RSK & Super Duty Spring Swap - Page 3 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 10-28-2009, 12:01 AM   #31 (permalink)
BadDogPSD's Avatar
Billy, if your question was for me, my truck seems to wander quite a bit. I'm constantly correcting the steering. I don't really know if it's the dropped pitman arm. I've been looking for my stock one to swap out to see if it makes a difference, but can't find the darn thing... moved a couple of times since I did the swap. I'm sure it's in a box somewhere!
1997 F250 4x4 Crew Cab PSD; Modded H2E, FFD Stage 2's, CPR Fuel, SRP1, ARP studs, Comp 910's, DI pushrods, Dana 60; Sky RSK w/SD springs.
BadDogPSD is offline
Old 10-28-2009, 06:51 AM   #32 (permalink)
ammayernick's Avatar
He is telling me that the tie rod ends would have to be cranked out to get the steering wheel back to center. More on one side then the other. This shop is the only one I'll let touch the truck so I trust his recommendation. However, I trust you guys opinions as well. I want to make the right decision here before I go ahead with the pitman arm.
2011 F350 CC Lariat 6.7 4x4 Tuxedo Black Loaded* ICON 4.5 inch Stage II with 4 link and Deaver Mini-Paks * OUO 5" Traction Blocks & Bars * 20" BMF Novakanes with 37x12.50x20 Nitto Trails * ICON Dual Steering Stabilizer * RECON Projectors, Mirror, 3rd brake, Cab,and Tailights * Pace Edwards Bedlocker * EPIC Door Seal Mods * AMP Research Steps * http://community.webshots.com/user/ammayernick
ammayernick is offline
Old 10-28-2009, 09:46 AM   #33 (permalink)
BadDogPSD's Avatar
Both the tie rod & drag link adjust from only one side. The passenger side is 'fixed', at least on my truck. Yes, he would have to lengthen the drag link using the adjusting sleeve. The tie rod connecting the two steering knuckles would be adjusted the same for both the stock or drop pitman arm. This only adjusts the tow-in. Cary has done a bunch of these conversions, and has helped with a bunch more... maybe you could try it with the stock arm & then go the with the dropped one if it doesn't work out correctly?
Old 10-28-2009, 09:50 AM   #34 (permalink)
Feedback Score: 3 reviews
What.....thats nuts! A RS kit will not change the alinement and to center the steering wheel you don't adjust the tie rods. You adjust the drag link. Now if the toe in is correct but the wheels are not both adjusted equally in then you pop one tie rod off to fix. then readjust the toe in.
Cary
caryt is offline
Old 10-28-2009, 01:07 PM   #35 (permalink)
We figured out what happened. I forgot I had my heavy-duty truck guy do the alignment the last time....HUGE mistake! The draglink end was short(go figure...aftermarket?) and he had all the adjustment on the tie rod ends so out of whack it appeared we had no adjustment left. We are taking everything apart, re-install everything correctly, new draglink end, and finish the alignment.
Old 10-28-2009, 07:59 PM   #36 (permalink)
BadDogPSD's Avatar
Great news! Let us know how it goes
Old 11-02-2009, 07:11 AM   #37 (permalink)
Its done! The ride is so soft and smooth. Eats up the bumps with no bounce or wander. I elected not to go with the dropped pitman arm. What I don't like is the bump-steer. I've changed the stabilizer with no noticable difference. A friend suggested trying it without. Anyone else have this problem?
Old 11-02-2009, 07:27 PM   #38 (permalink)
Leave the shock on. Drop pitman arm will help the bump steer but at a cost of steer feel. Thats why a new longer track bar is the answer..
Cary
caryt is offline
Old 11-02-2009, 07:51 PM   #39 (permalink)
Cary,
Any plans on when you will be releasing the longer trac bar? I always felt it was awfully short and probably binds up the front suspension in extreme articulation. Plus the bump steer issue.
While we are at it, any word on the front transfer case yokes?
What ever became of the billet OBS thermostat housing project?
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 11-02-2009, 11:35 PM   #40 (permalink)
BadDogPSD's Avatar
Casey told me about this after his D60 install... is it available yet?
Old 11-03-2009, 07:35 AM   #41 (permalink)
Parky66's Avatar
My Photos: (5)
Hey Guy's,
Just finished reading up on this thread and I'm very interested in this RSK & Super Duty Spring Swap. Any suggestions on where to start looking for parts and availability for my F-250 ?
Thanks in advance...
Mike
Mike Parker - Parky66
1996 F-250 Ext Cab
Long Bed, 4X4, 7.3 PSD
(ZF5) 5-Speed Transmission
(Twildman's) 4 Position Chip
Auto Meter Cobalt Series Gauges on Full A-Pillar
Tymar Intake
(DPP) 3" Downpipe
(DPP) Catalytic Converter Delete Pipe
Lund Moon Visor
RCI 2950
Kenwood MP3 Player
Parky66 is offline
Old 11-03-2009, 09:28 AM   #42 (permalink)
Talk to CaryT. He is extremely helpful and can provide the parts as well.
Old 11-03-2009, 01:05 PM   #43 (permalink)
BadDogPSD's Avatar
X'2 for for Caryt, he's helped a bunch of us with this upgrade. Well worth it!
Old 11-04-2009, 11:43 AM   #44 (permalink)
Truck looks great. hopefully soon I,ll be doing the same.
Where are you guys getting your Bilsteins? I can't seem to find them for the OBS.
1996 F-250 7.3L 4x4 ext. cab Long Bed
Superchip, Intake, Exhuast
4 wheel disc brakes
6.0l IC, guages.
967.3L4X4 is offline
Old 11-04-2009, 03:14 PM   #45 (permalink)
BadDogPSD's Avatar
Get in touch with Caryt at CT Peformance. He's got good prices and figured out the valving in the shocks to give the best ride quality.
