Old 09-11-2007, 01:10 PM   #1 (permalink)
Replacing Exhaust after 10 years
For all who have installed a new exhaust... How long did it take? What were your obstacles? Since I have to replace I am looking to go from the turbo back and I hear that is a real pain to do. Any suggestions?
I am doing this on my 97 F250 7.3L E4OD 4X4 Ext Cab LB
Ford Family
Me - 1997 F250HD PSD
Wife - 2005 Crown Vic
Brother - 1995 F250 PSD
Father-in-law 2001 F250 SD PSD
Sister - 2007 Mustang GT
stlpsd is offline
Old 09-11-2007, 06:58 PM   #2 (permalink)
Re: Replacing Exhaust after 10 years
Can't say for sure about your 97 but my 99 the only hard part was the downpipe needed extra hands but the rest was easy.
Early 99 Crew Cab Dually AFE Stage II, 4" MBRP,Autometer ultra lite gauges pyro,boost,trans temp,Zoodad Mod.,6.0 trans cooler and now sportin ITP'S Overboost Annihilator and DP Tuners F5 with no start,stock,60 tow,80E and 120 race and all i can say is DAMN!
Former U.S.A. Res. MP & proud of it!
yamt03 is offline
Old 09-11-2007, 07:01 PM   #3 (permalink)
dblamp's Avatar
On my 2002, I had to cut the down pipe to get it out. Other than that, pretty easy.
2002 F-350 SRW 4x4 Lariat Crew Cab, Auto, LSD 3.73, Toreador Red, Bridgestone Dueler A/T Revo 285s, MBRP 4" T409 Turbo back, AFE Stage 2, Isspro gauges (Pyro, Boost, Trans), BTS VB, DP F-5 (No start, Modified Stock, 60T, 80E, 120race), ITP Overboost Annihilator, CCV, AIH Delete, 6.0 Tranny Cooler, Bilsteins
dblamp is offline
Old 09-11-2007, 08:13 PM   #4 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: yamt03</div><div class="ubbcode-body">the downpipe needed extra hands but the rest was easy. </div></div>
From what I have heard around town, the firewall will need to be bent or pushed back to make room for the new DP.
Has anyone had experience doing this? The local muffler shop want $400 + to do the install due to the DP difficulty. I am trying to avoid that cost if there is a way to DIY.
Ford Family
stlpsd is offline
Old 09-11-2007, 08:48 PM   #5 (permalink)
CSIPSD's Avatar
My Photos: (52)
You can fit a two piece 3" down pipe in an OBS with no issues. Might have to remove a Bolt head or two... but its not bad
05/01 F-250 PSD, 125,000 miles, Zoodad, AFE Stage 2, CCV mod, Turbonetics Ball Bearing, Turbo-Master wastegate, Dieselsite's boots, 6.0 IC,Water Injection, AIH delete,ITP Regulator,DP and Wildman tunes,GTS Hybrid injectors, ITP Fuel system,Studs, 910 valve springs,Suncoast 4r100,MBRP T-409 duals,Aeroturbine, 6" tips, 16 Isspro gauge's, 100g fuel tank, 05 mirrors with recon lens, 4" Revtek lift 37-13.50-17 Toyo MT's
ME!
MY PICTURES
CSIPSD is offline
Old 09-12-2007, 12:48 AM   #6 (permalink)
My Photos: (6)
When I did my downpipe we cut it out and then bent the body lip on the cab down. The new one just slid in and with the lip bent, there's no worry about the pipe vibrating or making a rattling noise. After that the rest is a piece of cake...It took an hour or so to change out.
June 1996 F250HD XLT/SC, LWB, 4x4, 4:10LS, E4OD, White outside, Gray inside, Camper/Tow pack, Factory Aluminum wheels, Factory rear slider, decal free.
Factory AIC, Aux dash switches, Full add-a-leaf, Mile Marker SS Hubs, Upgraded E4OD Tranny, Tymar intake, BD downpipe, Exhaust brake, 203* stat, BriteBox, California Regulator mod, Truck Interiors Winterfront, Ported bug guard, Energy Suspension bushings rolling on 265x75 Bridgestone Revo's.
KD7UBW - PHAR (Public Health Amateur Radio)
My Truck
2008.5 Mazda 3s Touring 5 door in Copper Red Mica w/indash 6 disk Cd changer/MP3 and moonroof: The Wifes
Rookie is offline
Old 09-12-2007, 01:38 AM   #7 (permalink)
It's really not hard at all, just a little time consuming. It seems that some trucks have a little different clearances in the downpipe location. All you need to do is stick a 2x4 or a small scissor jack or whatever you can find (once the old downpipe is out)up in between the firewall and the engine block. Pry the firewall back, you may only need to bend the pinch weld back. I found it much easier to cut the old downpipe in half with a sawzall when I removed it.
1997 F250 HD 4x4 5speed Reg Cab, 4" MBRP exhaust, 1.0 turbo housing, Tymar Intake , 17* HPOP,Swamps 150cc, TW 4 position chip, Dana 60 w/RSK, Crossover steering, sittin on 35's
bosefes is offline
Old 09-12-2007, 09:17 AM   #8 (permalink)
MarkEkberg's Avatar
My Photos: (13)
If you have some know how it should be less than 2hrs for the DP stuff. Just make sure you have a saws all and a couple blades.
