I was inspecting my tank and I cannot find a rollover valve. Is there one a 4X2? I want to do the fast fill mod.
1995 F-350 XLT DRW
212,000+ miles
3" down Pipe
4" AFE Exhaust
No muffler
DIY TYMAR
DIY IDM mod
DIY Injectors
DIY Water Injection
DIY HPX
BB mod
Tony Wildman Chip
17* HPOP
6.0 IC
HID headlights
Gauges: Pyro, Boost, Trans John Wood Trans with a 6.4 T/C Truck Pics
Just did it, WOW, well worth the time and effort. You can do the front tank in place, but you'll have to drop the rear. Mine needed dropped anyway, I take what I would call very good care of my truck, and my rear tank had quite a bit of rust under the straps that I cleaned up and repainted. Now I have piece of mind too.
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
I have not done it yet, but I was looking for the rollover valve and I could not see it. I found the feed/return/fuel sending unit cover and the filler neck, but I can't seem to find the rollover valve. BTW, my tank is metal (don't know if it matters or not)
1995 F-350 XLT DRW
212,000+ miles
3" down Pipe
4" AFE Exhaust
No muffler
DIY TYMAR
DIY IDM mod
DIY Injectors
DIY Water Injection
DIY HPX
BB mod
Tony Wildman Chip
17* HPOP
6.0 IC
HID headlights
Did some more feeling around and I finally found it! Thanks
1995 F-350 XLT DRW
212,000+ miles
3" down Pipe
4" AFE Exhaust
No muffler
DIY TYMAR
DIY IDM mod
DIY Injectors
DIY Water Injection
DIY HPX
BB mod
Tony Wildman Chip
17* HPOP
6.0 IC
HID headlights
I started the mod today and I didn't want to use JB weld on the rollover valve. So I decided to make a new part for the application. I started off with 1-1/2" solid round of Delrin and copied the profile of the OEM rollover valve. I drilled and tapped it for 3/8" NPT. On the filler neck I was able to just knock out the inner vent piece with a couple of good hits with a hammer and screwdriver. Once again I opted not to use JB weld and instead brazed a brass barb fitting to the filler neck. I still need some hose to finish the job and do some testing.
1995 F-350 XLT DRW
212,000+ miles
3" down Pipe
4" AFE Exhaust
No muffler
DIY TYMAR
DIY IDM mod
DIY Injectors
DIY Water Injection
DIY HPX
BB mod
Tony Wildman Chip
17* HPOP
6.0 IC
HID headlights
that looks very good. probably one of the best job's i've ever seen on this mod.
<span style="color: #FF0000">#18</span> not all trucks are created equal
THE COWBOY'S CADILLAC,<span style="color: #FF0000">my pics.</span>, 96 F-350 XLT SC DRW PSD, 4x4 conversion(D60),more oil than you, auto tranny by faubion motorsports, tuned by a backwoods hack(thanks tony), 230cc injectors, D66 turbo, head studs, 910 valvesprings, open element intake, homebuilt fuel system, 3-4"DP, intercooler with homemade spider and piping, 5" chrome stacks with turnouts, front hitch(for my weight bar), member of the <span style="color: #FF0000">WNYPA</span>
I ended up making a new adapter because I didn't like the lip that is used to retain the fitting in the tank. I originally machined the taper at a 10* angle, but it wasn't steep enough. I made version 2.0 today and used a 20* taper, much better looking and matches the OEM perfectly. I installed it and it fits like a glove. I also routed the hose and filled up the tank. It works great! I actully got to fill up the tank without a spit up!
Although the web page says to use a straight fitting, I opted to go with a 90* elbow on the filler. I also was careful to route the hose in a continuos drop without a "trap". Now someday I'll get to the rear.
1995 F-350 XLT DRW
212,000+ miles
3" down Pipe
4" AFE Exhaust
No muffler
DIY TYMAR
DIY IDM mod
DIY Injectors
DIY Water Injection
DIY HPX
BB mod
Tony Wildman Chip
17* HPOP
6.0 IC
HID headlights
That fitting looks great, only problem I see is it WILL NOT fit on the rear tank, it is very low clearance where the rollover valve is.
I just used WATT's nylon elbows from Home Depot. 3/4" pipe tread to a hose barb of whatever size hose you use. And yes, you have to space the tank down some when you reinstall it.I cut some strips off an old truck mud flap for between the top straps & tank. Little longer bolts in the skid plate & all was fine.
97 F250 SC LB 4X4 PSD TDE0, E4OD,3.55's, 285/70/16"s ,Modified fuel tank vents, 375+k headed for 500k
Y'all might consider buying new roll-over valves and rubber grommets for the F450/F550. They drop right in, the hose barb end is 5/8 or 3/4 (can't remember), and they're designed to vent more air. I wish I'd saved the FoMoCo part numbers but I was in a hurry when I did the install. I bought all the parts from Dale @ TYMAR and he'd probably sell you just the pieces you want or the whole kit.
Fred
<font color="009966">`97 F250HD, XLT, CC, SB, 4X4, E4OD, 3.55's, Calypso Green/White, 141K, TDE0, Built 4/97.</font>
Mods: 3/8" trans lines, 1.00 A/R Turbine Housing, Stancor GPR, FTVB, Bill's Chip[img]/ubbthreads/images/graemlins/smokin.gif[/img], JoeServo IDM[img]/ubbthreads/images/graemlins/biggrin.gif[/img], Filler necks vented, Gutted EBPV, Hypermax DP, 4" Tymar Exhaust, GTS I/C, Add-A-Leafs F&R, Un-shimmed, Pyro-Boost-Trans Gauges, Tymar Intake & HPX Hose, TRU-COOL 4590 28,000 GVWR.
`04 Nash 285D 5er, Prodigy brake controller.
`70 VW Bug: 1776cc, Berg CW crank, Berg 42DCNF's, Engle 110 cam, HD valve springs, etc... Almost as much fun as a PSD!
I saved the bags. E8UZ-9B076-A is the # for the grommets and F4TZ-9B593-H is the short rollover valves and they use 3/4" hose. 3/8" rubber strips shimmed the rear tank down enough for valve clearance.
Cool. Thanks for the part numbers, I just added them to my spreadsheet. Good tip to use 3/8" rubber strips for the rear tank spacer. That's the missing link on my tank vent mod so my rear tank really doesn't fill any faster yet. Hey, maybe I'm motivated enough to get it done now.
Fred
I didn't space mine down. I just used the watts nylon fittings and made the rear fitting as short as I possibly could. It is a trick to get the rear hose flowing right, but I did and it works great. I still think one of the best parts of this mod is the piece of mind I got from "derusting" the tank where the straps go over it and painting it up. Now I shouldn't have to worry about it for another 10 years or so...
