Old 05-14-2007, 02:19 PM   #1 (permalink)
RSK photos please!
Who has some photos of the truck with RSK installed showing the overall look, how much the brackets show, and how you dealt with the bumper ? Radarman has good ones but he hasn't got any with the bumper on there.
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 05-14-2007, 03:44 PM   #2 (permalink)
My Photos: (17)
Re: RSK photos please!
Only one I have uploaded that has newest setup, I spaced bumper out 1.5 inches and then used the lower rubber valance off of an F150, you can't see the RSK at all. Only thing you notice is the shackles in the back.
1996 F250 Crew Cab 4x4 PSD Mods=
All DIY- E4OD Upgraded DIY Rebuild at 125k, Stroked Injectors, Tymar Style Intake, Exhaust, IDM, DIY RSK with V code SD springs, 1-piece TTB, Big Tranny Cooler and Full Tugger Kit
DP Tuner Chip
Pyro-Tranny-Boost Gauges in Autometer Full Pillar mount
My Truck
highfive is offline
Old 05-14-2007, 07:42 PM   #3 (permalink)
There are some on my link.
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 05-15-2007, 07:43 AM   #4 (permalink)
4rcFed's Avatar
My Photos: (6)
Nice truck highfive! [img]/ubbthreads/images/graemlins/biggrin.gif[/img] What size tires are you running? And by some of your pics, and your sig, I guess you made your RSK? Regardless, did you still move the front sprin support forward?
Thanks!
1997 F-250 HD, XLT, PSD, Ext. Cab, Off-Road pkg., 3.55's, E4OD, 4wd, Dana 60 swap, 3" Sky RSK, Lund visor, 151,000 miles, triple Auto Meter gauges, Tymar intake, Tymar DP, Straight piped, 5" Miter Stacks, Tuning by DP Tuner, 315/70/17's.
Without data, it is just another opinion!!
4rcFed is offline
Old 05-15-2007, 12:55 PM   #5 (permalink)
My Photos: (17)
Thanks, yes i made the brackets and did move them forward for the SD springs. I am going to have a new set of plates cut on the laser and try to draw them up so I don't have to space the bumper at all but I don't know if there is enough room yet for sure or not. I don't want to jinx it but I scored a killer deal on a kingpin 60 to bolt in I just need to pick it up before he comes to his senses but I already paid him so it should be good as gold. [img]/ubbthreads/images/graemlins/cool.gif[/img]
highfive is offline
Old 05-15-2007, 02:14 PM   #6 (permalink)
High Five,
Did you make a set of drawings the those mounts and shackles?? How did you keep from moving the front bumper out as far as Cary's?? Cary's bumper seems to be out much farther than yours..... or is it my imagination?
If you have some drawings/specs. for the mounts and shackles will you post them??? I really like the looks of the front bumper!!!
97' F250 4x4 crew cab. 4:10 gears,High Idle mod, Dana 60 conversion using 3"SKY RSK w/03' SD springs and 3 3/4" rear blocks to level. Tymar, Issopro gauges on 3 gauge pod, 3" down pipe, shimmed FPR and DP tuner 6 pos. chip (12-13-07).
http://community.webshots.com/user/amberjax
amberjax is offline
Old 05-15-2007, 03:07 PM   #7 (permalink)
My Photos: (17)
A few minor things here and that can gain you some room with the spacing but may cause more problems for intercoolers and such so you have to plan for what you want.
I have drawings for the old plates but I am scrapping them and going with new ones to make everything fit better. I don't know exactly how cary ended up centering the axle but when I moved the bracket forward I did a couple of things to gain some room, by centering the axle about .5 to .75 inches back and by rotating the front bracket slightly to the front you gain some more and a slight notch on one side got it where it is but like I said I am going to make new brackets that will have an offset below the bumper bracket and bumper edge but also be wider to spread the load on the frame. Probably do them next month, I will take actual pics of the plates this time before they go on, I hope to be able to get rid of the bumper spacers completely but it doesn't bother me the way it is now it looks like the SD's do I think.