The rest of the exhaust should also take less than 2 hrs.
MarkEkberg is offline
Old 09-12-2007, 12:03 PM   #9 (permalink)
Yes it is not hard and not worth $400. Cut the DP and pull out the top and bottom. Cut the body lip in two places and bend it flat. That is all. Slip in the new DP and done. If you want a thrill crank it at this point.
97 F250 7.3PSD,X-Cab,SWB,4X4,5spd,4.10gears,1Owner
3.5” DP,4” Exh.,No Cat,6637 Intake,FPR mod,60 gal bed tank,5th whl & gsneck
BDP 140v IDM Mod
CCV mod
'08 diff
Hewitt Gauges
HPX Mod
6 pos TW chip
Modded H2e
Rosewood stage II's
Valair clutch
'00 Excursion 7.3PSD 4X4, Bone stock...(wife's truck)
6637 intake
drill/slot rotors
Neal97250 is offline
Old 09-12-2007, 12:53 PM   #10 (permalink)
Hey thanks everyone for the replies. I think I will tackle this myself. It seems I have all the tools required. CSIPSD mentioned a 2 piece DP. I have not found that. Who makes it? I am looking at the SS kit from MBPR. I am open to your suggestions for quality materials if it is ok to post those kind of things here.
Again, thanks for all the help and suggestions so far.
Ford Family
stlpsd is offline
Old 09-12-2007, 01:14 PM   #11 (permalink)
MarkEkberg's Avatar
My Photos: (13)
If you still need one I have one for sale. It will not work with a existing stock set-up, but if your replacing everything anyway mine will work great.
Old 09-12-2007, 01:21 PM   #12 (permalink)
WormDrowner's Avatar
Send a message via ICQ to WormDrowner
Many folks had to bend their cab lip to make the new DP work. I was one of the lucky ones in that my cab is mounted far enough back that my new DP just dropped right in with a little manipulation. Some others here have been lucky as well. As far as that Sawzall blade goes, get a long one. it makes it much easier if you reach as far up the old pipe as you can to make the cut.
"You can all go to Hell. I'm going to Texas." - Davy Crockett
1996 F-250 Supercab PSD with Edge Evolution, Grand Rock Powerflow 4" exhaust, AFE Stage II Intake. Isspro Gauges.
1996 MB C220
WormDrowner is offline
Old 09-12-2007, 02:00 PM   #13 (permalink)
Only other caution is if you needto bend (likely) the cab lip, be careful of the fuel line elbow on the head. PIA if you break it off. I used a portapower with a body spreader. I had the tranny out though so I cheated!
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 09-12-2007, 02:27 PM   #14 (permalink)
My Photos: (5)
I would recomend at least 2 blades for the sawzall - fresh ones.
the factory down pipe is a tough bugger - good metal in that thing - too bad it's so horribly shaped.
Replacing the down pipe was not a big deal.
Upon recomendations from here I cut two slits in the floor / firewall hem flange, massaged it flat with a hammer, and installed the new round 2piece 3" unit - no sweat.
If possible use band clamps not U clamps.
Make sure you wear tight fitting safety glasses or goggles if you cut from underneath - been to the eye doctor - not fun!
Some guys have had good luck cutting from the top too.
You'll have to cut the tailpipe to get it out as I recall, too large to wrestle in unless you have it way up in the air.
I'd cut out the old system in as many pieces as required to make removal easy.
Then install the new down pipe - a super duty tailpipe, and connect the two with an adaptor at the cat flange and a piece of pipe. (SD tailpipe is 4"
Belleville, MI (Detroit / Ann Arbor)
'97 F250 4x4 7.3PSD ZF5spd 4L10
PA2818 diy intake, wicked wheel diy turbo rebuild, .84 turbo housing, no muffler, I LOVE MY BEANS TS'ers! ;-), new pedal box bushings, Fleetgaurd coolant filter, Seat Mod, electric fan, Eagle 16x8 w/265 75 Firestone Steeltex AT, cooling pkg front bumper
'69 Mustang 428CJ(ongoing project)
'99 escort zx2 commuter
'86 Supra classic ski boat 351W PCM power
'54 Belair sedan, all original
milner351 is offline
Old 09-12-2007, 04:18 PM   #15 (permalink)
My Photos: (6)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: milner351</div><div class="ubbcode-body">If possible use band clamps not U clamps.</div></div>
No lie! Definately go get some band clamps. My local NAPA has them in stock, but I am not sure if all NAPA's have them.
'95 F250 XLT 4X4 Ext Cab long bed, 5 speed, SMFW, custom kevlar LuK clutch by Superior Friction San Jose, 3.55 LSD, '88 kingpin D60, Sky RSK with SD V code springs, 175K miles, ATS 1.15 BB turbo, BDP Stage 2.5 injectors, BDP fuel system, 4 line Stealth, '02 120V IDM, ARP studs, Spearco 7.3 intercooler, 3" intakes, Northern Diesel Performance 6-pos TS chip w/TW tunes, guages, Tymar intake, EBPS bypass mod, IH bellowed uppipes, 4" DP, straight exhaust, 200PSI train horns and 215A alternator..
Home of the 94 and 95 HPOP anti bleed down mod
General Truck pictures..
radarman is offline
