Caryt has a write up that somebody used stock SD hangers and stuff on his OBS. Search Caryt's post in some of the recent RSK threads. Been mentioned in most.
03 F250 SC LB 4x4
4.5 inch DR kit. 35's
Freeflowing 4 inch lol
In SO-CAL?
Check out Southern California Powerstrokes.(SOCAPS).
Could I unbolt the leafs from the frame mounts, cut out the original frame mounts, weld/bolt in the SD ones all the while leaving the leafs attached to the axle?
The link stated that Shannon used SD springs and the axle moved back 1". I started to think that the SD center pin is different that the OBS. Also moving the axle back 1", would the front driveshaft need to be shortend. Hence my question about leaving the OBS leafs in place and using them as a guide/template to mount the SD ones.
