Old 09-10-2007, 11:56 PM   #1 (permalink)
remote start anyone???
got my 97 p-stroke runnin and was wantn to put a keyless entry system on it. just debating if i should go the extra mile and get a remote start. but im not even sure if it will work with the glow plugs or not???
rgilbert248 is offline
Old 09-10-2007, 11:58 PM   #2 (permalink)
PSDfreak's Avatar
Re: remote start anyone???
The systems I have seen are some pretty hefty wiring jobs...you can get systems for diesels that allow for a delay in order to warm the GP's before it cranks...
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is offline
Old 09-11-2007, 01:56 AM   #3 (permalink)
yeah im not sure if i could tackle the wiring or not... but circuit city will do the install for remote start, keyless entry and alarm for $160.
Old 09-11-2007, 03:54 AM   #4 (permalink)
STurbo90's Avatar
My Photos: (9)
That is damn cheap, what brand is that?
Any current remote start system will have diesel timer and/or GP sense wire on it.
On the obs its a straight forward install, no unreadable can-bus tach and GP light as on the '03 and up.
1995 F350 PSD,CC,LB,E4OD,4WDw4:10LS
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 09-11-2007, 09:11 AM   #5 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ryan_Gilbert</div><div class="ubbcode-body">yeah im not sure if i could tackle the wiring or not... but circuit city will do the install for remote start, keyless entry and alarm for $160. </div></div>
Is that with them knowing that is is going on a diesel?
'96 F250 XLT, PSD, 4x4, ExtCab, LB, Auto, 3.55.
11-06: DIY Open Element, EBPV & TC exhaust brake.
02-07: 40 gal '05 F550 aft-axle tank = ~60 gal total.
03-07:DIY/RDS stage 1's, 220,356mi, BTS downpipe & 6pos chip.
04-07: 226,000mi 277HP, 543TQ, Graph
05-07: EGT, Boost, Trans from Tymar
06-07: 4" exhaust, 31 row 6.0L trans cooler
08-07: BTS Transmission.
09-07: 80.76 @ 16.527
My picture & diagrams
danjreed is offline
Old 09-11-2007, 10:11 AM   #6 (permalink)
MarkEkberg's Avatar
My Photos: (13)
They won't do it on a stick.
MarkEkberg is offline
Old 09-11-2007, 01:17 PM   #7 (permalink)
Send a message via AIM to 96P_Stroke4x4
i got a python (same company as viper) alarm and remote start installed a couple weeks ago. it has a timer set to allow the glow plugs to cycle. no problems yet.
Matt
'96 F-250 XLT,ext-cab,4x4,BTS E40D,249k,dana60,swamps175/173s,CPR Fuel sysatem installed 8/2/08,rear discs4" dp to 6" exhaust w/ twin 6" miter cut stacks,Tymar,Autometer Lunar Boost,Pyro,and Tranny Temp,white-faced gauges, intercooler,diamond headlights and corners,onboard air,HX mod,Twildman 6-position chip,shimmed fpr,led 3rd brake light,2 green neon underbody kits+extras,clear cab lights,alteeza tails,4 corner strobes,Sirius satellite,kenwood mp3 player
NRA Life Member
North-South Skirmish Association
"Gotta love the fresh smell of diesel and black powder in the morning!"
96P_Stroke4x4 is offline
Old 09-11-2007, 01:29 PM   #8 (permalink)
STurbo90's Avatar
My Photos: (9)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: MarkEkberg</div><div class="ubbcode-body">They won't do it on a stick. </div></div>
there is models specifically made for manual trans.
you have to go through a sequence when you shut down the vehicle otherwise it won't remote start.
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 09-11-2007, 01:36 PM   #9 (permalink)
STurbo90's Avatar
My Photos: (9)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Cowboy_Dan</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ryan_Gilbert</div><div class="ubbcode-body">yeah im not sure if i could tackle the wiring or not... but circuit city will do the install for remote start, keyless entry and alarm for $160. </div></div>
Is that with them knowing that is is going on a diesel? </div></div>
That shouldn't make a difference on an obs.
There is only one additional wire to be hooked up compared to a gasser.
The WTS light can be tapped inside at the light for the gp system.
On the newer ones('03-up)the light is data and you need to run a wire outside to the actual relay,
and the tach sense requires a tach generator(extra) and needs to be mounted on the alternator.
I just meant $160.00 for alarm & remote start sounds awfully cheap on any car, gas or diesel.
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 09-11-2007, 02:39 PM   #10 (permalink)
Fireman87's Avatar
I currently have Scosche remote start system and had it professionally installed, total cost was $390.00. The system has the capability for keyless, alarm, and many other functions as well including the ablity to keep the inside cab temp. constant by starting and shuting off vehical automaticaly.
Auto Effects
1997 F-250HD Reg. Cab 4X4 PSD Off-Road, ZF5, 4.10, LUK Clutch Conversion, Coolant Filter, John Deere Coolant Eye, Custom Open Air Intake, 3" to 4" DP, 4" Straight Exhaust, Gutted EBPV, 4 Position Wildman Chip, Bully Dog Boost/Pyro, HPO Crossover Line, Cali. FPR, High Voltage IDM, Upgraded Headlight Harness, Scosche Remote Starter, 285/75 BFG A/T's, Add-a-leafs in the front, One Ton springs in the rear, Owned Since 08/20/2004, 195K
The Stroker
East End Volunteer Fire Depatment
Fireman87 is offline
Old 10-31-2008, 06:50 AM   #11 (permalink)
Thumbs up Remote auto start
Hi, I have just thought that people from GenControl may offer some remote start devices.Automatic Generator Control Module
Regards,
Vik
vikanuf is offline
Old 11-01-2008, 09:50 AM   #12 (permalink)
there is many manufacturers that will work a couple i install are , compustar , ultra start , and zenysis , all 3 will allow for manual or automatic trans mission and glow plug operation with delayed start for diesels these units all work GREAT
1996 F350 2WD DRW CC BLACK BEAUTY STG1 160 CC INJECTORS , 3.5" DOWN PIPE 4" MAGNAFLOW EXHAUST, SD HPOP , CPR FUEL SYSTEM , AFE AIR FILTER IN STOCK HOUSING , DP TUNER WITH F5 , AUTOMETER GAUGES PYRO - BOOST - TRANS TEMP - COOLANT , DIPRICOL HPOP GAUGE .
FUTURE MODS ARE D66 TURBO FROM BEANS , SD INTERCOOLER MOD AND WATER METH KIT TO HELP LOWER EGT'S ON HILLS
2002 FORD WINDSTAR SPORT
2007 SPORTSMAN 500HO STEALTH BLACK
2008 SPORTSMAN 800HO STEALTH BLACK
2009 POLARIS RZR NEUCLEAR ORANGE 2" LIFT, 27"SWAMPLITWES ON ITP RIMS , POLARIS PERFORMANCE EXHAUST KIT (THIS THING IS CRAZZZY I LOVE IT )
2008 COUGAR SRX (KEYSTONE) 30FT HOLIDAY TRAILER
drford is offline
