What are the pros and cons of removing the ebps? Does it restrict or not? If it will improve power or performance. Always looking to improve as I can. Thanks for all the info, I've learned a lot from all yall.
Are you talking about removing the Exhaust Back Pressure Sensor (EBPS) or gutting/removing the Exhaust Back Pressure Valve (EBPV)? In the case of the valve, the butterfly and shaft take up 22% of the flow area (so it will flow better resulting in roughly a 50F drop in EGTs). Cheers!
There are other mods I want to do... but after rebuilding the front axle... a little low on money for a while. Also any other free or inexpensive mods?
When I gutted my egbp I saw no improvement in any power or lower egt's and only found a soft engine code latter. I now found you can convert your egbp into a jake break. Good luck Mont
For those of us who tow, the do-it-yourself exhaust brake is a great tool.
To activate the brake will cost perhaps $10 for a switch. If you have an automatic transmission, another $10 switch will allow you to lock-up the torque converter for when coming down the mountain with the exhaust brake working.
Not bad, considering an after-market exhaust brake would cost perhaps a thousand buckaroos to install.
I'm with Mr. Patrick on this. I use my modified exhaust valve "brake" all the time. It was about $20, which included a nifty pack of indicator lights! NOTE: My '94.5 has the "fade-y" brake pedal business, so wiring the "exhaust brake" to trip either manually or by the brake lights was a waste- the brakes fade so its tough to get the engine brake to trip just off the pedal. 1 more thing to fix, someday...!
