Old 03-25-2007, 12:36 PM   #1 (permalink)
removin turbo so time for downpipe? anything else?
hi, my fuel pumps shot so im removing the turbo to replace it and think this is an ideal time to modify the downpipe, also the glowplugs are getting swapped while im in there, should i do the injector o rings too> how difficult are they?, any websites or advice on what mods to do while im in there would be appreciated, also, what brand downpipe or does it matter, thank you all.
'95 7.3l PSD 250,000 straight stock so far. 4:10's new tranny, fuel pump, hpop, so far.
nailbender68 is offline
Old 03-25-2007, 01:29 PM   #2 (permalink)
Re: removin turbo so time for downpipe? anything else?
A little more info on what your working on will help.
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 03-25-2007, 01:30 PM   #3 (permalink)
you should but the specs of your truck in your sig. Like your mileage, and mods to the truck. Its located in under the "my home" at the top of this page.
1997 F-250 PSD, 130k, 4x4, Outlaw E4ODX, Standard Cab, reg bed, 3.55 LS rear, Swamps 225/146 injectors, Autometer Guages Pyro/Boost/Tranny, 3" downpipe, 3.5" adjusted exhaust, ts 6 pos chip, Tonys fun programs, Tru-Cool H7B, 285/75, factory alum rims, Western V-Plow, 6.0 intercooler installed not plumbed
I wish my lawn was Emo, cause then it would cut itself
Racerxautomotive.com for your upgraded E4OD/4R100 needs
BlindViper is offline
Old 03-25-2007, 02:30 PM   #4 (permalink)
sorry, this is on a 95 f250 with 250k and stock as can be for now,it does have 4:10's
Old 03-25-2007, 07:24 PM   #5 (permalink)
Your turbo up pipes are probably leaking. Replace the donuts for them. Get under the truck with a strong light and check where the pipes from the exhaust manifolds go to the turbo. If you see soot (most likely) then you are loosing boost and power.
Mine are leaking and I've got the parts to do it...just not the weather (raining constantly).
'97 F350 PSD E4OD CC 4x4
265/75/16, BB shim=73psi, Open Element, 10K with switch on dash, IDM mod, 30K Hayden tranny cooler, 3" downpipe, 4" straight pipe, the usual gauges, Bullydog 6 position chip. Biodiesel as much as possible.
Tankota is offline
Old 03-25-2007, 10:39 PM   #6 (permalink)
Last summer I had to replace the H.P. oil plug on the back side of the passenger side head because it was leaking. The o-ring was all tore up. The next time my turbo comes off, I'll be replacing the plug on the drivers side. Dale Isley sold me the plug for about $16, and said he's seen a lot of them need replacing. I only had 110K miles, so at 250K, I'd be replacing them if I were you.
Joe
97 F350 4x4 CC 3.55, BTS Tranny, Banks Intercooler, Hypermax Stage I injectors, DieselPower Custom chip, late model HPOP, JoeServo IDM, Hx hose, TYMAR Intake, gutted EBPV, homemade TC Lockup and AIC, CCV mod, Truecool MAX cooler, Air Bags and Horns, Edlebrock IAS shocks, TYMAR 3"-4" downpipe, 4" exhaust, AMSOIL dual bypass filters.
362 HP
jvanhelden is offline
Old 03-26-2007, 11:23 AM   #7 (permalink)
I'm in the same boat. I need to replace the turbo on my new truck and am trying to hit everything back there while I have it apart.
In addition to those items already mentioned, I plan on checking all the components and seals for the EBPV system. I will be keeping mine, but I see others have dumped it.
I am also wondering about how long the fuel pumps last? Does it make since to put a new one in since it's apart? At a minimum, I will be replacing the hoses on the back side of the pump.
Shawn
96 Roll-A-Long F-350 4x4 Crew: 110,000 miles, built E4OD, 1.0 housing, and 3"x4" down pipe.
Truck
AZStang is offline
