed,Mag-Hytec pan,dual True-Cools,remote filter,3 pos.T/C lock-up switch w/LED,Elec.fans on trans.& engine w/Derale adj.stats,Gauges,Kingpin D60 w/Lock Right,Detroit Locker in the 10.25,4.88s,4" Nat. springs w/ORU-SRK in fr.,crossover steering,10" Atlas springs in rear-no blocks!,Bilstein 5100s,38" PJ Dirt Grips on 16x12" M/T Classic Locks w/Centramatic balancers,Warn hubs,Powerslot rotors,Hawk pads,Can-Back canvas top.
http://s77.photobucket.com/albums/j70/Briansshop/
Just getting broken in, 50,000 miles!
Briansshop is offline
Old 07-05-2006, 12:10 AM   #4 (permalink)
Gator3's Avatar
Brian do you have any pictures of your battery relocation?
1996 250 SC LWB 4x4, Triple Piller/w Autometer 60 PSI Boost - Pyro - EGT Gauges, BTS Trans, Rebuilt Motor 6/01/07, Swamps Large Gator Squiters, Swamps Gen 3 Custom HPOP, Sledgehammer Turbo, 99 IC conv., Headstuds, Cometic HG's, 203* Thermostat, Evans Coolant, Swamps Programing, JS IDM, Vortex Custom Fuel System, Open Air Intake, 4" Downpipe, 5" Miter Cut Stacks, Custom CCV Mod, Homemade Oil Bypass, Dana 60 Axle Swap, Custom RSK w/2001 springs, New paint job, Onyx Spray-In Bedliner, Kenwood Stereo, Complete Interior Overhaul
Gator3 is offline
Old 07-05-2006, 04:57 PM   #5 (permalink)
Briansshop's Avatar
Yea, I have some pics,I'll try to get them up here, as soon as I figure out how.
Brian
Old 07-05-2006, 07:40 PM   #6 (permalink)
You could get the side mount battery boxes Ford puts on the Econolines. They put one battery under the hood, and one mounted on the frame under the side doors.
Dave
Smokyred- RED 11/97 F250HD XLT SCLB Auto 4.10LS 4x4 OFFROAD Powered By 2L Motorsports and SWAMPS.
Mods: AM Ultra-Lites, DiPricol HPOP gauge,TS/2L Moto Chip, 4" Straight-Piped, Poor boy's intake, Swamps II's, BTS, 285 BFG A/T's on factory Alcoas. Lots more to install, see below!
On the bench: AirFlo S400, Swamps 275's, Studs Rods and Springs for the top end, and some other stuff.
My Pictures
DD- SILVER 11/97 F350HD XLT RCLB Auto 3.55LS 4x4 OFFROAD
Mods: Redneck straight-pipe, TS/2L Moto chip.
smokyred is offline
Old 07-05-2006, 08:34 PM   #7 (permalink)
Brian, do you think (Im not an electrician) that the long cables (I have an extended cab) would lead to voltage drop/heat build up by placing my batteries back there? Im looking at about six to seven feet of cable.
Randy
To do list:IDM mod
Old 07-05-2006, 09:00 PM   #8 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Just add a size and you will be fine.
MarkEkberg is offline
Old 07-05-2006, 09:50 PM   #9 (permalink)
Briansshop's Avatar
Yea,like Mark said.Go big and it'll be fine.My truck is a CC and my cables are about 11ft. long. Mine are 4/0 gauge - about the size of a 3/4' garden hose!I ran the same size ground right to one of the starter bolts.Cranks over w/no probs.
Brian
Old 07-05-2006, 09:51 PM   #10 (permalink)
Soaggydogg's Avatar
My Photos: (11)
That was the best place for an air tank for horns but not anymore.
'95 F250 Ported Snorkle, Foil Delete and a little more
'02 Excursion Matched Perfect and Staggered Special
Total Diesel Performance Custom Tuning
Rockin S Performance BTS dealer
good-times.webshots.com/photo/2120855500037306169oDlfMF Well did you touch it?
Soaggydogg is offline
Old 07-05-2006, 11:40 PM   #11 (permalink)
Thanks! That was my next question: exactly what gauge cable do I need. Appreciate the help.
Randy
To do list:IDM mod
