Old 03-26-2008, 06:21 PM   #1 (permalink)
RSK with SD Springs/ Rear Shackle Flip
I have been reading a lot about the RSK with the SD springs. I just have a few questions that I can't seem to find answers to.
IIRC, the Super Duty V codes dont give any extra lift but have a softer spring rate, and ride the smoothest, while the X codes add 1-1.5" of lift and are still smoother then the OBS springs.
My question is, if I go with the 3" RSK and the X codes, that will give me 4-4.5" of lift in the front, correct?
Also, If I do go with the X codes in the front will I need longer shocks, brake lines, and a pitman arm???
My other is about doing a Rear shackle Flip.
I was thinking about going with Super Duty Springs in the rear as well.
What is the difference between Super Duty rears if any? Do some add lift do some ride smoother?
Also, If I do go with super duty springs in the rear will I be able to do a Rear Shackle Flip?
My main goal is to have a smoother ride, 3-4" of lift and the truck to sit level.
thanks,
Justin
1996 Ford F350, 7.3 PSD, crew cab, 8ft bed, 4x4, 5 speed manual, 4.11 gears. 184,000 miles. 3x4" down pipe, 4" exhaust with 5" polished SS tip, gutted EBPV, chrome nerf bars, autometer ultra lite pyro and boost gauges, alpine cd player, alpine speakers,garmin GPS.
"Real trucks have 3 Pedals, 2 Sticks, and No Spark Plugs"
gilroyracing is offline
Old 03-27-2008, 01:20 AM   #2 (permalink)
Jcart's Avatar
CaryT would be the Go to Resource on this, do a search on him or PM him. I kept my springs stock, 2.5" custom RSK and Velvet rides on the rear and it made a significant change to handling and ride. Can only imagine the longer SD springs would be that much sweeter....
jrc
96 XLT F350 CC ZF-5 355's 16x8 aluminum rims 285/75R 16 Dick Cepek F-C IIs. T Wildman programs, Map regulator, DIY CCV & HX mod, TDS exhaust brake, BD gauges, downpipe 4" exhaust, custom SS resonator, LUK, SD I/C, Custom Shackle Reversal, Custom Moose Bar and Velvet rides, RS 9000x shocks, Custom Aluminum Drybox/fuel tank, Swamp's Baby Injectors, SD Hpop, DIY Oil by pass filtration, DIY electric fans, DIY E-Fuel system, Lighting by VisionX, LightForce and PIAA and other stuff.
http://community.webshots.com/user/jcart44
Jcart is offline
Old 03-27-2008, 01:33 AM   #3 (permalink)
CaptinCrash's Avatar
What does RSK stand for
sorry about frequent miss spellings I'm severly dylexic
A true Desert Racer For life
1997 f250 4x4 ex.cab long bed 7.3l Scalzo Racing Chase 1
Airraid stage 2intake
Real Men Use The Green Pump
CaptinCrash is offline
Old 03-27-2008, 10:14 AM   #4 (permalink)
The post directly below this one will help.
RSK kit?
'95 F250HD XLT XC LB, 4:10's. K&N filter (kept dirty haha) 6 Pos Wildman tuner, Tymar DP straight piped to 5" miter stacks, Autometer Ultra-Lite Pyro/Trans/Boost Guages in an Autometer triple pillar pod. Diamondplate Weatherguard Toolbox, Diamondplate bed caps, full Diamondplate tailgate protector, 6" Drop bumper, Diamond headlights/marker lights/turn signals, tinted windows. Lots of interior stereo mods. Dana 60 swap in the works.
1993 F150 Lightning, CAI, Valvebody Shift kit, Eaton Posi, LFP Traction bars. Totally upgraded Sound system.
2003 Ford Mustang Cobra, 2.81 pulley, Dropped 2", 18" wheels, Full Bassani exhaust, JLT CAI, Accufab 100mm TB, Custom Tune. Totally upgraded sound system, and then some.. 430RWHP 466RWTQ
1982 F150 RC LB 4x4, Plow TRUCK
weareweird69 is offline
Old 03-28-2008, 10:12 PM   #5 (permalink)
RSK= Reverse Shackle Kit
Old 03-30-2008, 07:17 PM   #6 (permalink)
Ttt...........
Old 03-31-2008, 08:13 AM   #7 (permalink)
gnxtc2's Avatar
You don't have to go with "X" codes. SKY makes a RSK that gives you 5" lift.
I was taking with my chassis guy and he has a F350 OBS all done up. He has done everything through the years and now it's on an air bag suspension. Here is his truck: JW Racing Fabrication LLC - Seymour CT and jwracing-fab.com :: View topic - My 1997 F350 with 2 feet of lift He made all the brackets and everything himself.
I was talking with him about the rear shackle flip. He wasn't too thrilled about it but said it could be done. Yes, it will change your wheelbase and pinion angle. Also you can fold the shackles in the back.
When I ordered my RSK from SKY last week, I inquired about the shackle flip and they were so-so about it. They did tell me that the pinion angle will change and you will have to play with. They even told me that you might have to use a 4* shim. I asked if I could buy the rear HD shackles and he didn't give me a straight answer. He just told me that the rear shackles will give 1" higher or lower lift but would not elaborate on it.
Billy T.
gnxtc2@aol.com
'97 Black F250HD,XLT, SC, LB, 4x4, Suncoast E40D, Triple Disk Converter, Dana 60, 3.55LS, built 12/97, US GEAR downpipe, Bilstein 5150s, Front add-a-leaf w/urethane bushings, VDO EGT, Trans Temp, and Boost gauges, Hellwig rear swaybar, Shimmed fuel regulator, 4" Exhaust-Straight piped,FORD AIC, Custom triple A-pillar gauge holder,B&M Supercooler, gutted EBPV, B&M Transpan, ART Cryo slotted rotors, Tony Wildman 4 position chip, Joe Servo IDM, MAP sensor mod, Blackbird rear disc conversion, RSK w/ "V" & "F" code SD springs, 149K
PICTURES OF IT ALL
Fort Lee, NJ
gnxtc2 is offline
Old 03-31-2008, 10:59 PM   #8 (permalink)
thanks for the info billy