Oh yeah, on the shackles I used some factory ones at first but didn't like them and ended up going with shackles from sky, they will sell the pieces separately and the shackles are extremely stout and were only like $60.
highfive is offline
Old 05-15-2007, 03:45 PM   #8 (permalink)
My Photos: (6)
Sniff...
Gosh.. thanks for making me feel that much worse that my truck is all torn apart like it is..
[img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
'95 F250 XLT 4X4 Ext Cab long bed, 5 speed, SMFW, custom kevlar LuK clutch by Superior Friction San Jose, 3.55 LSD, '88 kingpin D60, Sky RSK with SD V code springs, 175K miles, ATS 1.15 BB turbo, BDP Stage 2.5 injectors, BDP fuel system, 4 line Stealth, '02 120V IDM, ARP studs, Spearco 7.3 intercooler, 3" intakes, Northern Diesel Performance 6-pos TS chip w/TW tunes, guages, Tymar intake, EBPS bypass mod, IH bellowed uppipes, 4" DP, straight exhaust, 200PSI train horns and 215A alternator..
Home of the 94 and 95 HPOP anti bleed down mod
General Truck pictures..
radarman is offline
Old 05-15-2007, 06:49 PM   #9 (permalink)
High Five,
Please post the new ones when you get them done. Is there any way you could email a drawing of the old bracket?? Like to get any idea of what you did. You can pm to me if you'd like. Thanks!
amberjax is offline
Old 05-15-2007, 08:42 PM   #10 (permalink)
My Photos: (17)
Do you have visio or powerpoint or anything like that?
highfive is offline
Old 05-16-2007, 02:31 AM   #11 (permalink)
Hey Highfive,
Would you be able to send tehm to me as well.
Still working on my solid Dana50.
1996 F250 4x4, SB Ext. Cab, 5spd, 285-75-16's, Tymar intake, Shimed FPR, 320,000km,
bigtcustom is offline
Old 05-16-2007, 06:55 AM   #12 (permalink)
My Photos: (13)
Sorry to hack in, but has someone done this with SD lift springs? 2", 4", or bigger?
Tim
'97 F350 crew cab 4x4 lwb xlt 5 speed 225hp
'95 F250 reg cab 2wd xl auto 215hp
75f100 is offline
Old 05-16-2007, 12:23 PM   #13 (permalink)
I have a set of X, 5" and 7" Donahoes I will be playing with this summer [img]/ubbthreads/images/graemlins/biggrin.gif[/img] Anything over the X I will need to go to crossover steering $$$ [img]/ubbthreads/images/graemlins/vulnerable.gif[/img] and I really don't want to go that high but may end up there to be able to run 37"
Cary
2006 Yamaha FJR1300
caryt is offline
Old 05-16-2007, 01:28 PM   #14 (permalink)
Now you guys got me thinking about the front brackets...If a guy made up a set that mounted to the frame like the RSK kit with regular F350 leafs would, in other words no moving of the bumper mounts, then made the bracket like a bannana facing foreward to put the front of the spring under the bumper........darn wish I hadn't bought the SKY kit already......
Old 05-16-2007, 02:43 PM   #15 (permalink)
tjbeggs's Avatar
you are correct! I see no reason (especially if you use 3/8 plate rather than 1/4) that you couldn't build brackets that pretty much bolt up like the rest but are formed in such a way as to leave room for the bumper not to be moved. It would be more work and more steel but to me its worth not having to move that bumper out there. If you have a ever seen many modern(boss, blizzard) snow plow brackets you could easily see how it could be done. I wish I were closer to making this project happen and I would start making my brackets but I have a few other things that need to be done first
1997 F-350 CC LB 4x4 Auto, AD's, Chip, IC, 4Wh. Disk Brakes, and other stuff
Truck Pics
tjbeggs is online now
