Well After i got my injector O ring situation handled with a set of stage 1's and 1000 miles on the highway I have a definite rod knock. I think it happened the 2 times I ran it out of oil, the first time I had no idea it was burning oil and the second time was because I didnt know how fast it was going through it. Good thing i am a machinist and it will only cost me parts and time. I also noticed that the turbo made a bad whine when under heavy boost and am thinking of puting a turbo off a superduty on the Ol girl and am wondering what is involved?
you will need pedistal uppipes and colector, ic y pipe, 3" intakes. Some one here have put a sd turbo on there trucks and were not impressed at all. Man go with a BB or TN turbos.
1996 crew cab 4x4 black psd BDP 250cc hyrbids BDP fuel system Stealthhinator dual ipr hpop
H2E TDP tuning 515hp 1158tq
99.5 psd reg cab 2wd
334hp 740tq
rdrcm #29
"New opinions are always suspected, and usually opposed,without any other reason but because they are not already common" John Locke Truck and misc pics
teh SD turbo is not an upgrade, more like a downgrade. How can you hear a rod knock? way too loud for that. If in fact you do have a rod knock then you must have bent it durign teh injector install, did you turn it over by hand first?, it si very possible that you tweaked a rod while gettign the oil out of the cylinders.
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
Does it white smoke at all? Could of not gotten one of the injs seated good and if it leaks fuel into the cylinder it will make a hellacious fuel knock.
<font color="red">bdp</font> Custom Injectors
<font color="red">bdp</font> Custom Fuel systems
<font color="red">bdp</font> Custom Turbo systems Stealth Dual HPOP Systems Get Destroked W/Destroke Cummins Conversion Kits
Whatever else you may need to go fast or tow with your truck. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
95 5SPD F350 4X4 4:11LS For Sale
New Truck- 02 F350 Dually 4x CC 6spd- 05 CR Cummins Built For Pullin And Raisin Hell
Yes i broke a nozzle one time and it also made one hell of a knock like a rod.
334hp 740tq
rdrcm #29
The only smoke I ever see is black smoke. Would a bent red get progressively worse, because it has been getting worse ever since I got done with my road trip and now it is so bad that I can feel it in the truck.
had that once, broke the block too, I hated that day.
But with as many times as he has run it out or low on oil could it be possible that it is a rod?
334hp 740tq
rdrcm #29
if you run low or out of oil the injectors stop firing first , hence engine stops, you can not run teh main gallery or crank or rods out of oil first, great safety feature from Ford.
um international, and more specifically i beieve ya can thank cat for it. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] sorry i feel like being a smart --- today. [img]/ubbthreads/images/graemlins/cool.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img]
<span style="color: #FF0000">#18</span> not all trucks are created equal
THE COWBOY'S CADILLAC,<span style="color: #FF0000">my pics.</span>, 96 F-350 XLT SC DRW PSD, 4x4 conversion(D60),more oil than you, auto tranny by faubion motorsports, tuned by a backwoods hack(thanks tony), 230cc injectors, D66 turbo, head studs, 910 valvesprings, open element intake, homebuilt fuel system, 3-4"DP, intercooler with homemade spider and piping, 5" chrome stacks with turnouts, front hitch(for my weight bar), member of the <span style="color: #FF0000">WNYPA</span>
Bent rod makes more sense, when i did the injectors i sucked the oil out of the cylinder and put the injectors in and pulled the plugs out except for #8 as it didnt want to come out and when it hydrolocked it hit pretty good. so i then pulled the injecor back out and was able to get the rest of the oil out of the cylinder. after i started it up it sounded fine and drove it around a day or so and then took my 1000 mile trip and on the way it started to knock and steadily got worse. The ridge at the bottom of the bore must be just steadily eating away at the piston skirt.
well now you used up that one day a year real early didn't ya? [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
yes, you failed to mention the hydrolock on #8, most of the oil and fuel go into that cyl, bad problem. You should really jsut start by gettign ready to pull the motor, you may be able to save it now, I hope.
