I gutted my EBPV about 6 months ago now I have a leak where the rod goes into the pedestal. Is there a simple way to remove the cylinder from the pedestal or does anybody sell one that has it removed already?
Thanks.
2000 F250 Lariat, CA Emissions, CC, Long Bed PSD, 4x4, Manual, 4.30 gears, 82K Miles Performance Mods: Tuned by PHP, Gauges, AIH Delete, 5" straight exhaust, DIY Intake Suspension: Fabtech all spring 8" Lift, Fabtech Dual Front shock mounts, Fabtech Dual steering stabilizer, Bilstien 5125 on corners, 17" ATX Vice, 37" Toyo M/T
i just cut mine off and welded a piece covering the oil hole.Pretty straight forward really. I think International has a pedistal without it though. I don't know the part number but someone will.
Alex
1997 F-350 blue crew cab,ZF5,4x4,cold air intake, DIY electric fuel system,4"downpipe, D66 Turbo,Dual 5" stacks, 4" lift, 315 MT Baja Claws,wheel to wheel nerfs,'01 HPOP,DIY stage 2's,6.0 Intercooler,TWILDMAN 4 position chip.
You know I think I remembered seeing that when I was in your shop. (I changed my screen name, I was leroux) How hard was that to do? I would hate to screw up my pedestal.
i just did mine, cut it off and ground it all down smooth, then brought it down to the welding shop since i don't have a tig. they charged me $10 to weld it. well worth it to me, it was so much easier putting it back on with that "junk" outa the way. it just hit me that i didn't wire my ebpv open, hhhhmmmmmmmm, i think i'll have to check that.
<span style="color: #FF0000">#18</span> not all trucks are created equal
THE COWBOY'S CADILLAC,<span style="color: #FF0000">my pics.</span>, 96 F-350 XLT SC DRW PSD, 4x4 conversion(D60),more oil than you, auto tranny by faubion motorsports, tuned by a backwoods hack(thanks tony), 230cc injectors, D66 turbo, head studs, 910 valvesprings, open element intake, homebuilt fuel system, 3-4"DP, intercooler with homemade spider and piping, 5" chrome stacks with turnouts, front hitch(for my weight bar), member of the <span style="color: #FF0000">WNYPA</span>
if ya take out the snap ring on the end and pull the "guts" outa it you can see what need to be cut off, it's actually very simple. if i remember correctly there were four small holes that had to be welded up. good luck to ya.
This is a picture of what it looks like after it is cut and welded. Maybe it will help you.
I couldn't get it to open by clicking on it but if I enter it on the Address bar of your internet provider it came up for me.
1997 F-250 XLT EXTA-CAB, 7.3 P.S.D., 2-wheel dr., 108,000 miles, E40D trans., 4:10 rear., DIESEL INNOVATION 4 position CHIP, JoeServo IDM MOD, Tymar intake & HPX Hose, SONNEX Accumulator Valve & Tricumulator Springs, Tru-cool tranny cooler. Trans,Pyro(pre-Turbo)& Boost gauges,down pipe w/ 4" exhaust on back. Kitty gone, Non-existing EBPV. 99 intercooler w/ gtspowerstroke tubes. Pull 28 ft 5th wheel and 17 ft boat,in tandem. Including truck, everything together weighs 18,080 lb's. http://community.webshots.com/user/ksfishman100
I recall this is for the non-EBV IH pedestal part # 1822873C1 at around $200
Brian
95 F-250 XLT,SC,4x4,TDE1,LWB,4:56's,Dana 60,E4OD(lightly tuned),Tymared,Swamped,Lifted,rear disc brakes,6 pos chipped & a pile of other odd & end mods.Trucks,Parts & Misc. Pics 05 F250 V10 too
