Old 05-16-2005, 01:48 PM   #1 (permalink)
Reverse Shackle Question?
Will I need to buy different shocks if I install a Reverse Shackle Kit? Also, if I need to put blocks in the rear for leveling the truck after the install, where do you get those?
Thanks! [img]/ubbthreads/images/graemlins/smokin.gif[/img]
1997 F250HD Regular Cab 4x4, 4.10 SRW, Handshaker ZF5 Tranny, Bean Stage I's, TWildman 4 Pos Chip, 3" Downpipe/4" Exhaust, Tymar Intake, Luk Single Mass Flywheel/Clutch, IDM Mod, Ford AIC, Stancor GPR, HX Mod, Gutted EBPV, Dead Kitty, Coolant Filter, 203* Stat, Twin Electric Fans, A/C Mod, GPR Bypass System, 1.0 A/R Turbo Exhaust Housing
There's no Substitute for Cubic Inches!!!
F250Jockey is offline
Old 05-16-2005, 02:50 PM   #2 (permalink)
Re: Reverse Shackle Question?
The kits is a 2.5 inch lift so you will need new shocks. As for the rear, it leveled mine out perfectly, but I have a 350 so it may be different.
MY TRUCKS
1996 PSD F-350 crew cab 4x4, AB CODE CALIFORNIA TRUCK, 5 speed,CON-O SMFW modified by Southbend Clutch, ORU Reverse Shackle kit, 4:10, u.s. gear chip, IDM MOD BY ME , down pipe, 4 inch straight pipe, boost and EGT gauges,PRO COMP A/T's 305-70's, Bilstein's, ditched the k&n filter for an open element Baldwin PA 2818, kenwood & polk audio sound system.
2002 Excursion PSD 4x4 XLT Premium- TN BB 1.0 Turbo , 6.0 IC, 8 inch Sky Jacker lift, FOX shocks with remotes, 35-12.50R17 BFG Muds mounted on 17x10 Boyd Coddington Billet wheels, ORU Frozen rotors, custom hybrid intake, DVD/2 monitors, Billet grill, XM radio, DP Tuner PCM QLJ5/PMT1 combo, Edge Juice/Attitude for gauges.
SOUTHERN CALIFORNIA POWERSTROKES MEMBER
mattymx is offline
Old 05-16-2005, 04:29 PM   #3 (permalink)
If I go with Bilstein's on the front with the Reverse Shackle Kit, does anyone know which ones will fit? Also, which Bilstein's are you guys using in the rear?
Old 05-16-2005, 08:49 PM   #4 (permalink)
Banned
A stock shock should work just fine for a 2.5" lift. When I built my reverse shackle at the full bottom travel the shocks were just bottoming out but I built mine for a 4" lift. I got the rear blocks from Summit but make sure you don't get the wedge shaped ones like I did. It is WAY to much of an angle and it messes the geometry up. I did 4" in front and 3" in back and it sit's about perfect.
gtspowerstroke is offline
